    Screen distorted_URGENT HELP!
    14 Posts 7 Posters 1.9k Views 7 Watching
    • H
      h4zel
      HI Solo , i try yur suggestion and off the open Gl accelerator
      The distorted stop.. but whenever i turn the view. the screen froze and
      everything is very very slow.
      Any other solution. with open Gl maintain. 😎
      grafic card : nvidia Gforce 8500 GT
        remus
        Did you try turning of anti aliasing or did you just turn of 'hardware acceleration'?
        If the latter, try the former.
        • H
          h4zel
          hmm.. i try turn off hardware acceleration.. no distorted but it to jumpy to draw.
          using OPen Gl hardware acceleration 16x True color Medium 0x anti-alias
          problem still occur.. blur whenever i used a commands except Paint 😐
          • soloS
            Do you have updated drivers? as this looks exactly like the problem I had two years ago when they first launched the 8800 gtx card and I had to wait for months until updated drivers were available.
            • H
              h4zel
              Hmm. i downloading the driver now.. 112mb .>.<" will take awhile..
              will keep update if it work.. thx again solos
              • C
                Charlie__V
                h4zel,
                I had the same problem a number of months back.
                The following soved the problem for me
                Re: Nvidia GeForce 8700MGT
                by CHARLIE__V on Sun Jan 11, 2009 9:12 am
                Hello all,
                Anyone running an Nvidia GeForce 8700MGT with hardware acceleration enabled ?
                I searched and found that an older driver for the 8800 allows for HA, but no such driver for the 8700.
                EDIT:
                Well for those interested....looks like I may have solved/answered my own question.
                Seems I had a combination of option settings selected that were causing me grief.
                In the Nvidia control panel I needed to have the image setting set to
                Let 3D app Decide
                And in SU preferences....Open GL....Capabilities....use an option with
                Anti Alias set to 0x
                SLI Enabled/Disabled does not seem to make a difference.
                Above settings are with Dell driver 176.78_Dec21_2008
                TIA.....
                best,
                Charlie
                Specs:
                Dell
                XPS M1730, Intel Core 2 Extreme X9000(2.8GHz, 800Mhz 6M L2 Cache)
                NVIDIA SLI Dual GeForce 8700MGT with 512MB GDDR3
                4GB, DDR2, 667MHz
                320GB 7200RPM Hard Drive
                OS: XP Pro SP3
                • H
                  h4zel
                  HI charlie, i will try out yur way.. hope it work..
                  recently been busy no time to try on it yet..
                  will let u know if it work πŸ˜›
                    dlomas
                    Try changing Styles/Edit/Face Settings/Transparency Quality ->faster.
                    Also turn off; Model Info/Rendering/Use Anti-Aliased Textures ->turn it off
                    • H
                      h4zel
                      HI all,
                      Hey charlie. yur method work.after i set it. no problem so far good to go ^.^ thx for all the valuable comment every 1 πŸ‘
                      • P
                        PRSS
                        Hi h4zel
                        Forceware version 169.21 should certainly work out for you. Google search for this and you'll get the download. I had this same problem with my 8600GT & 8800GT cards in my home & office computers respectively. The problem disappeared after I installed this older version of drivers (Windows XP).
                        Hope this helps.
                        With best regards
                        PRSS
