    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      fredo6
      @dave r said:
      Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
      Yes, I did install LibFredo6 version 3.1. However, I didn't remove all of the old program, I just renamed the directories until I was sure this version would work.
      Now, however, I did remove all of the old directories, I now have this error.
      Working my way to total victory.
      Thanks for the replies
      Ken
      Ken,
      Do not remove or rename anything. Just install the Library LibFredo6 3.1 and FreeScale 2.0, as indicated.
      Then, if it works, you may want to remove the folders LIBFREDO6_Dir_30 and FREESCALE_Dir_10, but it does not really matter you do it right away, as they will never be loaded.
      Fredo
      • W
        wolfy
        Fredo, you are truly amazing!! ☀ Thanks so much for all your hard work, dedication and generosity!!!
        • O
          otb designworks
          awesome awesome awesome!!!
          Fredo, if it wasn't for you, I think I would have left SU in my dust ages ago.
          Just simply fantastic and thank you!!
          Cheers, Chuck
          OTB Designworks is on Youtube
          • ely862meE
            ely862me
            This is
            http://www.webdeveloper.com/animations/bnifiles/dmfire.gif
            Well done....i m still wondering what is sketchup going to become with such smart people like Fredo..
            Thanks a lot!
            Elisei
            Elisei (sketchupper)
            Come and See EliseiDesign
            • fredo6F
              fredo6
              to all users
              First of all thanks very much for your warm encouragements. Note that the reward should also go to the SU team, for the native capability of the 3D application and for the design of the API, which is quite powerful (and of course the choice of Ruby). Stretch is actually simply based on the functionality of the native Move tool, and the other deformations just rely on the capability of Sketchup to transform faces and edges when you move vertices.
              A few remarks based on comments received:
              1. For Bend, I would recommend that you configure the slicer with a 'negative' number. This allows to adjust automatically the number of slices based on the angle. With a small angle, you will only get a few slices. The convention is based on a 12-sides circle (360 degree). For instance "-3" corresponds to a circle of 36 edges.
              2. The slicer is based on the Sketchup "Intersect With" functionality(to answer a question from Whaat). Unfortunately, the API method does not seem to be able to cut lonely edges. If you have some in your model, they wont be smoothly bent and could even create some geometric mess.
              3. Plane Shear is a simple transformation, but it also 'shears' the axes of the components, so that they are no longer orthogonal. Although in most cases you do not have to bother, it might be that some scripts encounter problems with those components if they assume that the axes are orthogonal. Just in case, though I don't have any script in mind!
              4. I forgot to mention the "Make Unique" function. All transformations manage it automatically, but again, it easy to mess up or get bugsplat with too quick Undos. So if you know for sure that you want to transform complex sets of embedded components, you can use the Make Unique function once for all.
              5. I recommend you watch the edges generated by Bend and Twist with slicer on. By default, they are created as soft and smooth, so the surface may look smooth. It is good however to check the details to avoid late surprise. In most cases, you should avoid to deform twice the same area.
              6. The protractor plane-lock works in Toggle mode. You do not need to keep the Shift key down. Lock is also set when pressing arrow Up, Left, Right for the axes. Arrow Down will unlock the plane.
              7. For the Donation, there is a menu in FreeScale. So you do not need to care about the HTML file. Thanks for those who already donated. Again, the script is totally free.
              Please do not hesitate to report bugs and problems so that I can improve the plugin for all.
              Fredo
              PS: by the way, if some knows how to embed a YouTube video within a message!
              • soloS
                solo
                I embedded the youtube video in your original post.
                http://www.solos-art.com
                • urgenU
                  urgen
                  ---Thanks!!!!! 👍
                  ------Thanks!!!!! 👍
                  ----------Thanks!!!!! 👍 😄
                  --pupil forever...------
                  • PixeroP
                    Pixero
                    Fantastic!
                    I was waiting for the bend tool and now we got the others as well.
                    Then the stretch tool. Just wow! What a timesaver.
                    I'm shocked at what you can do by yourself.
                    It would be quite interesting to be a fly in the SU teams office when they see this plugin. 😉
                    Google team shame on you +2.
                    • S
                      sepo
                      "1) For Bend, I would recommend that you configure the slicer with a 'negative' number. This allows to adjust automatically the number of slices based on the angle. With a small angle, you will only get a few slices. The convention is based on a 12-sides circle (360 degree). For instance "-3" corresponds to a circle of 36 edges."
                      How do you do that? I do not seem to have any GUI. In your video there is one.
                      • thomthomT
                        1. Plane Shear is a simple transformation, but it also 'shears' the axes of the components, so that they are no longer orthogonal. Although in most cases you do not have to bother, it might be that some scripts encounter problems with those components if they assume that the axes
                        I might be working on one at the moment. A script that generates a second cutout for cutout components so you can cut through double faced walls. I haven't checked yet, but I have a suspicion that it might not work out the position properly. So I'll see if I can account for this.
                        • soloS
                          solo
                          Hit the tab button
                          • fredo6F
                            fredo6
                            One thing I forgot to repeat and insist on.
                            All transformations in FreeScale are purely geometric. So they totally ignore the behavior of Dynamic Components.
                            I simply hope it does not mess up anything however.
                            Personally, I have not played yet with Dynamic Components (I don't have the Pro version) and I have found nothing in the API allowing to inspect or act on such DC behaviors.
                            Please tell me if you encounter any problem between FreeScale and Dynamic Components.
                            Fredo
                            • S
                              sepo
                              Cheers Solo
                              • soloS
                                solo
                                Works great for rigging too, see Matrix bullet dodge timelapse.
                                http://img27.imageshack.us/img27/6888/matrixmoves.gif
                                • D
                                  dacad
                                  That's cool solo, but don't you mean posing solo?:)
                                  That gave me an idea for an update to ffd plugin for use in posing characters, if we could just place the ffd points in the mesh instead of the standart box position they appear. Is that possible? 😄
                                  • soloS
                                    solo
                                    DacaD, Posing and rigging, same thing.
                                    What would be great is to be able to select a spot and make joints, then using the bend option it only bend at the joint.
                                    however what we have now works pretty good.
                                    http://img27.imageshack.us/img27/7100/neobend.jpg
                                    • D
                                      Dan
                                      Cher Fredo, je n'ai qu'un seul mot a vous dire: SUPERBE!
                                      Hey, Google SketchUp, don't you think Fredo deserves a free license of SU 7 PRO ? I think that his plugins brought you a bunch of extra buyers.
                                      • D
                                        dacad
                                        ups, my mistake then, but i tough rigging was the stuff related with doing the bones for a mesh and conecting them that was then used to animate or pose the mesh, at least from what i can remember from animating in 3dsmax. I also called it posing because of the transpose feature of zbrush that they say artists use to pose characters wihtout doing any rigging... i'm not even sure if that name is righ (in technincal terms and english terms 😛)
                                        That's a good ideia too, to animate in sketchup, a mix between sketchyphisics and freedo's free scale/bend. the Phisend plugin....lolol
                                          clean selection?
                                          Yes clean selection by architectboy or cleanup_model.rb by J.H. Aughey ☀
                                            And then after use Fredo's bend, clean selection can be useful for lighten the object 😉
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 59 / 59
