    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • PixeroP
      Pixero
      Fantastic!
      I was waiting for the bend tool and now we got the others as well.
      Then the stretch tool. Just wow! What a timesaver.
      I'm shocked at what you can do by yourself.
      It would be quite interesting to be a fly in the SU teams office when they see this plugin. 😉
      Google team shame on you +2.
        sepo
        "1) For Bend, I would recommend that you configure the slicer with a 'negative' number. This allows to adjust automatically the number of slices based on the angle. With a small angle, you will only get a few slices. The convention is based on a 12-sides circle (360 degree). For instance "-3" corresponds to a circle of 36 edges."
        How do you do that? I do not seem to have any GUI. In your video there is one.
          1. Plane Shear is a simple transformation, but it also 'shears' the axes of the components, so that they are no longer orthogonal. Although in most cases you do not have to bother, it might be that some scripts encounter problems with those components if they assume that the axes
          I might be working on one at the moment. A script that generates a second cutout for cutout components so you can cut through double faced walls. I haven't checked yet, but I have a suspicion that it might not work out the position properly. So I'll see if I can account for this.
          • soloS
            Hit the tab button
            • fredo6F
              One thing I forgot to repeat and insist on.
              All transformations in FreeScale are purely geometric. So they totally ignore the behavior of Dynamic Components.
              I simply hope it does not mess up anything however.
              Personally, I have not played yet with Dynamic Components (I don't have the Pro version) and I have found nothing in the API allowing to inspect or act on such DC behaviors.
              Please tell me if you encounter any problem between FreeScale and Dynamic Components.
                sepo
                Cheers Solo
                • soloS
                  Works great for rigging too, see Matrix bullet dodge timelapse.
                  http://img27.imageshack.us/img27/6888/matrixmoves.gif
                    dacad
                    That's cool solo, but don't you mean posing solo?:)
                    That gave me an idea for an update to ffd plugin for use in posing characters, if we could just place the ffd points in the mesh instead of the standart box position they appear. Is that possible? 😄
                    • soloS
                      DacaD, Posing and rigging, same thing.
                      What would be great is to be able to select a spot and make joints, then using the bend option it only bend at the joint.
                      however what we have now works pretty good.
                      http://img27.imageshack.us/img27/7100/neobend.jpg
                        Dan
                        Cher Fredo, je n'ai qu'un seul mot a vous dire: SUPERBE!
                        Hey, Google SketchUp, don't you think Fredo deserves a free license of SU 7 PRO ? I think that his plugins brought you a bunch of extra buyers.
                          dacad
                          ups, my mistake then, but i tough rigging was the stuff related with doing the bones for a mesh and conecting them that was then used to animate or pose the mesh, at least from what i can remember from animating in 3dsmax. I also called it posing because of the transpose feature of zbrush that they say artists use to pose characters wihtout doing any rigging... i'm not even sure if that name is righ (in technincal terms and english terms 😛)
                          That's a good ideia too, to animate in sketchup, a mix between sketchyphisics and freedo's free scale/bend. the Phisend plugin....lolol
                            clean selection?
                            Yes clean selection by architectboy or cleanup_model.rb by J.H. Aughey ☀
                              And then after use Fredo's bend, clean selection can be useful for lighten the object 😉
                                Did some testing; no problems at all. I don't have to do any consideration for skewing. 😄
                                • troyhomeT
                                  troyhome
                                  Free for life if you contribute something this helpful without asking anything but feedback in return.
                                  IOviz.com
                                  SU Pro 2024 PC
                                    jmmad
                                    I wrote this not so long ago for your last plugin.
                                    @jmmad said:
                                    Thxs a lot Fred for this plugin, your ruby scripts are amazing.
                                    Do you think you could add more transformations to it, like bend, twist, Bulge
                                    Maybe for a commercial plugin?
                                    http://www.sketchucation.com/forums/scf/download/file.php?id=20380&t=1
                                    And now you make all of our dreams come true and freely?
                                    SU was needing trasformations badly
                                    Thanks for this plugin and for your generosity
                                    I really love the user interface of those deformations, specially Stretch and Bend, so easy and precise to use.
                                    Bend Shear Taper are even easier to use than Bonzai3D deformations.
                                    And stretch its amazing I have never seen something like that before, your solution to the problem of keeping some geometry untouch its genius. Only one feature you could add is to give the strech tool the ability to make more paralel planes that deform the model, so it can afect more parts of the geometry at the same time.
                                    I only have one problem with the stretch tool some times when i strech something even a simple geometry SU freezes and does not respond, and i have to restart SU.
                                    With all your plugins you are giving Sketchup so many atractive and usefull features it's geting updated constantly.
                                    Google should change the name of the program for something like FredoUP
                                    Thanks again.
                                    And yes i think Google should give you a eternal Licence + 1000 for that
                                    Get Upa !
                                    • utilerU
                                      utiler
                                      thanks you Fredo, there is nothing more I can say....
                                      Just Curious...
                                        ScottPara
                                        Shame shame shame on Google for not patting this guys back! How is it that a lone programmer can take sketchup to this level with little resources in comparison to Google? Yet we get Version 7 which is a polished version of 6 yet we all had to pay. Google should either hire Fredo, Whaat, and a few others (did not mean to leave anyone out) or leave the programming to them for 2 years and see what Sketchup becomes!
                                        Fredo....thank you for an absolutely AMAZING plugin!
                                        Google.....take notice!
                                        Scott
                                        Love the fact that some HATE my avatar.....
                                        • X
                                          xrok1
                                          Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
                                          i would love to see the donation page in english too so i could give you some kudos. please post english donation link, and thankyou very much.
                                          Now for the soft selection! 😄
                                          • EscapeArtistE
                                            EscapeArtist
                                            Thank you for this plugin. It is fantastic!
                                            • 58
                                            • 59
                                            • 4 / 59
