    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.3m Views 342 Watching
      mac1
      Su 7.1+ plus here and see the following:
      1. Bug splat for the stretch of the 2 cubed group and can get a bug splat for stretch of just one of them. No bug splat for stretch of one stand alone, before making copy.
      2. Outliner shows the two groups. Report back to 1 by entering edit mode and leaving confirmed ❓
        3)Instead of making groups the cube1 and cube2 were made in nested component then no bug splat. Checking placement of stretching plane shows the tool will change the definition, say of cube2 if plane is thu it and not cube2 in other instance of cubed into differnt instances.
        Ckecking version , may have 2.0
      • fredo6F Offline
        fredo6
        These bugsplats may be related to the fact that when you copy a group, it behaves as a component until it is edited or modified. Normally FredoScale makes them unique, but there may be problem for these type of copy-cat groups.
        Also, having the outliner open is usually not recommended, especially with version 6 and 7.
        fredo
          mac1
          Thanks fredo
          I heed the previous warnings and roll it up before doing any thing.
          It appears I am at 2.0i so will update and look for diff
          Update: 2.1a gives same result
            tulacong
            http://forums.sketchucation.com/download/file.php?id=49290
            With FredoScale 2.1 you can orientate the selection box around a set of objects and interactively apply a number of geometric transformations, such as Scaling, Tapering, Stretching, Plane Shear, Twisting, Bending and Rotation. By extension, some transformation can be done without a selection box.
            [attachment=4:3vnwzr1a]<!-- ia4 -->FredoScale%202.jpg<!-- ia4 -->[/attachment:3vnwzr1a]
            http://forums.sketchucation.com/download/file.php?id=49286
            [attachment=2:3vnwzr1a]<!-- ia2 -->FredoScale User Manual - English - v2.0 - 28 Mar 09.pdf<!-- ia2 -->[/attachment:3vnwzr1a]
            [attachment=3:3vnwzr1a]<!-- ia3 -->FredoScale User Manual - French - v2.0 - 28 Mar 09.pdf<!-- ia3 -->[/attachment:3vnwzr1a]
            • Language: English, French, Spanish, German, Italian, Japanese, Korean, Chinese, German (thanks to all kind translators)
            • Menus: by default, it is installed in Tools > Fredo6 Collection > FredoScale
            • Icon toolbar: by Default ‘FredoScale’. many icons are available, but you can configure which ones to display (menu Default Parameters…)
            • The plugin is free, for private and commercial usage. There is a donation menu however.
            http://forums.sketchucation.com/download/file.php?id=49287
            1. Download and Open the archive
            2. Select All (Ctrl A)
            3. Extract into the Sketchup Plugin Directory
            4. Answer YES to overwrite all existing files if any
            The footprint in the SU Plugin Directory must be:
            [attachment=1:3vnwzr1a]<!-- ia1 -->Fredoscale 2.1 footprint.jpg<!-- ia1 -->[/attachment:3vnwzr1a]
            On Mac the SU plugin directory should be:
            Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
            CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
            http://forums.sketchucation.com/download/file.php?id=49285
            DOWNLOAD FredoScale 2.1a – 12 Jan 11
            [attachment=0:3vnwzr1a]<!-- ia0 -->FredoScale 2.1a.zip<!-- ia0 -->[/attachment:3vnwzr1a]
            IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
            http://forums.sketchucation.com/download/file.php?id=49284
            [flash=425,344:3vnwzr1a]http://www.youtube.com/v/WN-nV5VsoRY&hl[/flash:3vnwzr1a]
            [flash=425,344:3vnwzr1a]http://www.youtube.com/v/bPbb8PPGtVg&hl[/flash:3vnwzr1a]
            Pour les utilisateurs francais voir aussi l’excellente video de Laurent Brixius
            http://www.arch-image.com/wordpress/2010/04/06/plugin-sketchup-fredoscale/
            http://forums.sketchucation.com/download/file.php?id=49288
            • Select one or several objects (faces, edges, groups or components)
            • Click on the icon of one tool, for instance Scaling
            • You can orientate the selection box:
            • Arrow Upwill align on model axes
            • Arrow Leftand Arrow Rightwill cycle through axes of components at highest level
            • Arrow Downwill restore the initial alignment when selecting
            • Gently click and drag on the handles to perform the deformation. Toggle the CTRL key to perform the deformation from the center.
            • You can type relevant values in the VCB or via a dialog box (TAB key)
            • For Twist and Bend, F4 toggles a Slicer on and off
            • For Stretch, F4 toggles a Divider on and off
            • It is a good idea to check the contextual menu to see available options
            http://forums.sketchucation.com/download/file.php?id=49289
            FredoScale 2.1a - 12 Jan 11: Technical update along with LibFredo6, with two-phase loading. No functional change, but it is advised to upgrade for support.
            FredoScale 2.0i - 08 Apr 10: Same as 2.0h, but includes the Chinese translation.
            FredoScale 2.0h - 26 Nov 09: Stable version
            verygood thanks
            • fredo6F Offline
              fredo6
              @mac1 said:
              Thanks fredo
              I can reproduce the bugsplat.
              This seems definitely related to the question of Groups behaving as components when copied and not edited yet.
              I think I can do something about.
              Just in case, FredoScale includes a commande MakeUnique (icone as a 1) which applies a make unique to groups and components recursively.
              Fredo
              • I Offline
                ivreich
                Hi Fredo
                Thanks for this great set of tools.
                One suggestion- would it be possible to add a "uniform deformation" checkbox to the box dimension dialog box so that you can scale uniformly to a specific dimension? I can't seem to get uniform deformation when using "scale to targets" or while using the dimension dialog box, even when toggling the shift key.
                Cheers
                joel
                  rock1
                  great plugin fredo!. I'm really amazed by this plugin !! I found fredoscale very useful. 👍 👍
                  Signature removed by SCF Admin
                    dedmin
                    • fredo6F Offline
                      fredo6
                      @dedmin said:
                      Do you have the model.
                      The bugsplat in mirroring seems to be related to the question of unique component (again).
                      Fredo
                        dedmin
                        BC1D1S1D.skp
                        • K Offline
                          karros
                          Found this thread (and forum) by chance while looking for some answers on google. Plugin works great, thank you!!!
                            Designmark
                            Thanks Fredo,
                            Downloaded FredoScale today, it's fantastic!!
                            I really appreciate this plugin.
                            Kind regards,
                            Mark.(Newby)
                              merlin7777777
                              I'm getting this error when i start SU (v 8):
                              Error Loading File bootstrap_FredoScale.rb
                              (eval):1: uninitialized constant FredoScale::T6Error Loading File ZLoader__FredoScale.rb
                              no such file to load -- LibFredo6.rbError Loading File __loader.rb
                              uninitialized constant Traductor::Plugin
                              I'm fairly certain the directory structure is as you specify. I extracted the files from the subfolders into their own folders as specified but I also extracted those files to the plugin directory just in case.
                              any thoughts?
                                Jim
                                Did you install LibFredo6, as the instructions say? It's required to run most of Fredo's plugins.
                                  merlin7777777
                                  ah - no. can't see that info in the OP. can you direct me where to go for it?
                                    • gillesG Offline
                                      gilles
                                      I am trying to bend a profile with precision, let say a 4000mm radius bend at 90°.
                                      the only way I found to do this is to first calculate the length of the arc: PI2000, then use the bend tool and type 6283,20 (PI2000) and bend 90°.
                                      Could it be possible to just type the desired radius in VCB ?
                                        merlin7777777
                                        OK - added the fredo6, all works ok except still egtting this error on startup:
                                        Maybe something to do with the double extraction I did?
                                          To be sure it isn't, why don't you remove anything to do with FredoScale and LibFredo and reinstall them so you know they are installed correctly.
                                          • fredo6F Offline
                                            fredo6
                                            Do you use Plugin Organizer?
                                            Another user had the same problem, which can be solved by setting Excluded Directories.
                                            Fredo
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 56
                                            • 57
                                            • 29 / 57
