    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.0m Views 345 Watching
    • mitcorbM Offline
      mitcorb
      And you have no hidden layer geometry? (I don't know if this can cause anything)
      I have nothing to base this on, but could your processor be overtaxed, perhaps you have other applications in operation but minimized and you are trying to run Fredoscale?
      I know that some of the scale operations are difficult for me to select the little boxes, and depending on the complexity of the geometry the processing can take an extended period of time. But I have an old Pentium4, XPhome, NVidia MX class video card. I also have software with process hog issues. None of this may apply to your situation, just possibilities.
        Jibe1982
        Tu es génial Fredo! I think you multiply the value of sketchup by 2 or 3. un grand BRAVO! PS je te conseille de mettre en place les donations, tu pourrais gagner quelque pepettes 😉
          AtomicKangaroo
          An amazing Plug in! Thank you so much for creating it.
            Serg_67
            http://forums.sketchucation.com/download/file.php?id=49290
            With FredoScale 2.1 you can orientate the selection box around a set of objects and interactively apply a number of geometric transformations, such as Scaling, Tapering, Stretching, Plane Shear, Twisting, Bending and Rotation.
            BRAVO!!!
            • W Offline
              warunthorn
              Thak you very much
                jbd
                Sir,
                Amazing, Very Useful Tools Collection.
                Thankyou very much n GBU.
                regards - jbd - indonesia
                  PauloH
                  Thank you, thank you, thank you for this update. It's a beauty and saves me sooooooooo much time. I'm extremely grateful.
                    tomb85
                    First, thanks for this plugin, it's great. Most of the time i need the stretch tool, i'm trying to implement this in my worflow for stretching cabinets, windows, doors, ... but i keep getting the same bugsplat while using it.
                    even with very simple geometry.
                    I make a cube and group it (let's call it cube1). A make a copy of it (cube2) so i have the exact same cubes next to each other. I select both cube1 and cube2 and putting into a new group (cubegroup.
                    so now i have a my newly made group (cubegroup) with 2 nested groups inside (cube1 and cube2). I can use the stretch-tool on this without any problem. After stretching I duplicate my cubegroup. In my entity info window i see that there are 2 of these groups in my model. when i try to stretch my 2nd cubegroup, i get a bugsplat. see my video:
                    http://www.youtube.com/watch?v=uxhelxITBO4
                    Now when i do exactly the same, but instead of trying to stretch my second cubegroup after duplicating it. I first edit my group by entering it, and leaving it. Now my Entity info window says there is just 1 of group of this in my model instead of 2. take a look at my second video where i don't get the bugsplat:
                    http://www.youtube.com/watch?v=0xGhham4AxM
                    any explanation?
                    thanks
                      dedmin
                      Just tried, but no BugSplat for me! Maybe some messing plugins?
                        mac1
                        Su 7.1+ plus here and see the following:
                        1. Bug splat for the stretch of the 2 cubed group and can get a bug splat for stretch of just one of them. No bug splat for stretch of one stand alone, before making copy.
                        2. Outliner shows the two groups. Report back to 1 by entering edit mode and leaving confirmed ❓
                          3)Instead of making groups the cube1 and cube2 were made in nested component then no bug splat. Checking placement of stretching plane shows the tool will change the definition, say of cube2 if plane is thu it and not cube2 in other instance of cubed into differnt instances.
                          Ckecking version , may have 2.0
                        • fredo6F Offline
                          These bugsplats may be related to the fact that when you copy a group, it behaves as a component until it is edited or modified. Normally FredoScale makes them unique, but there may be problem for these type of copy-cat groups.
                          Also, having the outliner open is usually not recommended, especially with version 6 and 7.
                          fredo
                            mac1
                            Thanks fredo
                            I heed the previous warnings and roll it up before doing any thing.
                            It appears I am at 2.0i so will update and look for diff
                            Update: 2.1a gives same result
                              tulacong
                              With FredoScale 2.1 you can orientate the selection box around a set of objects and interactively apply a number of geometric transformations, such as Scaling, Tapering, Stretching, Plane Shear, Twisting, Bending and Rotation. By extension, some transformation can be done without a selection box.
                              [attachment=4:3vnwzr1a]<!-- ia4 -->FredoScale%202.jpg<!-- ia4 -->[/attachment:3vnwzr1a]
                              http://forums.sketchucation.com/download/file.php?id=49286
                              [attachment=2:3vnwzr1a]<!-- ia2 -->FredoScale User Manual - English - v2.0 - 28 Mar 09.pdf<!-- ia2 -->[/attachment:3vnwzr1a]
                              [attachment=3:3vnwzr1a]<!-- ia3 -->FredoScale User Manual - French - v2.0 - 28 Mar 09.pdf<!-- ia3 -->[/attachment:3vnwzr1a]
                              • Language: English, French, Spanish, German, Italian, Japanese, Korean, Chinese, German (thanks to all kind translators)
                              • Menus: by default, it is installed in Tools > Fredo6 Collection > FredoScale
                              • Icon toolbar: by Default ‘FredoScale’. many icons are available, but you can configure which ones to display (menu Default Parameters…)
                              • The plugin is free, for private and commercial usage. There is a donation menu however.
                              http://forums.sketchucation.com/download/file.php?id=49287
                              1. Download and Open the archive
                              2. Select All (Ctrl A)
                              3. Extract into the Sketchup Plugin Directory
                              4. Answer YES to overwrite all existing files if any
                              The footprint in the SU Plugin Directory must be:
                              [attachment=1:3vnwzr1a]<!-- ia1 -->Fredoscale 2.1 footprint.jpg<!-- ia1 -->[/attachment:3vnwzr1a]
                              On Mac the SU plugin directory should be:
                              Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
                              CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
                              http://forums.sketchucation.com/download/file.php?id=49285
                              DOWNLOAD FredoScale 2.1a – 12 Jan 11
                              [attachment=0:3vnwzr1a]<!-- ia0 -->FredoScale 2.1a.zip<!-- ia0 -->[/attachment:3vnwzr1a]
                              IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
                              http://forums.sketchucation.com/download/file.php?id=49284
                              [flash=425,344:3vnwzr1a]http://www.youtube.com/v/WN-nV5VsoRY&hl[/flash:3vnwzr1a]
                              [flash=425,344:3vnwzr1a]http://www.youtube.com/v/bPbb8PPGtVg&hl[/flash:3vnwzr1a]
                              Pour les utilisateurs francais voir aussi l’excellente video de Laurent Brixius
                              http://www.arch-image.com/wordpress/2010/04/06/plugin-sketchup-fredoscale/
                              http://forums.sketchucation.com/download/file.php?id=49288
                              • Select one or several objects (faces, edges, groups or components)
                              • Click on the icon of one tool, for instance Scaling
                              • You can orientate the selection box:
                              • Arrow Upwill align on model axes
                              • Arrow Leftand Arrow Rightwill cycle through axes of components at highest level
                              • Arrow Downwill restore the initial alignment when selecting
                              • Gently click and drag on the handles to perform the deformation. Toggle the CTRL key to perform the deformation from the center.
                              • You can type relevant values in the VCB or via a dialog box (TAB key)
                              • For Twist and Bend, F4 toggles a Slicer on and off
                              • For Stretch, F4 toggles a Divider on and off
                              • It is a good idea to check the contextual menu to see available options
                              http://forums.sketchucation.com/download/file.php?id=49289
                              FredoScale 2.1a - 12 Jan 11: Technical update along with LibFredo6, with two-phase loading. No functional change, but it is advised to upgrade for support.
                              FredoScale 2.0i - 08 Apr 10: Same as 2.0h, but includes the Chinese translation.
                              FredoScale 2.0h - 26 Nov 09: Stable version
                              verygood thanks
                              • fredo6F Offline
                                @mac1 said:
                                Thanks fredo
                                I can reproduce the bugsplat.
                                This seems definitely related to the question of Groups behaving as components when copied and not edited yet.
                                I think I can do something about.
                                Just in case, FredoScale includes a commande MakeUnique (icone as a 1) which applies a make unique to groups and components recursively.
                                • I Offline
                                  ivreich
                                  Hi Fredo
                                  Thanks for this great set of tools.
                                  One suggestion- would it be possible to add a "uniform deformation" checkbox to the box dimension dialog box so that you can scale uniformly to a specific dimension? I can't seem to get uniform deformation when using "scale to targets" or while using the dimension dialog box, even when toggling the shift key.
                                  Cheers
                                  joel
                                    rock1
                                    great plugin fredo!. I'm really amazed by this plugin !! I found fredoscale very useful. 👍 👍
                                    Signature removed by SCF Admin
                                      dedmin
                                      • fredo6F Offline
                                        @dedmin said:
                                        Do you have the model.
                                        The bugsplat in mirroring seems to be related to the question of unique component (again).
                                          dedmin
                                          BC1D1S1D.skp
                                            karros
                                            Found this thread (and forum) by chance while looking for some answers on google. Plugin works great, thank you!!!
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 58
                                            • 59
                                            • 29 / 59
