    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
      rekin0
      Thanks for signaling this.
      • G Offline
        guilhermestudio
        hi,
        I'm with some issues to instal LibFredo6.
        I did all the usual procedure and when I start Sketchup appear this mensage:
        "You must install LibFredo6 version 5.2 or higher to run Fredo6_Curviloft"
        and in the menu/window instead of LibFredo6 Settings I see "Ruby Console" that opens a dialog box, that I have no idea of what tipe on it.
        Please Help
          @guilhermestudio said:
          hi,
          Please Help
          Do you have FULL read/write Security permission set for all users/groups listed under Properties > Security > Edit... for the Plugins folder ?
          If not, then you might think you have installed the Lib folder, but Windows might have actually put it into the VirtualStore to protect you from yourself, but not tell you... 😒
          If you have a link/button in one of the top-bars of the Plugins folder's Windows Explorer window that's a sure sign...
          Fix the Security to FULL [you need to be an Admin to do that [set it in Users control-panel if not]].
          Then install the Lib and any other things you find in the VirtualStore...
          Alternatively... if you think you have installed the Lib and it is in the Plugins folder... then how did you do it - if you did it manually did you keep the files in their subfolders etc - not doing so is a recipe for disaster !
          I recommend you use the RBZ Preferences > Extensions > Install... button installer, or use the PluginStore dialog's AutoInstaller... 😕
            rv1974
            Fredo, I have errors in calculations. What Am I Doing Wrong?
            fredo_topo.skp
            Ruby Error - CALCULATING TERRAINS - 14-Jan-14 14_01_18.txt
              rv1974
              • fredo6F Offline
                fredo6
                NEW RELEASE: LibFredo6 v5.5g - 24 Jan 14
                LibFredo6 5.5g is a release for EdgeInspector 1.0, which is just published as part of FredTools 1.6g.
                See main post of this thread for Download.
                Fredo
                • OxerO Offline
                  Oxer
                  Thanks Fredo for this update and new tool !! 👍
                  I have updated the Spanish Language (Spain).
                  Spanish Language (Spain) v5.5g
                  http://www.oxervision.blogspot.com/
                  • fredo6F Offline
                    fredo6
                    Oxer,
                    Thanks very much. Will go in next release
                    Fred
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: LibFredo6 v5.6a - 03 Feb 14
                      LibFredo6 5.6a is a release for fixing bugs in Curvizard, for the Make Curve tools
                      There is also a (limited) support for Retina screens. The parameter can be set in the Default Parameters dialog box of LibFredo6. When set, the size of the button palettes, visual progress bars and some custom tooltips is enlarged by a factor 2. However, the font size is not changed (not possible from Ruby). So you may obtain an acceptable result or keep tiny fonts.
                      Fredo
                      • jeff hammondJ Offline
                        jeff hammond
                        hey Fredo,
                        not sure which thread to post this but this one seems ok 😉
                        some of your toolbars aren't showing tooltips per icon.. i don't have all of your plugins installed but with the ones i do, the following names show as the tooltip for every icon in their respective toolbar:
                        Curviloft
                        RoundCorner
                        FredoScale
                        two of them are showing each icon tooltip properly:
                        JointPushPull (the new one)
                        BezierSpline
                        (not sure about fredotools and curvizard as i use the single button toolbar for those)
                        dotdotdot
                        • F Offline
                          fboth
                          **Dear Fredo
                          I have Sketchup 2013. I installed your fredo 6 and reound corner and I get Error message
                          erfordert Sketchup Version höher als 5.0.160 Aktuerlle Version ist 13.0.4813
                          Please help me
                          Franz**
                          • fredo6F Offline
                            fredo6
                            @fboth said:
                            **Dear Fredo
                            Please help me
                            Franz**
                            It looks like you have an old version of LibFredo6 and RoundCorner.
                            Please upgrade to latest ones.
                            Ideally, use the Sketchucation PluginStore tool to install the plugins.
                            Fredo
                              roshinimohan
                              how do i go about it for mac os
                                Go about what? What is "it"?
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: LibFredo6 v5.7a - 15 Feb 14
                                  LibFredo6 5.7a is a release for EdgeInspector 1.1, which is part of FredoTools 1.7a
                                  See main post of this thread for Download of LibFredo6.
                                  Fredo
                                  • F Offline
                                    fboth
                                    Thank you Fredo,
                                    yes it works now!!
                                    I got another Problem, when I round the Corners of a cube, I get holes in the Corners, how to avoid this? And if I select one Corner after the other, as I do not want to round all Corners of the case, I get sometimes holes sometimes there is some material left I mean the rounding does not go around the new round Corner in the Corner.
                                    • cottyC Offline
                                      cotty
                                      @fboth said:
                                      Thank you Fredo,
                                      yes it works now!!
                                      If the faces are too small, they are not created. You can try to scale your model up (100x, 1000x) before you use the plugin.
                                      my SketchUp gallery
                                      • guanjinG Offline
                                        guanjin
                                        Check the update click to view is invalid
                                        I come from China, is to learn
                                        • guanjinG Offline
                                          guanjin
                                          Selection boxes have become such a big,sketchup8 and 2013 are so。
                                          5.6 and 5.7 are like this, 5.4 no problem 。
                                          • U Offline
                                            unclex
                                            Error Loading File Fredo6_!LibFredo6.rb
                                            Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb:689:in []' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb:689:in list_log_files'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb:708:in purge' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:224:in after_startup'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:184:in startup' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:299:in module:LibFredo6'
                                            C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
                                            2014 Just Like This
                                            2013 OK
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 112
                                            • 113
                                            • 36 / 113
