    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
      detcharles
      What Should I do to fix it?
      • K Offline
        KevB
        can somebody tell me where you put the shared library file ie the round corners
        Kevin
          Kevin
          Go to the first post of the thread and read it. It tells you where to put the files. Why don't you install the Sketchucation Plugin Store? Then you can just let it auto install your plugins.
            detcharles
            Hello,
            I am reposting from earlier concerning a problem with the way the text is displayed in joint push pull. I included a photo [see attached].
            Fredo mentioned its an issue with Open GL text sizing. Does anyone know how to adjust that?
            Thank You
            I am running SU8 PRO on a Macbook Pro Retina, OS Maverick
            • fredo6F Offline
              fredo6
              NEW RELEASE: LibFredo6 v5.4a - 07 Nov 13
              LibFredo6 5.4a is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
              Note: I will re-release all my scripts in the coming days, hopefully based on LibFredo6 5.4
              See main post of this thread for Download.
              Fredo
              • guanjinG Offline
                guanjin
                Fredo
                I installed Fredo6_% 21LibFredo6 - v5.4a, tips or display version 5.3, you need 5.4
                guanjin
                I come from China, is to learn
                • OxerO Offline
                  Oxer
                  For me the same when I run SU.
                  http://www.oxervision.blogspot.com/
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: LibFredo6 v5.4b - 08 Nov 13
                    Note: LibFredo6 5.4a was an incorrect release on the forum (it was OK on Plugin Store). So please move to 5.4b for avoidance of doubt
                    LibFredo6 5.4b is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
                    Fredo
                    • guanjinG Offline
                      guanjin
                      Fredo
                      Thank updates, operating normally, thank you!
                        Merdox
                        thaaaankss
                          Aldob
                          Hi Fredo,
                          Thanks for you awsome plugin. However I have difficulties install it to alternative file location using additional plugin folder. I installed latest version library and plugins from plugin store and when launch SketchUP I have messages about errors and have no plugins in sketchup after opening. The only I have BZ_toolbar with no icones on it. I'd be appreciate if you could help me to solve a problem.
                          error message
                          Error Loading File C.txt
                            metamachine
                            first off, a massive thank you for your hard work.
                            I have recently upgraded to 2013 but the installation of fredocore has been less than smooth for me . I have installed it via the extension warehouse but run into this error in my ruby console|
                            rror; #<NoMethodError; undefined method `each' for nil;NilClass>
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `get'
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;154;in `[]'
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;667;in `load_second_phase_rubies'
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Plugin.rb;124;in `launch_action'
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/bootstrap_FredoScale.rb;381;in `launch_action_p'
                            /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_FredoScale/bootstrap_FredoScale.rb;322;in `configure'
                            /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `call'
                            /Users/DJ/Library/Application Support/SketchUp 2013/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb;1111;in `build_config_handlers'
                            /Library/Application Support/SketchUp 2013/SketchUp/Plugins/Lib6Core.rb;191;in `call'
                            In this instance i tried to use the box scaling but nothing happens or shows. Ive done a ton of googling but I have not seen a similar error message. I hope anyone can help me
                            thnx,
                            -D
                              @metamachine
                              Please add your OS and SketchUp version to your SketchUcation User profile...
                              And then expand their details in a post as needed...
                              That will often help us understand your issues more readily...
                              I guess you are on a MAC with v2013 [Make?]...
                              Have you restarted SketchUp after the updates - some of Fredo's tools require this to complete the changes...*
                              Have you installed the very latest versions of the Lib itself AND each of the Tools.
                              Many have been updated to suit v2013 and so they cannot be 'copied over' from your v8 folders.
                              All of the latest Lib and Tool files should be available at the EW... OR they are download-able as RBZ archives from the easy to use SketchUcation PluginStore page [these can then be installed from the SketchUp > Preferences > Extensions > Install... button in v8/v2013], or using SketchUcation's Plugin Store dialog from within SketchUp itself, which AutoInstalls etc...*
                                metamachine
                                Yea, i should have added my profile and system specs.
                                Anyway, Im running a retina macbook pro late 2013 osx mavericks and sketchup 13. I have installed the plugins via the EW so I have no idea what is going on exactly. I have noticed this mavericks update is very picky with granting apps and software permission to write etc. to the point of claiming the software "is broken and should me moved to thrash" if it comes from a source apple does not recognise.
                                Yesterday i died a complete reinstall of sketchup 2013 but to no avail. I guess Ill have to mess about a bit more
                                -D
                                  metamachine
                                  fixed!
                                  so apparently having the plugins in both user/library/sketchup/plugins and hd/library/sketchup/plugins causes a conflict and stops the extension from working. after some hours of frustration I can finally work again.
                                  thank you again
                                  -D
                                    Please do update your profile, then.
                                      Why did you put the file in the alternate Plugins folder ? ๐Ÿ˜’
                                      • E Offline
                                        emash
                                        Please help me, my interface is resetting each time i start sketchup. Plugin buttons using fredo are all gone each start, P.S. Mac OS, sketchup pro 8
                                          jimbob99
                                          rhino > sketchup... too many plugins and downloads for tools that should already been implented into the original program.
                                          • cottyC Offline
                                            cotty
                                            And you think this belongs into this topic because ...? ๐Ÿ˜•
                                            my SketchUp gallery
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 112
                                            • 113
                                            • 35 / 113
