    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • W
      wriopomba
      v8.4g didn't work on my computer 😞. I would like to try a old version but i don't find it to donwload.
      • fredo6F
        fredo6
        It would be useful to know what 'does not work'.
        Fredo
        • G
          GHira
          Hello,
          V8.4g didn't work well in my pc too.
          My sketchup versions are 2018pro and 2014pro, and both of them don't work well.
          This is error message. Sorry for two-byte text for I use Japanese version....
          First line is just noticing error.
          Fredo6_!LibFredo6.rbファイルをロード中にエラー発生
          Error: #<ArgumentError: invalid byte sequence in UTF-8>
          c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
          c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
          C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
          C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
          I wondered that this occurs because of my two-bite code user dir name(which automatically named when I installed win10),
          but when I use older version libFredo, This problem didn't occur.
          Does this helps you?
          • G
            GHira
            By way of experiment, I made new windows user named alphabetical, and I newlly installed libfredo. then my probrem on this plugin was solved, It seems to be work well.
            Sorry for my impatience and Thanks for wonderfull plugin...
            • fredo6F
              fredo6
              @GHira,
              Definitely the error comes from your 2-bytes Windows username.
              Your profile indicates that you use Sketchup 2014. Is that correct?
              If so, then I suggest you move to Sketchup Make 2017 or Sketchup Pro 2018, which have a better support of Unicode in Ruby.
              Fredo
              • fredo6F
                fredo6
                @guz said:
                I'm having a similar issue with Curviloft (see attached image).
                I don't find the attached image.
                Fredo
                • guzG
                  guz
                  Perhaps there is a conflict with VRay? Was trying to troubleshoot why my toolbars wouldn't save their position. Ended up uninstalling / reinstalling plug-ins and received the Curviloft 1.7d: Error starting up plugin (creating menus and icons) error as well as a "lib6core.rbe:1058:in 'rescue in block in effective_load_part2" error.
                  -guz
                  Sorry, I just realized that the max size for an image is 2MB and 1600 px. I resized it here.
                  • guzG
                    guz
                    Apologies for that. I didn't read the image limitations when I made my attachment. It is fixed now.
                    • fredo6F
                      fredo6
                      NEW RELEASE: LibFredo6 v8.5a - 13 Jul 18
                      LibFredo6 8.5a is for Animator 2.2a and bug fixing
                      See plugin home page of LibFredo6 for Download of LibFredo6.
                      Main Post of the LibFredo6 thread
                      Fredo
                      • P
                        penumbra
                        by process of elimination i discovered today that Fredo6 plugins are making my SU 2017 Pro run very very slow at satrtup and when i invoke the toolbards dialog box. I disabled all my plugins to find that sketchup ran fine. i enabled Fredo 6 lpugins again and slowness occurs again. I ahve udpated to latest version of all Fredo 6 plugins but have found the probelm persists.
                        windows 7 64 bit syste 32GB ram
                        Video Card Nvidia quadro M1000M
                        Edit: perhaps not, also disabled Vray and find better performance.
                        • fredo6F
                          fredo6
                          @penumbra
                          You have a performance menu entry showing the time to load for my plugins. I am interested by the result.
                          Is the slowness only for the startup time, and/or after when you model in Sketchup. Do you observe a lag after you see all toolbars displayed?
                          Fredo
                          • fredo6F
                            fredo6
                            NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
                            LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
                            Fredo
                            • T
                              thaissoares
                              Hello, I'm having trouble installing LibFredo6, the error message appears:
                              Erro ao carregar o arquivo Fredo6_!LibFredo6.rb
                              c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                              c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                              C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                              C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erro ao carregar o arquivo Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                              C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                              C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                              C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in <top (required)>' Erro ao carregar o arquivo Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                              C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                              C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                              It does not open in the window bar, but old versions work.
                              I use Windows 8 and SketchUp Pro 2017.
                              • TIGT
                                The accented "i" in your [Portuguese ?] Windows user name [ tha**í**s] is almost certainly causing the issue.
                                Accented characters broke many scripts, until the newer versions of SketchUp got an updated Ruby installation, with extra tools available to try and circumvent such problems...
                                However, Fredo's tools have for a long time forced file-path encoding etc into UTF-8 format...
                                So I am surprised that this issue has occurred, let's wait for Fredo's comments...
                                • fredo6F
                                  fredo6
                                  NEW RELEASE: LibFredo6 v8.5c - 31 Jul 18
                                  LibFredo6 8.5c fixes issues with non-ascii Windows usernames
                                  Fredo
                                  • fredo6F
                                    fredo6
                                    NEW RELEASE: LibFredo6 v8.5f - 14 Aug 18
                                    LibFredo6 8.5f increases the timeout for rendering in Vray from Animator. It also fixes other bugs.
                                    Fredo
                                    • H
                                      Helle
                                      SU 8 free. Updating I get this:
                                      Error Loading File Fredo6_!LibFredo6.rb
                                      undefined method `startup' for LibFredo6:ModuleError Loading File Fredo6_FredoScale.rb
                                      no implicit conversion to float from nilError Loading File Fredo6_RoundCorner.rb
                                      aiiii, what's wrong please, please help
                                      regards Helle
                                      • jujuJ
                                        juju
                                        regards Helle
                                        Fredo6 is upgrading his extensions, support for some older versions of SU are being deprecated to facilitate compatibility with newer coding. SU8 would definitely be on the list of no longer supported SU versions.
                                        • H
                                          Helle
                                          oh, what a shame. I read it as "pre-8" and thought I could use it. Thanks for the fast reply
                                          • cam_lC
                                            cam_l
                                            any chance someone has a copy of the last pre-su8-deprecated version of libfredo? not even sure which version that would be..
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 116
                                            • 117
                                            • 67 / 117
