    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      jjbrown
      hi, ive tried to install libfredo6 a million times with no luck ,,, the Sketchup Extension Manager just keeps saying loading an dose nothing ... im running OSX 10.13.3n
      PLEASE HELP
        jjbrown
        @jjbrown said:
        Hi everyone. I am new to Fredo. I have been trying to load this all day with no luck. I am running SU on Mac iOS 10.11.06 it downloads finn in my browser but then trys to open in the extension warehouse an just gets stuck ... says ' loading ' an dose nothing. ive eeven tried loading it to SU 2017 with the same result ... PLEASE HELP 😞
        HI, IM HAVING THE SAME ISSUE ,,, DID YIOU RESOLVE THE ISSE ??? ANY ADVICE WOULD BE MUCH HELP AN appreciated 😄
        • fredo6F
          @jjbrown,
          Where did you get the RBZ from for LibFredo6 ?
            Get the Lib from here: https://sketchucation.com/pluginstore?pln=LibFredo6
            Then install it using the SketchUp > Window > Extension Manager dialog "Install Extension" red-button...
            Also ensure that the installed extensions show as 'enabled' in the dialog.
            Unless you have your Extension Manager's Loading-policy set to 'Unrestricted' you might have issues with older extensions - however, because Fredo's tools are up to date and properly 'signed' that should NOT be an issue... but perhaps try that just in case ?
            Remember that the Lib on its own does little, but it vitally supports many of Fredo's other extensions.
            Also after its installation [and those of any related extensions], then please close SketchUp and restart it to ensure that the Lib and its related extensions get fully registered and synced.
              jjbrown
              @fredo6 said:
              @jjbrown,
              i got everything from here ... sketchUcation
                jjbrown
                THIS WORKED .... THANK YOU !!!
                • T
                  thasimakis
                  Hello all
                  I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
                  Any ideas?
                  • fredo6F
                    LibFredo6, which is simply a shared library, does not have any toolbar and does not do anything alone.
                    You need to install another of my plugins (like RoundCorner, FredoScale, ...) to see a toolbar for these plugins.
                    • W
                      wriopomba
                      v8.4g didn't work on my computer 😞. I would like to try a old version but i don't find it to donwload.
                      • fredo6F
                        It would be useful to know what 'does not work'.
                        • G
                          GHira
                          Hello,
                          V8.4g didn't work well in my pc too.
                          My sketchup versions are 2018pro and 2014pro, and both of them don't work well.
                          This is error message. Sorry for two-byte text for I use Japanese version....
                          First line is just noticing error.
                          Fredo6_!LibFredo6.rbファイルをロード中にエラー発生
                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                          c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                          c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                          C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                          C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                          I wondered that this occurs because of my two-bite code user dir name(which automatically named when I installed win10),
                          but when I use older version libFredo, This problem didn't occur.
                          Does this helps you?
                          • G
                            GHira
                            By way of experiment, I made new windows user named alphabetical, and I newlly installed libfredo. then my probrem on this plugin was solved, It seems to be work well.
                            Sorry for my impatience and Thanks for wonderfull plugin...
                            • fredo6F
                              @GHira,
                              Definitely the error comes from your 2-bytes Windows username.
                              Your profile indicates that you use Sketchup 2014. Is that correct?
                              If so, then I suggest you move to Sketchup Make 2017 or Sketchup Pro 2018, which have a better support of Unicode in Ruby.
                              • fredo6F
                                @guz said:
                                I'm having a similar issue with Curviloft (see attached image).
                                I don't find the attached image.
                                • guzG
                                  guz
                                  Perhaps there is a conflict with VRay? Was trying to troubleshoot why my toolbars wouldn't save their position. Ended up uninstalling / reinstalling plug-ins and received the Curviloft 1.7d: Error starting up plugin (creating menus and icons) error as well as a "lib6core.rbe:1058:in 'rescue in block in effective_load_part2" error.
                                  -guz
                                  Sorry, I just realized that the max size for an image is 2MB and 1600 px. I resized it here.
                                  • guzG
                                    guz
                                    Apologies for that. I didn't read the image limitations when I made my attachment. It is fixed now.
                                    • fredo6F
                                      NEW RELEASE: LibFredo6 v8.5a - 13 Jul 18
                                      LibFredo6 8.5a is for Animator 2.2a and bug fixing
                                      • P
                                        penumbra
                                        by process of elimination i discovered today that Fredo6 plugins are making my SU 2017 Pro run very very slow at satrtup and when i invoke the toolbards dialog box. I disabled all my plugins to find that sketchup ran fine. i enabled Fredo 6 lpugins again and slowness occurs again. I ahve udpated to latest version of all Fredo 6 plugins but have found the probelm persists.
                                        windows 7 64 bit syste 32GB ram
                                        Video Card Nvidia quadro M1000M
                                        Edit: perhaps not, also disabled Vray and find better performance.
                                        • fredo6F
                                          @penumbra
                                          You have a performance menu entry showing the time to load for my plugins. I am interested by the result.
                                          Is the slowness only for the startup time, and/or after when you model in Sketchup. Do you observe a lag after you see all toolbars displayed?
                                          • fredo6F
                                            NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
                                            LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 115
                                            • 116
                                            • 67 / 116
