    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.6m Views 580 Watching
      thasimakis
      Hello all
      I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
      Any ideas?
      • fredo6F Offline
        LibFredo6, which is simply a shared library, does not have any toolbar and does not do anything alone.
        You need to install another of my plugins (like RoundCorner, FredoScale, ...) to see a toolbar for these plugins.
        • W Offline
          wriopomba
          v8.4g didn't work on my computer 😞. I would like to try a old version but i don't find it to donwload.
          • fredo6F Offline
            It would be useful to know what 'does not work'.
              GHira
              Hello,
              V8.4g didn't work well in my pc too.
              My sketchup versions are 2018pro and 2014pro, and both of them don't work well.
              This is error message. Sorry for two-byte text for I use Japanese version....
              First line is just noticing error.
              Fredo6_!LibFredo6.rbファイルをロード中にエラー発生
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
              c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
              C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
              C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
              I wondered that this occurs because of my two-bite code user dir name(which automatically named when I installed win10),
              but when I use older version libFredo, This problem didn't occur.
              Does this helps you?
                GHira
                By way of experiment, I made new windows user named alphabetical, and I newlly installed libfredo. then my probrem on this plugin was solved, It seems to be work well.
                Sorry for my impatience and Thanks for wonderfull plugin...
                • fredo6F Offline
                  @GHira,
                  Definitely the error comes from your 2-bytes Windows username.
                  Your profile indicates that you use Sketchup 2014. Is that correct?
                  If so, then I suggest you move to Sketchup Make 2017 or Sketchup Pro 2018, which have a better support of Unicode in Ruby.
                  • fredo6F Offline
                    @guz said:
                    I'm having a similar issue with Curviloft (see attached image).
                    I don't find the attached image.
                    • guzG Offline
                      guz
                      Perhaps there is a conflict with VRay? Was trying to troubleshoot why my toolbars wouldn't save their position. Ended up uninstalling / reinstalling plug-ins and received the Curviloft 1.7d: Error starting up plugin (creating menus and icons) error as well as a "lib6core.rbe:1058:in 'rescue in block in effective_load_part2" error.
                      -guz
                      Sorry, I just realized that the max size for an image is 2MB and 1600 px. I resized it here.
                      • guzG Offline
                        guz
                        Apologies for that. I didn't read the image limitations when I made my attachment. It is fixed now.
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v8.5a - 13 Jul 18
                          LibFredo6 8.5a is for Animator 2.2a and bug fixing
                            penumbra
                            by process of elimination i discovered today that Fredo6 plugins are making my SU 2017 Pro run very very slow at satrtup and when i invoke the toolbards dialog box. I disabled all my plugins to find that sketchup ran fine. i enabled Fredo 6 lpugins again and slowness occurs again. I ahve udpated to latest version of all Fredo 6 plugins but have found the probelm persists.
                            windows 7 64 bit syste 32GB ram
                            Video Card Nvidia quadro M1000M
                            Edit: perhaps not, also disabled Vray and find better performance.
                            • fredo6F Offline
                              @penumbra
                              You have a performance menu entry showing the time to load for my plugins. I am interested by the result.
                              Is the slowness only for the startup time, and/or after when you model in Sketchup. Do you observe a lag after you see all toolbars displayed?
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
                                LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
                                  thaissoares
                                  Hello, I'm having trouble installing LibFredo6, the error message appears:
                                  Erro ao carregar o arquivo Fredo6_!LibFredo6.rb
                                  c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                                  c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                                  C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                                  C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erro ao carregar o arquivo Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                  C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                                  C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
                                  C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in <top (required)>' Erro ao carregar o arquivo Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                                  C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                                  C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                                  It does not open in the window bar, but old versions work.
                                  I use Windows 8 and SketchUp Pro 2017.
                                    The accented "i" in your [Portuguese ?] Windows user name [ tha**í**s] is almost certainly causing the issue.
                                    Accented characters broke many scripts, until the newer versions of SketchUp got an updated Ruby installation, with extra tools available to try and circumvent such problems...
                                    However, Fredo's tools have for a long time forced file-path encoding etc into UTF-8 format...
                                    So I am surprised that this issue has occurred, let's wait for Fredo's comments...
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.5c - 31 Jul 18
                                      LibFredo6 8.5c fixes issues with non-ascii Windows usernames
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v8.5f - 14 Aug 18
                                        LibFredo6 8.5f increases the timeout for rendering in Vray from Animator. It also fixes other bugs.
                                        • H Offline
                                          Helle
                                          SU 8 free. Updating I get this:
                                          Error Loading File Fredo6_!LibFredo6.rb
                                          undefined method `startup' for LibFredo6:ModuleError Loading File Fredo6_FredoScale.rb
                                          no implicit conversion to float from nilError Loading File Fredo6_RoundCorner.rb
                                          aiiii, what's wrong please, please help
                                          regards Helle
                                          • jujuJ Offline
                                            juju
                                            regards Helle
                                            Fredo6 is upgrading his extensions, support for some older versions of SU are being deprecated to facilitate compatibility with newer coding. SU8 would definitely be on the list of no longer supported SU versions.
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 111
                                            • 112
                                            • 67 / 112
