    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • fredo6F
      fredo6
      @RubenB
      Thanks for signaling. This is a small bug in the periodic popup prompting for a Check for Update.
      This is fixed in v8.4d, just published.
      Fredo
      • P
        peuluang
        I use Sketchup 2017.
        Why LibFredo6 not work.
          What makes you think it doesn't work?
          • fredo6F
            fredo6
            NEW RELEASE: LibFredo6 v8.4e - 28 May 18
            LibFredo6 8.4e fixes a bug related to text selection in some web dialog boxes
            See plugin home page of LibFredo6 for Download of LibFredo6.
            Main Post of the LibFredo6 thread
            Fredo
            • B
              bharralure
              Merci Fredo
              La version v8.4e de Lib Fredo6 corrige effectivement les petits problèmes rencontrés lors de la sélection de texte des outils "volumes Solides" et "Étiqueter les surfaces".
              • K
                kejtrin
                Hi Fredo, please, how to install LibFredo to a different folder? I have installed the AdditionalPluginFolder, created another folder for plugins, but a guess I need .zip file to install LibFredo6 to that folder. I can see only .rbz file in download and I don't know, how to change destination plugin folder in Sketchup 2018 extention manager. Thanx for help!
                • fredo6F
                  fredo6
                  NEW RELEASE: LibFredo6 v8.4f - 29 May 18
                  LibFredo6 8.4f fixes a bug that prevented to launch the video generation in Animator
                  Fredo
                  • fredo6F
                    fredo6
                    Unfortunately the native Extension Manager of Sketchup does not propose alternate directories.
                    The Sketchucation PluginStore does and should be the solution for your configuration.
                    Otherwise, you have to rename the rbz as .zip, and then extract the file and folder manually in the alternate directory.
                    Fredo
                    • G
                      gaetane74
                      Hi Fredo, ou Bonjour Fredo
                      Depuis que j'ai réinstaller Sketchup je ne peux plus installer tes plugins… j'ai ce message à l'ouverture
                      Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                      c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in match' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block (2 levels) in load_from_config'
                      c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in each' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in block in load_from_config'
                      c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in foreach' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in load_from_config'
                      c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in block in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in each'
                      c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:245:in startup'
                      C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                      C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                      C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                      C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Erreur de chargement du fichier Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                      C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                      C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                      Merci de ton aide
                      • fredo6F
                        fredo6
                        Merci de ton aide
                        The best would be to clean up and reinstall LibFredo6.
                        Fredo
                        • J
                          jjbrown
                          Hi everyone. I am new to Fredo. I have been trying to load this all day with no luck. I am running SU on Mac iOS 10.11.06 it downloads finn in my browser but then trys to open in the extension warehouse an just gets stuck ... says ' loading ' an dose nothing. ive eeven tried loading it to SU 2017 with the same result ... PLEASE HELP 😞
                          • fredo6F
                            fredo6
                            NEW RELEASE: LibFredo6 v8.4g - 10 Jun 18
                            LibFredo6 8.4g fixes a bug that prevented to locate the program FFmpeg in Animator
                            Fredo
                            • J
                              jjbrown
                              hi, ive tried to install libfredo6 a million times with no luck ,,, the Sketchup Extension Manager just keeps saying loading an dose nothing ... im running OSX 10.13.3n
                              PLEASE HELP
                              • J
                                jjbrown
                                HI, IM HAVING THE SAME ISSUE ,,, DID YIOU RESOLVE THE ISSE ??? ANY ADVICE WOULD BE MUCH HELP AN appreciated 😄
                                • fredo6F
                                  fredo6
                                  @jjbrown,
                                  Where did you get the RBZ from for LibFredo6 ?
                                  Fredo
                                  • TIGT
                                    Get the Lib from here: https://sketchucation.com/pluginstore?pln=LibFredo6
                                    Then install it using the SketchUp > Window > Extension Manager dialog "Install Extension" red-button...
                                    Also ensure that the installed extensions show as 'enabled' in the dialog.
                                    Unless you have your Extension Manager's Loading-policy set to 'Unrestricted' you might have issues with older extensions - however, because Fredo's tools are up to date and properly 'signed' that should NOT be an issue... but perhaps try that just in case ?
                                    Remember that the Lib on its own does little, but it vitally supports many of Fredo's other extensions.
                                    Also after its installation [and those of any related extensions], then please close SketchUp and restart it to ensure that the Lib and its related extensions get fully registered and synced.
                                    • J
                                      jjbrown
                                      @fredo6 said:
                                      @jjbrown,
                                      Fredo
                                      i got everything from here ... sketchUcation
                                      • J
                                        jjbrown
                                        THIS WORKED .... THANK YOU !!!
                                        • T
                                          thasimakis
                                          Hello all
                                          I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
                                          Any ideas?
                                          • fredo6F
                                            fredo6
                                            LibFredo6, which is simply a shared library, does not have any toolbar and does not do anything alone.
                                            You need to install another of my plugins (like RoundCorner, FredoScale, ...) to see a toolbar for these plugins.
                                            Fredo
