    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
      @peuluang said:
      I use Sketchup 2017.
      Why LibFredo6 not work.
      What makes you think it doesn't work?
      • fredo6F
        NEW RELEASE: LibFredo6 v8.4e - 28 May 18
        LibFredo6 8.4e fixes a bug related to text selection in some web dialog boxes
        • B
          bharralure
          Merci Fredo
          La version v8.4e de Lib Fredo6 corrige effectivement les petits problèmes rencontrés lors de la sélection de texte des outils "volumes Solides" et "Étiqueter les surfaces".
          • K
            kejtrin
            Hi Fredo, please, how to install LibFredo to a different folder? I have installed the AdditionalPluginFolder, created another folder for plugins, but a guess I need .zip file to install LibFredo6 to that folder. I can see only .rbz file in download and I don't know, how to change destination plugin folder in Sketchup 2018 extention manager. Thanx for help!
            • fredo6F
              NEW RELEASE: LibFredo6 v8.4f - 29 May 18
              LibFredo6 8.4f fixes a bug that prevented to launch the video generation in Animator
              • fredo6F
                Unfortunately the native Extension Manager of Sketchup does not propose alternate directories.
                The Sketchucation PluginStore does and should be the solution for your configuration.
                Otherwise, you have to rename the rbz as .zip, and then extract the file and folder manually in the alternate directory.
                • G
                  gaetane74
                  Hi Fredo, ou Bonjour Fredo
                  Depuis que j'ai réinstaller Sketchup je ne peux plus installer tes plugins… j'ai ce message à l'ouverture
                  Erreur de chargement du fichier Fredo6_!LibFredo6.rb
                  Error: #<ArgumentError: invalid byte sequence in UTF-8>
                  c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in match' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in block (2 levels) in load_from_config'
                  c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in each' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:804:in block in load_from_config'
                  c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in foreach' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:802:in load_from_config'
                  c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in block in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in each'
                  c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1216:in load_all_plugins' c:/users/julie/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:245:in startup'
                  C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                  C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erreur de chargement du fichier Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                  C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                  C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                  C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Erreur de chargement du fichier Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                  C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
                  C:/Users/Julie/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
                  Merci de ton aide
                  • fredo6F
                    Merci de ton aide
                    The best would be to clean up and reinstall LibFredo6.
                      jjbrown
                      Hi everyone. I am new to Fredo. I have been trying to load this all day with no luck. I am running SU on Mac iOS 10.11.06 it downloads finn in my browser but then trys to open in the extension warehouse an just gets stuck ... says ' loading ' an dose nothing. ive eeven tried loading it to SU 2017 with the same result ... PLEASE HELP 😞
                      • fredo6F
                        NEW RELEASE: LibFredo6 v8.4g - 10 Jun 18
                        LibFredo6 8.4g fixes a bug that prevented to locate the program FFmpeg in Animator
                          jjbrown
                          hi, ive tried to install libfredo6 a million times with no luck ,,, the Sketchup Extension Manager just keeps saying loading an dose nothing ... im running OSX 10.13.3n
                          PLEASE HELP
                            jjbrown
                            HI, IM HAVING THE SAME ISSUE ,,, DID YIOU RESOLVE THE ISSE ??? ANY ADVICE WOULD BE MUCH HELP AN appreciated 😄
                            • fredo6F
                              @jjbrown,
                              Where did you get the RBZ from for LibFredo6 ?
                                Get the Lib from here: https://sketchucation.com/pluginstore?pln=LibFredo6
                                Then install it using the SketchUp > Window > Extension Manager dialog "Install Extension" red-button...
                                Also ensure that the installed extensions show as 'enabled' in the dialog.
                                Unless you have your Extension Manager's Loading-policy set to 'Unrestricted' you might have issues with older extensions - however, because Fredo's tools are up to date and properly 'signed' that should NOT be an issue... but perhaps try that just in case ?
                                Remember that the Lib on its own does little, but it vitally supports many of Fredo's other extensions.
                                Also after its installation [and those of any related extensions], then please close SketchUp and restart it to ensure that the Lib and its related extensions get fully registered and synced.
                                  jjbrown
                                  @fredo6 said:
                                  @jjbrown,
                                  i got everything from here ... sketchUcation
                                    jjbrown
                                    THIS WORKED .... THANK YOU !!!
                                    • T
                                      thasimakis
                                      Hello all
                                      I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
                                      Any ideas?
                                      • fredo6F
                                        LibFredo6, which is simply a shared library, does not have any toolbar and does not do anything alone.
                                        You need to install another of my plugins (like RoundCorner, FredoScale, ...) to see a toolbar for these plugins.
                                        • W
                                          wriopomba
                                          v8.4g didn't work on my computer 😞. I would like to try a old version but i don't find it to donwload.
                                          • fredo6F
                                            It would be useful to know what 'does not work'.
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 112
                                            • 113
                                            • 66 / 113
