    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • fredo6F
      fredo6
      @ben ritter said:
      The download link does not work for me for either one of the plugins.
      Which download link? I only publish via the SCF PLugin Store.
      Fredo
      • B
        Ben Ritter
        Fredo
        OK, thanks. I just thought the yellow "Download" button in your post downloaded the .rb files on some of your other plugins.
        Thanks again for sharing.
        • E
          eozel
          As you said, i installed fredotools. It said that "selected extension has been succesfully installed...". When i open skecthup software again it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.).
          Thanks four your supports.
          • fredo6F
            fredo6
            Do you see the menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a.
            At least this shows that LibFredo6 is correctly installed
            Maybe a snapshot of your Plugin directory would also help.
            Fredo
            • E
              eozel
              Fredo
              I see menu Windows > LibFredo6 Settings after installing LibFredo6 6.2a. But after i install extensions like curviloft, roundcornet, it give error msg ""you must install Libfredo 6 version 5.2..". I installed fredotools too as you said me, it doesnt give an error for "you must install Libfredo 6 version 5.2..." but fredotools doesnt seen anywhere (tools menu, etc.
              thanks.
                I've seen the same sort of message in the past. The solution that worked for me was to go to the Plugins folder and delete the LibFredo6 files including the folders. Then reinstall the fresh version from the Pluginstore.
                Evidently, some file wasn't getting overwritten when the newer version was installed over the old.
                • E
                  eozel
                  Thanks but I try to it more than 2 times, additionally i uninstalled sketchup and delete all files related with it. My problem comes from asci chracter of computer username. With new update of libfredo 6, libfredo 6 settings has been seen under windows menu. But plugings gives error whicg i said before msg.
                  Additionally, another computer of mine (which hasn't got asci chracter of username) which i use libfredo 6 and most of plugins. But when i install shapes pluging, it start to give load error msg:
                    Uninstalling and reinstalling sketchUp was an unneeded step.
                    As for the Shapes plugin, where did you get it?
                    • E
                      eozel
                      While other plugings works well for the shapes plugin, it gives load error msg another computer of mine when sketchup is opennig.
                        That didn't answer my question. 😒
                        Just forget I asked about it.
                        • E
                          eozel
                          404 Not Found
                          (sketchucation.com)
                          • fredo6F
                            fredo6
                            @eozel,
                            At the moment, only LibFredo6 and FredoTools has been corrected for the problem of non-ascii characters.
                            So are you sure you dont find it?
                            • the menu is under Tools > FredoTools
                            • there is a toolbar with a single icon showing F6
                            Fredo
                              404 Not Found
                              (sketchucation.com)
                              Try the version from the Extension Warehouse instead.
                              • E
                                eozel
                                @fredo6 said:
                                @eozel,
                                Fredo
                                There is no fredotools.
                                • fredo6F
                                  fredo6
                                  @eozel,
                                  Could you show a screenshort of the "check For Updates" of LibFredo6.
                                  Also, can you check the footprint of plugins in the SU Plugins directory where you installed.
                                  Fredo
                                  • E
                                    eozel
                                    @fredo6 said:
                                    @eozel,
                                    Fredo
                                    • fredo6F
                                      fredo6
                                      Eozel,
                                      Thanks. There is also a Trace log utility in the LibFredo6 menu.
                                      Could you check or send me the txt or a snapshot after expanding the list.
                                      Also the date of last check (1 Jan 1970) seems to have a problem. I have to check
                                      Fredo
                                      • E
                                        eozel
                                        @fredo6 said:
                                        Eozel,
                                        Fredo
                                        1413369931.22969;Fredo6_!LibFredo6.rb:71: in `log'
                                        DATE / TIME: 2014-10-15 13:45:31 +0300
                                        SKETCHUP VERSION: 14.1.1282
                                        RUBY_PLATFORM: i386-mingw32
                                        LOG FILE: LibFredo6Trace_14_1413369931228.txt
                                        1413369931.22969;Fredo6_!LibFredo6.rb:113: in `startup'
                                        LibFredo6: Starting up Fredo6_!LibFredo6.rb
                                        1413369931.319277;Fredo6_!LibFredo6.rb:265: in `dir_appdata'
                                        Temp Files directory: C:/Users/EMREZE~1/AppData/Local/Temp
                                        1413369931.351414;Fredo6_!LibFredo6.rb:266: in `dir_appdata'
                                        Default Parameters folder: C:/Users/EMREZE~1/AppData/Local/LIBFREDO6_DATA_Dir/DefaultParameters
                                        1413369931.385449;Fredo6_!LibFredo6.rb:173: in `startup'
                                        LibFredo6: Beginning of loading Cycle***+
                                        1413369931.4218082;Fredo6_!LibFredo6.rb:180: in `startup'
                                        LibFredo6 Core: Fredo6_!LibFredo6/Lib6Core.rb successfully loaded
                                        1413369931.5345228;Lib6Core.rb:992: in `load_full_rubies'
                                        LibFredo6 6.2a: Ruby files loaded [69 ms]
                                        1413369931.56119;Lib6Core.rb:921: in `effective_load_part2'
                                        LibFredo6 6.2a: Startup (creating menus and icons) [10 ms]
                                        1413369931.586445;Fredo6_!LibFredo6.rb:189: in `startup'
                                        LibFredo6: End of loading Cycle***-
                                        1413369938.4396129;Lib6Plugin.rb:150: in `load_body'
                                        Lib6PluginDialogs.rb: Loading body code from body_Lib6PluginDialogs.rb [33 ms]
                                        1413369938.539354;Lib6Core.rb:85: in `use_single_library'
                                        Lib6G6.rb: Loading body code from body_Lib6G6.rb [80 ms]
                                        1413369938.580538;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Translate.rb: Loading body code from body_Lib6Translate.rb [20 ms]
                                        1413369938.621686;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Spline.rb: Loading body code from body_Lib6Spline.rb [20 ms]
                                        1413369938.673656;Lib6Core.rb:85: in `use_single_library'
                                        Lib6WebHtml.rb: Loading body code from body_Lib6WebHtml.rb [30 ms]
                                        1413369938.770474;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Tool.rb: Loading body code from body_Lib6Tool.rb [77 ms]
                                        1413369938.835396;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Algo.rb: Loading body code from body_Lib6Algo.rb [40 ms]
                                        1413369938.882689;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Contour.rb: Loading body code from body_Lib6Contour.rb [23 ms]
                                        1413369938.916536;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Offset3d.rb: Loading body code from body_Lib6Offset3d.rb [15 ms]
                                        1413369938.9848142;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Transform.rb: Loading body code from body_Lib6Transform.rb [49 ms]
                                        1413369939.032744;Lib6Core.rb:85: in `use_single_library'
                                        Lib6Mark.rb: Loading body code from body_Lib6Mark.rb [22 ms]
                                        1413369939.0687091;Lib6Plugin.rb:150: in `load_body'
                                        Lib6WebJS.rb: Loading body code from body_Lib6WebJS.rb [17 ms]
                                        1413369939.1184819;Lib6Plugin.rb:150: in `load_body'
                                        Lib6WebWdlg.rb: Loading body code from body_Lib6WebWdlg.rb [25 ms]
                                        1413369939.164896;Lib6Plugin.rb:150: in `load_body'
                                        Lib6WebXTable.rb: Loading body code from body_Lib6WebXTable.rb [25 ms]
                                        • fredo6F
                                          fredo6
                                          Very strange.
                                          Could you do 2 things:
                                          1. Type the following commands in the RubyConsole and tell me the result
                                            LibFredo6.sudir
                                            LibFredo6.path
                                            LibFredo6.folder
                                            LibFredo6.appdata_dir
                                            LibFredo6.defparam_dir
                                            defined?(FredoTools)
                                          2. Remove the Fredo6_Fredotools.rb file (it is of no use actually, just for EWH compliance), exit and restart SU and see if you see FredoTools now
                                          Thanks and sorry for these problems. You support is helpful
                                          Fredo
                                          • E
                                            eozel
                                            @fredo6 said:
                                            Very strange.
                                              LibFredo6.sudir
                                              LibFredo6.path
                                              LibFredo6.folder
                                            Fredo
                                            LibFredo6.sudir
                                            C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                                            LibFredo6.path
                                            C:/Users/emre özel/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6
                                            LibFredo6.folder
                                            Fredo6_!LibFredo6
                                            nil
                                            1. I removed Fredo6_Fredotools.rb file, exited and restarted SU. But there is not fredotools.
                                            I think there is another problem on my pc or windows settings, etc.
                                            Thanks for your supports
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 116
                                            • 117
                                            • 43 / 117
