    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • G
      goyatea Newcomers
      • fredo6F
        fredo6
        Somethings is wrong is the installation of Sketchucation Tools.
        Could you
        1. go to the Plugin directory: c:/users/legai/appdata/roaming/sketchup/sketchup 2025/sketchup/plugins
        2. Delete the folder Sketchucation
        3. Reinstall Sketchucation tools from the Sketchucation site
        Please advise if this does not work.
        • G
          goyatea Newcomers
          Thanks, it's working now.
          First, I deleted it, then I modified the signature authorisation in the warehouse extension. It was a signature issue.
          In SketchUp:
          Extensions → Extension Manager
          Click the ⚙️ Extension Manager Settings icon.
          You'll find “Extension Loading Policy” / “Extension Loading Preferences.”
          Select:
          “Approve Unidentified Extensions”
          Restart SketchUp.
          • I
            ID3D
            Bonjour
            Avec la version 16.3b la fenêtre traduction n'apparait plus sur tout les plugins frtedo6
            fredo6F 1 Reply Last reply
            • fredo6F
              fredo6 @ID3D
              @ID3D
              which plugins for instance?
              • B
                Bublifuk21 @fredo6
                @fredo6 please find attached.
                Fredo6 Plugins Information on 2026-11-06 09:14:12 +0100
                • Platform: x64-mingw32 - Ruby: 2.2.4
                • Sketchup: 17.2.2555
                • LibFredo6: v16.1g
                • LibFredo6 G6 Binary loaded
                • LibFredo6 E6 Binary NOT loaded
                • Sketchucation Tools: 5.0.8
                • SCFLicense: v7.5a - 80
                • Fredo6 Plugins
                  Curviloft v2.0a - licensed FULL: 262837 - HE1772082497.0K
                  FredoScale v3.7c
                  JointPushPull v4.9a - licensed FULL: 263124 - HE1772082497.0K
                  RoundCorner v3.4a - licensed FULL: 263401 - HE1772082497.0K
                • SCFLicense directory present
                  Signature File: 2026-02-26 06:08:17 +0100
                  Curviloft: 2026-02-26 06:08:26 +0100
                  JointPushPull: 2026-02-26 10:15:01 +0100
                  RoundCorner: 2026-03-02 12:08:45 +0100
                • S
                  studioae
                  Hi, everyone. Running SU2027 on Mac. Have LibFredo6 installed. Installed several tools, including Curviloft. The menu bars appear, with clickable icons, but nothing happens when I click them.
                  I have restarted, rebooted, uninstalled, reinstalled, installed LibFredo6 first, checked for updates, etc. None of that makes any difference.
                  Any idea why? Thanks!
                  • S
                    studioae
                    Hi, all. I'm running SU2027. I have LibFredo6 installed. I had several Fredo extensions installed, but have backed it off just to Curviloft as I troubleshoot.
                    The toolbars are present, buttons are there, but when pressed they do nothing. I have uninstalled, reinstalled, rebooted, etc., and none of that has changed anything.
                    Any ideas? Thanks.
                    • fredo6F
                      fredo6 @studioae
                      @studioae
                      Could you open the Ruby console before launching a plugin. If there are error showing up, copy and paste the text here.
                      • S
                        studioae
                        Hi, Fredo.
                        Never mind! I found the problem. I just reinstalled Sketchucation Tools and voilà, everything came to life. Sorry about that!
                        • fredo6F
                          fredo6
                          NEW RELEASE: LibFredo6 v16.4a - 11 Nov 26
                          LibFredo6 16.4a is a maintenance release. It includes changes related to:
                          • Compatibility SU2027
                          • Technical adjustments
                          • Bug Fixing
                          If you use LordOfTheToolbars, please upgrade it to LordOfTheToolbars v4.2a. Otherwise, LOTT will not be activated
                          Requirements: SU2017 and above
                          See plugin home page of LibFredo6 for Download of LibFredo6.
                          Main Post of the LibFredo6 thread
                          • F
                            ferdsabatini
                            Hello! @fredo6 I’d like to know if there will be a bundle for the 2027 version soon. Thxx
                            • A
                              aprogon
                              Hi Fredo, hi everyone,
                              I have just installed SketchUp 2027 and I am unable to get LibFredo6 or any of the FredoBundle plugins to work.
                              I downloaded and installed the latest version of LibFredo6 (v16.4a) together with the latest versions of the FredoBundle plugins. The plugins are installed, the toolbars appear, but none of the tools work.
                              In SketchUp's Extension Manager, LibFredo6 appears with:
                              • Version: 1.0
                              • Author: (blank)
                              • Description: (blank)
                              I also get the following error:
                              NameError (uninitialized constant E6B)
                              For comparison, I am running the same plugins on SketchUp 2026 without any issues.
                              Has anyone experienced the same problem with SketchUp 2027?
                              Extension Errors Report
                              SketchUp: 27.0.267
                              OS: Windows 11
                              Ruby: 3.4.9
                              Extension: Fredo6 LibFredo6 (1.0)
                              Error: NameError (uninitialized constant E6B)
                              C:/Users/user/AppData/Local/Temp/Fredo6__loader_top_1794588161.rb:1:in '<top (required)>'
                              C:/Program Files/SketchUp/SketchUp 2027/SketchUp/Tools/extensions.rb:209:in 'Sketchup.require'
                              C:/Program Files/SketchUp/SketchUp 2027/SketchUp/Tools/extensions.rb:209:in 'SketchupExtension#load'
                              C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in 'Sketchup.register_extension'
                              C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:153:in 'LibFredo6_Loader.process'
                              C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:164:in 'module:LibFredo6_Loader'
                              C:/Users/user/AppData/Roaming/SketchUp/SketchUp 2027/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in '<top (required)>'
                              Any help would be greatly appreciated.
                              Thank you!
                              • fredo6F
                                fredo6
                                It might be a problem of installation where the main file Fredo6_!LibFredo6.rb has not been replaced. I don't know how you installed it.
                                Could you go to the plugin directory, and erase:
                                • Fredo6_!LibFredo6.rb file
                                • Fredo6_!LibFredo6 subfolder
                                And then reinstall LibFredo6.
                                A 1 Reply Last reply
                                • A
                                  aprogon @fredo6
                                  Hi @fredo6,
                                  Thank you very much for your reply.
                                  I installed the plugins through SU's Extension Manager.
                                  I deleted the file and folder you mentioned, and that partially solved the problem. I was able to install LibFredo and the other plugins, and they now show up correctly. The tools are listed, and the correct versions are displayed in the Extension Manager.
                                  The problem is that none of them actually work. I've tried JointPushPull, RoundCorner and FredoScale, but when I select any of the tools, they don't work. I've tried launching them both from the toolbars and from the Tools > Fredo Collection menu, but nothing happens.
                                  I can't even open the License option to load my license.
                                  Do you have any idea what might be causing this?
                                  Thanks again for your help!
                                  Dave RD 1 Reply Last reply
                                    Dave R @aprogon
                                    Why didn't you install LibFredo6 and the other extensions with the Sketchucation Tool? You have to have the current version of the tool installed to manage the licenses for Fredo's extensions.
                                    What version of LibFredo6? What are the version numbers of Joint P/P, RoundCorner, and FredoScale?
                                    What version of SketchUp are you using? On what operating system?
                                    A 2 Replies Last reply
                                    • A
                                      aprogon @Dave R
                                      Hi @Dave-R,
                                      Thanks for your reply.
                                      I've always installed the plugins through the Extension Manager and never had any issues until I upgraded to SU 2027. In fact, as I mentioned in my original post, the plugins work perfectly fine in SU 2026. In any case, if you think that might be the cause, I'll give it a try.
                                      As for the extension versions, I'm using the latest ones available in the Plugin Store. I downloaded them again a couple of days ago:
                                      • LibFredo_v16.4a
                                      • RoundCorner_v3.4a
                                      • FredoScale_v3.7c
                                      • JointPushPull_v4.9a
                                      Windows and SketchUp versions are included in my original post, but I'll list them again here:
                                      SketchUp: 27.0.267
                                      OS: Windows 11
                                      Thanks for your time.
                                      • A
                                        aprogon @Dave R
                                        Hi again @Dave-R ,
                                        I’ve just uninstalled everything and reinstalled it using the SketchUcation ExtensionStore, but the result is exactly the same. All the tools show up, but none of them work.
                                        • fredo6F
                                          fredo6
                                          It is important to know what you mean by 'none of them work'. Do you get a message?
                                          Can you open the Ruby console before launching the tool.
                                          Could you also copy/paste the output when you invoke the meny Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support.
                                          Also, make ure you installed the latest version of the Sketchucation Tools.
                                          • D
                                            DRydah13
                                            SketchUp 2026 / Windows 11
                                            LibFredo6 version 16.4a
                                            Windows Code Integrity Event ID: 3077
                                            Blocked component: SU26-0/E6B.so
                                            Windows Smart App Control: ON
                                            Request: A trusted, properly signed version of the E6B component compatible with Windows Smart App Control.
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 117
                                            • 116 / 117
