    [Plugin] AddFaces
    18 Posts 14 Posters 30.6k Views 14 Watching
      This script simply adds faces to selected edges if it can.
      [flash=600,338:dq1eir8s]http://www.youtube.com/v/o3L1afAhabY[/flash:dq1eir8s]
      Read the start of the rb file for guidance.
      Select some edges and use the Plugins-Menu or Context-Menu item.
      In the Ruby Console you can type **TIG.**addfaces [note this was changed in v2.0]
      http://sketchucation.com/resources/pluginstore?pln=addfaces
        Dan
        Thanks a lot, Tig!
        Useful as always πŸ‘
          Mysterious πŸ˜„
            Jim
            I like this idea of command line access to infrequently used scripts. All it needs is a little auto-completion and input area...
              Ah ok I understand now β˜€
              • Chris FullmerC Offline
                Cool, thanks TIG!
                All my Plugins I've written
                  Matt666
                  +1, Jim! Like command line in Acad...
                  Frenglish at its best !
                  My scripts
                  • G Offline
                    gavvy
                    😲 TiG ! what is the difference form the makeFaces.rb ?? ❓
                      remus
                      makefaces works on the whole model, this works on a seection.
                      • EarthMoverE Offline
                        EarthMover
                        I use Rick's make faces script on a selection all the time. It works well, although it can take a long time if there is a big selection. I wonder if TIG's script is perhaps a little faster?
                        Content Creator at Skapeup
                        • I Offline
                          iborov
                          I RESPECT YOU TIG!
                          !B
                          • brookefoxB Offline
                            brookefox
                            Thank you, TIG.
                            Since I often find myself having to draw and erase edges so as to get SU to face things it 'normally' does without 'instruction' (esp. within 'curves') I like the menu/context selection for this. I hope it will save me such time spent.
                            ~ Brooke
                            • Bob JamesB Offline
                              Bob James
                              Simple curve: get error
                                @Bob
                                It appears under the Plugins-Menu or the Context-Menu.
                                Used from the Ruby Console v2 command is now:
                                **TIG.**addfaces
                                [the thread IS 5 years OLD for v1...]
                                  Bob James
                                  Being graphically oriented I just watched the video and didn't read the words under it.
                                  Well, at least I present problems that are easy to solve πŸ˜„
                                  Thank you for taking the time, yet again, to help.
                                    tillar
                                    Any chance a progress bar can be added?
                                    The "Simplify Contours" extension has a really basic one, down in the statusbar that gets the job done.
                                    Simplify Contours (sketchup.com)
                                    http://extensions.sketchup.com/sites/extensions.sketchup.com/files/styles/ext_icon/public/Simplify_Contours.png?itok=_snDPjK4
                                      The PluginStore now contains v2.1 http://sketchucation.com/pluginstore?pln=addfaces
                                      It now has a progress-indicator on the status-bar ...666/1234 etc...
                                        a4jp.com
                                        Thank you so much. This plugin is wonderful. Will there be any updates for it later on?
