πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] AddFaces
18 Posts 14 Posters 30.1k Views 14 Watching
    This script simply adds faces to selected edges if it can.
    [flash=600,338:dq1eir8s]http://www.youtube.com/v/o3L1afAhabY[/flash:dq1eir8s]
    Read the start of the rb file for guidance.
    Select some edges and use the Plugins-Menu or Context-Menu item.
    In the Ruby Console you can type **TIG.**addfaces [note this was changed in v2.0]
    http://sketchucation.com/resources/pluginstore?pln=addfaces
      Dan
      Thanks a lot, Tig!
      Useful as always πŸ‘
        Mysterious πŸ˜„
          Jim
          I like this idea of command line access to infrequently used scripts. All it needs is a little auto-completion and input area...
            Ah ok I understand now β˜€
              Cool, thanks TIG!
                Matt666
                +1, Jim! Like command line in Acad...
                Frenglish at its best !
                My scripts
                  gavvy
                  😲 TiG ! what is the difference form the makeFaces.rb ?? ❓
                    remus
                    makefaces works on the whole model, this works on a seection.
                    • E Offline
                      EarthMover
                      I use Rick's make faces script on a selection all the time. It works well, although it can take a long time if there is a big selection. I wonder if TIG's script is perhaps a little faster?
                      Content Creator at Skapeup
                      • I Offline
                        iborov
                        I RESPECT YOU TIG!
                        !B
                          brookefox
                          Thank you, TIG.
                          Since I often find myself having to draw and erase edges so as to get SU to face things it 'normally' does without 'instruction' (esp. within 'curves') I like the menu/context selection for this. I hope it will save me such time spent.
                          ~ Brooke
                          • Bob JamesB Offline
                            Bob James
                            Simple curve: get error
                              @Bob
                              It appears under the Plugins-Menu or the Context-Menu.
                              Used from the Ruby Console v2 command is now:
                              **TIG.**addfaces
                              [the thread IS 5 years OLD for v1...]
                                Bob James
                                Being graphically oriented I just watched the video and didn't read the words under it.
                                Well, at least I present problems that are easy to solve πŸ˜„
                                Thank you for taking the time, yet again, to help.
                                  tillar
                                  Any chance a progress bar can be added?
                                  The "Simplify Contours" extension has a really basic one, down in the statusbar that gets the job done.
                                  Simplify Contours (sketchup.com)
                                  http://extensions.sketchup.com/sites/extensions.sketchup.com/files/styles/ext_icon/public/Simplify_Contours.png?itok=_snDPjK4
                                    The PluginStore now contains v2.1 http://sketchucation.com/pluginstore?pln=addfaces
                                    It now has a progress-indicator on the status-bar ...666/1234 etc...
                                      a4jp.com
                                      Thank you so much. This plugin is wonderful. Will there be any updates for it later on?
