    [Plugin] AddFaces
    18 Posts 14 Posters 31.4k Views 14 Watching
      gavvy
      😲 TiG ! what is the difference form the makeFaces.rb ?? ❓
        remus
        makefaces works on the whole model, this works on a seection.
        • EarthMoverE Offline
          EarthMover
          I use Rick's make faces script on a selection all the time. It works well, although it can take a long time if there is a big selection. I wonder if TIG's script is perhaps a little faster?
          Content Creator at Skapeup
          • I Offline
            iborov
            I RESPECT YOU TIG!
            !B
            • brookefoxB Offline
              brookefox
              Thank you, TIG.
              Since I often find myself having to draw and erase edges so as to get SU to face things it 'normally' does without 'instruction' (esp. within 'curves') I like the menu/context selection for this. I hope it will save me such time spent.
              ~ Brooke
              • Bob JamesB Offline
                Bob James
                Simple curve: get error
                  @Bob
                  It appears under the Plugins-Menu or the Context-Menu.
                  Used from the Ruby Console v2 command is now:
                  **TIG.**addfaces
                  [the thread IS 5 years OLD for v1...]
                    Bob James
                    Being graphically oriented I just watched the video and didn't read the words under it.
                    Well, at least I present problems that are easy to solve πŸ˜„
                    Thank you for taking the time, yet again, to help.
                      tillar
                      Any chance a progress bar can be added?
                      The "Simplify Contours" extension has a really basic one, down in the statusbar that gets the job done.
                      Simplify Contours (sketchup.com)
                      http://extensions.sketchup.com/sites/extensions.sketchup.com/files/styles/ext_icon/public/Simplify_Contours.png?itok=_snDPjK4
                        The PluginStore now contains v2.1 http://sketchucation.com/pluginstore?pln=addfaces
                        It now has a progress-indicator on the status-bar ...666/1234 etc...
                          a4jp.com
                          Thank you so much. This plugin is wonderful. Will there be any updates for it later on?
