    Vray Color Question
    renderpluginsextensions
    8 Posts 4 Posters 2.1k Views 4 Watching
    • boofredlayB
      boofredlay
      I have a texture that is rendering yellow when it is supposed to be green.
      See images for my settings and the render.
      What could be causing this? I cannot seem to correct it.
      Thanks for any help.
      • thomthomT
        First of all: What V-Ray version do you have?
        That green material you have, is the texture in reality yellow, but colourized in SU?
        • boofredlayB
          boofredlay
          Version 01.05.30
          The texture is actually red, adjusted in SU.
          By your question, I am assuming it is best to change the color prior to inserting in SU?
          Thanks.
          • thomthomT
            It is the safest thing. V-RAy some times has problems dealing with colourised textures. Some times you get the issue you got, v-ray doesn't modify the colour. But you also got a problem that V-Ray creates a Blend map, using the original texture and blending it 50/50 with the colourization colour, which isn't a good blend method as you looses colour depth.
            • EarthMoverE
              EarthMover
              Eric,
              For textures that give me a hard time in Vray, I'll usually just edit them in photoshop from sketchup, then reload them. It's a pain, but it works pretty quickly. It only happens on certain textures for some odd reason.
              Content Creator at Skapeup
              • boofredlayB
                boofredlay
                Thanks guys. πŸ˜„
                • S
                  ScottPara
                  Click the "M" next to the diffuse color and lets see those settings πŸ˜„
                  Scott
                  Love the fact that some HATE my avatar.....
                  • boofredlayB
                    boofredlay
                    As requested.
