Vray Color Question
I have a texture that is rendering yellow when it is supposed to be green.
See images for my settings and the render.What could be causing this? I cannot seem to correct it.
Thanks for any help.
First of all: What V-Ray version do you have?
That green material you have, is the texture in reality yellow, but colourized in SU?
Version 01.05.30
The texture is actually red, adjusted in SU.
By your question, I am assuming it is best to change the color prior to inserting in SU?Thanks.
It is the safest thing. V-RAy some times has problems dealing with colourised textures. Some times you get the issue you got, v-ray doesn't modify the colour. But you also got a problem that V-Ray creates a Blend map, using the original texture and blending it 50/50 with the colourization colour, which isn't a good blend method as you looses colour depth.
Eric,
For textures that give me a hard time in Vray, I'll usually just edit them in photoshop from sketchup, then reload them. It's a pain, but it works pretty quickly. It only happens on certain textures for some odd reason.
Thanks guys.
Click the "M" next to the diffuse color and lets see those settings
Scott
As requested.
