    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 375.5k Views 135 Watching
    • david_hD Offline
      david_h
      Okay. serious gob-smacking d'oh here. I got it to work.
      Thanks. Although. . I thought I did all this stuff. But whatever. .it works now.
      • Z Offline
        ZahariStoyanov
        @boofredlay said:
        One for me was when Gaieus was from Gaieus' talk at the Basecamp (I saw the video) and using the rotate tool.
        When you click the rotate tool and click the rotation point, don't let go of the mouse button... drag it out to either red or green (or any other snap point you set up) then click to start. This relieves any need for a vertical plane to get your rotation set up.
        See image for example.
        [attachment=0:1ay9p7c2]<!-- ia0 -->ClickHold.jpg<!-- ia0 -->[/attachment:1ay9p7c2]
        I have been using SU since V2 and never knew that until last year.
        1. F##king 2009! I've been modelling with SU since 2006 and didn't know about this feature until today ๐Ÿ˜„
        • Z Offline
          ZahariStoyanov
          Recent duh-moments in my modelling - watching Box's doodles to find out I've been using SU the wrong way for quite long. Again and again ๐Ÿ˜„
          • Epix3DE Offline
            Epix3D
            Modelling small parts
            Iยดve had som problems with curves when modelling small parts. Rounded edges/corners will not close. I found a workaround that works: Scale the model two times or more, do the rounding with double radius, -then scale down 0,5 to normal size.
              ๐Ÿ‘ Yep. That's a standard recommended procedure for drawing small items in SketchUp. I use a slightly different procedure that works better for me but yours is the method most people seem to use.
              • JQLJ Offline
                JQL
                I bet that method evolves making turning your geometry into a component (wich is default work for you) copy the component to the side and scale it up, work on the scaled up version and the correctly scaled version will update simultaneously.
                Repeat the process as needed!
                Right?
                That's what I do too, even if I have to turn my groups into components. (Sorry Dave, but I simply love the components vs groups discussion!)
                www.casca.pt
                Visit us on facebook!
                  you should have a group hug
                  • BoxB Offline
                    http://i155.photobucket.com/albums/s296/storeben/Stuff/buthead.gif
                      why thank you Box
                        You mean a component hug, right? ๐Ÿ˜„
                          no, if components hug you get a scaling issue
                          • BoxB Offline
                            Groups, components or unique's doesn't matter! If you lot get close enough to be hugging there will be dubious 'plugin' accusations. As Rich says, there is a front door and a back passage...........
                            • jiminy-billy-bobJ Offline
                              jiminy-billy-bob
                              Everyone know that deep down, groups and components are the same.
                                ๐Ÿ˜›
                                ๐Ÿ˜ฎ
                                • JQLJ Offline
                                  JQL
                                  So... are we starting chapter 2? Will it be a trilogy?
                                  www.casca.pt
                                    It's been a love/hate project I've tackled on and off when I had time.
                                    So to finally draw a line under it is great.
                                    Now to see what happens next.... ๐Ÿ˜›
                                    • cottyC Offline
                                      cotty
                                      ๐Ÿ‘
                                      my SketchUp gallery
                                        jiminy-billy-bob
                                        Are you bringing these to the Basecamp? ๐Ÿ˜„
                                          Who said that?
                                            jiminy-billy-bob
                                            Nobody, I'm just wondering
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
