    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.3k Views 135 Watching
    • Z
      ZahariStoyanov
      @boofredlay said:
      One for me was when Gaieus was from Gaieus' talk at the Basecamp (I saw the video) and using the rotate tool.
      When you click the rotate tool and click the rotation point, don't let go of the mouse button... drag it out to either red or green (or any other snap point you set up) then click to start. This relieves any need for a vertical plane to get your rotation set up.
      See image for example.
      [attachment=0:1ay9p7c2]<!-- ia0 -->ClickHold.jpg<!-- ia0 -->[/attachment:1ay9p7c2]
      I have been using SU since V2 and never knew that until last year.
      1. F##king 2009! I've been modelling with SU since 2006 and didn't know about this feature until today ๐Ÿ˜„
      • Z
        ZahariStoyanov
        Recent duh-moments in my modelling - watching Box's doodles to find out I've been using SU the wrong way for quite long. Again and again ๐Ÿ˜„
        • Epix3DE
          Epix3D
          Modelling small parts
          Iยดve had som problems with curves when modelling small parts. Rounded edges/corners will not close. I found a workaround that works: Scale the model two times or more, do the rounding with double radius, -then scale down 0,5 to normal size.
            ๐Ÿ‘ Yep. That's a standard recommended procedure for drawing small items in SketchUp. I use a slightly different procedure that works better for me but yours is the method most people seem to use.
            • JQLJ
              JQL
              I bet that method evolves making turning your geometry into a component (wich is default work for you) copy the component to the side and scale it up, work on the scaled up version and the correctly scaled version will update simultaneously.
              Repeat the process as needed!
              Right?
              That's what I do too, even if I have to turn my groups into components. (Sorry Dave, but I simply love the components vs groups discussion!)
              www.casca.pt
              Visit us on facebook!
                you should have a group hug
                • BoxB
                  http://i155.photobucket.com/albums/s296/storeben/Stuff/buthead.gif
                    why thank you Box
                      You mean a component hug, right? ๐Ÿ˜„
                        no, if components hug you get a scaling issue
                        • BoxB
                          Groups, components or unique's doesn't matter! If you lot get close enough to be hugging there will be dubious 'plugin' accusations. As Rich says, there is a front door and a back passage...........
                          • jiminy-billy-bobJ
                            jiminy-billy-bob
                            Everyone know that deep down, groups and components are the same.
                              ๐Ÿ˜›
                              ๐Ÿ˜ฎ
                              • JQLJ
                                JQL
                                So... are we starting chapter 2? Will it be a trilogy?
                                www.casca.pt
                                  It's been a love/hate project I've tackled on and off when I had time.
                                  So to finally draw a line under it is great.
                                  Now to see what happens next.... ๐Ÿ˜›
                                  • cottyC
                                    cotty
                                    ๐Ÿ‘
                                    my SketchUp gallery
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Are you bringing these to the Basecamp? ๐Ÿ˜„
                                        Who said that?
                                        • jiminy-billy-bobJ
                                          jiminy-billy-bob
                                          Nobody, I'm just wondering
                                            I'm not bringing them. But they could be there.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 32 / 35
