    Osx : SketchUp wants to access my keychain
    20 Posts 16 Posters 7.0k Views 16 Watching
      Sophie424
      When I start up SketchUp I get a dialog:
      SketchUp wants to access my keychain - do you want to allow this?
      Is this normal?
      • Chris FullmerC Offline
        That is the literal wording of the prompt? word for word?
        Do you have a USB named "My Keychain?" or is that the name of one of your hard drives?
        Chris
        All my Plugins I've written
        • Paul RussamP Offline
          Paul Russam
          Chris, its OSX's place for storing logins/passwords.
          I imagine that SU will store your Google account info for logging into warehouse and this is what is keychain is wanting permission for.
          Paul Russam
          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
            Sophie424
            It disturbs me, I have many other passwords on the keychain e.g. my LAN logins for other machines.
            The keychain seems to have 3 identical entries by Sketchup:
            Google Sketchup application password
            I am using Sketchup-7 Pro, perhaps that is the reason?
            • bigstickB Offline
              bigstick
              Just accept and don't worry about it πŸ˜‰
              • daleD Offline
                dale
                No one can access your keychain without your administrator password. Be sure to protect that.
                  DrSunglasses
                  πŸ‘Š 😎
                  πŸ€“ Anyone know how to disable this? πŸŽ‰ I've tried deleting the keychain entries, but they just show up again when I start SketchUp and it asks for a password. 😍
                  • AndrewSA Offline
                    AndrewS
                    @drsunglasses said:
                    Anyone know how to disable this? I've tried deleting the keychain entries, but they just show up again when I start SketchUp and it asks for a password.
                    What specifically would you like to disable? Are you concerned about SketchUp writing the keys in the first place, the fact that it wants repeated access to your keychain, or the fact that the password prompt keeps appearing?
                    The interactions that will occur in this circumstance depend on the settings of certain security preferences you have set on your machine, so I just need more details to understand what you're trying to accomplish. For instance, if you have enabled the application firewall, you're going to have to enter a password before SketchUp can access your keychain, whereas there may just be a prompt to ask for approval, or no prompt at all, in various situations.
                    I will say this to the paranoid among you; SketchUp can only access the keys in your keychain that you provide access to. When the OS displays the warning to say an application wants to see your keychain, it does tell you which keys it wants to see, so that's how you know it isn't doing something fishy behind your back.
                    The keys SketchUp saves in the keychain are various session IDs that are vital for features that use built-in browser interaction. I can't think of any reason to be concerned about them or want to remove them. I'd like to know what has you concerned...
                    Andrew S.
                    SketchUp Release Engineer
                      DrSunglasses
                      I'm a sysadmin 😎 and I have a template user profile which runs SketchUp with no keychain password prompt. After the template account is copied to be the system-wide default and I run SketchUp as a user I get this dialog:
                      http://img23.imageshack.us/img23/1765/sketchuperror.png
                      Obviously, I'd like no prompt, if possible.
                      p.s. sorry for all the smilies in my first post... there are just too many good ones on this forum!!
                        And have you already seen our SketchUp "smiley's"
                        (and more - the system only allows 15 in a post)
                          jeanclaudevandam
                          Hi I am also a system administrator using a template account.
                          Everytime this program is run it asks for the login keychain.
                          Is there a way to disable it?
                            syman97
                            I am also a system admin using a template acct. Can someone please help us to disable the login keychain?
                            • AndrewSA Offline
                              AndrewS
                              Sorry, we've been pretty busy around here and haven't been able to look into this. I've sent a message out to the Mac gurus to see if anyone has ideas and can help immediately. Otherwise, unfortunately, it'll still have to sit on the backburner until we can get to it.
                              My gut feeling is that we may be able to get around it with application signing. We presently distribute SketchUp unsigned. If you, as a sysadmin, were to sign it using self-certified keys, you might be able to get around it. That's just a guess though.
                              Andrew
                              Andrew S.
                                bjanzen
                                If you look at /Applications/Utilities/Keychain Access, you'll see that there's a "Warehouse Authorization Token". We discussed this when it came out that it wasn't very Mac-like, but it's really the cleanest/easiest way to handle interaction with the warehouse. If this is a huge problem for you, I could file a feature request and link to this thread. Let me know.
                                b
                                  tesamie
                                  For some unfathomable reason the SketchUp coders think this keychain thing is a good idea, it was never there before Google bought them out.
                                  The way I got rid of it was to run the KeyChain Access application in the Utilities folder and look for the 3 SketchUp items in the login keychain. Then double clck on each and change the access control from "confirm before allowing access" to "allow all appllications to access this item". That then gets rid of the prompt.
                                  Of course it makes the items less secure (though I've no idea what these things are trying to store anyway), but short of being able to remove this thing entirely it beats being prompted for 3 passwords every time you launch the application.
                                    Scorysto
                                    This occurs for me as well. Mostly in my lab setting. The problem comes in with the fact that we use LDAP to authenticate users then map it to a local account. The local accounts password is different from the password that the user enters to authenticate based on LDAP. This cause the login.keychain to lock. SU access the login.keychain. At the moment there is not a way to unlock the keychain based on Directory access such as ldap. What this means is that anyone one in a lab setting using a similar authentication method will run into it. It would be nice to be able to turn off SU so it didn't need to access the login keychain. Or an even better solution that I haven't been able to find either is something that either resets or changes the keychain password to match the LDAP Authentication. Just thought it is irritating because student users that login get freaked out when they see dialog boxes that ask for passwords. If you hit cancel 3 times it still allows the program to work so I assume that what ever it is doing is not critical but it help in terms of user experience to have it not happen at all.
                                      DrSunglasses
                                      I think I've fixed things.... Removing everything in ~/Library/Keychains as the template user seems to do the trick.
                                      ls-mac;~ gccf0$ rm -rf ~/Library/Keychains/*
                                      Before I did that, I removed SketchUp's two login.keychain entries in Keychain Access, but I don't know if that was necessary.
                                        carterx
                                        Has anyone been able to get this to work. I just finished building my college wide base image and this is the only application that is giving me an issue. I too create a default user which all new user profiles are built from and users being promp. for a keychain password will not work. If I can not find a fix in the next couple days SketchUp will have to be pulled from the college wide image.
                                        Thanks.
                                          terrycat_osu
                                          Hello all,
                                          I wanted to post a solution to this problem. The sketchup license does not involve the the keychain... there is no reason to copy that over to your template. The only file you need to copy over to your template is /Users/<username>/Library/Application Support/Google SketchUp 8/Lic#####.skp6lic For assurance I copied the whole /Users/<username>/Library/Application Support/Google SketchUp directory to the template.
                                          Thats all you need. Good luck!
                                            losdw
                                            I am also having the same problem, and the above fixes do not work. If I use the local admin account on the system, it doesn't ask for the keychain, if I use an ldap authenticated/template account, it does ask for the keychain.
                                            I would love to deploy this application to the mac labs we have on campus, any help would be greatly appreciated.
                                            Thanks.
