    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
    • scottliningerS
      scottlininger
      I just had a big one reported to me... posting it here so folks are aware until the next fix.
      The face.material method is entirely missing from the new docs.
      • Scott Lininger
        SketchUp Software Engineer
        Have you visited the Ruby API Docs?
      • scottliningerS
        scottlininger
        There's a new update live that fixes (most of) the problems reported above. There were one or two that will require me to pound on it a bit more. Keep 'em coming!
        I also posted a new tutorial on reading attributes.
        • Scott Lininger
        • thomthomT
          Nice one Scott.
          I seem to have come across three observer events that doesn't work. It would probably be useful to mark these in the docs with a warning so that people won't waste a whole lot of time trying to get them work work. ..like I have...
          DefinitionObserver http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17631 (Completely busted)
          EntitiesObserver.onContentsModified http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17970 (Add and Remove event works though. Haven't tried the Erase event.)
          • scottliningerS
            scottlininger
            I also just got this one from a coworker:
            Sketchup.get_resource_path example fails. Looks like there's a required parameter that's not properly documented.
            -Scott
            • Scott Lininger
            • thomthomT
              These failing observers is quite severe. I don't suppose there's a chance the dev team can push out an update outside the servicepack schedule? (I don't know what your schedule is, but seeing that we just got an servicepack I'm a bit pessimistic to when this might be addressed...)
              • R
                remus
                A semi related typo:
                in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
                • Chris FullmerC
                  ::OFF TOPIC::
                  All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?
                  Chris
                  All my Plugins I've written
                  • scottliningerS
                    scottlininger
                    Just saw another one: the Sketchup.break_edges= example is the Sketchup.break_edges? example.
                    Thom, step 1 with the observers is to confirm if it's the implementation that is broken or the documentation. Simone has filed A-list bugs against the observer problems you've found, and he and I have been chatting about it. Any fixes will have to wait until the next maintenance release.
                    Feel free to PM me if you want to brainstorm workarounds for what you're trying to accomplish. I know a few tricks. πŸ˜‰
                    • Scott Lininger
                    • R
                      remus
                      Dont pretend your not in on it as well πŸ˜„
                      on a more serious note, it seems a shame to miss out on the ever so powerful ruby based capabilities of sketchup, so i thought i'd try my hand at it and see if i got anywhere.
                      I reckon i could just about right a box making script at the moment πŸ‘ just as long as you dont want to change your box at all...
                      • thomthomT
                        Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                        But onOpen works.
                        • thomthomT
                          Error 404 (Not Found)!!1
                          (code.google.com)
                          For example, if a user has double-clicked into a component to edit its geometry, and then double clicked into a sub-group to edit that, the active_path might contain:
                          And there it stops. Doesn't actually display an example.
                          • scottliningerS
                            scottlininger
                            Self note: We should add these codes to the send_action docs:
                            (groups.google.com)
                            • Scott Lininger
                            • thomthomT
                              (code.google.com)
                                   # This is an example of an observer that watches tool interactions.
                                   class MyToolsObserver < Sketchup;;ShadowInfoObserver
                                     def onActiveToolChanged(tools, tool_name, tool_id)
                                       UI.messagebox("onActiveToolChanged; " + tool_name.to_s)
                                   # Attach the observer.
                                   Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                              Note that it refers to Sketchup::ShadowInfoObserver instead of Sketchup::ToolsObserver.
                              • TIGT
                                (groups.google.com)
                                Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
                                If there are such codes it makes like a lot easier...
                                Some "wrong": Sketchup.send_action 21513 >>> opens the Outliner ???
                                • thomthomT
                                  (code.google.com)
                                  The manual says the argument should be either true or false, but the example sets it to 3.
                                  • Chris FullmerC
                                    The FAQ page lists some sites that carry/catalog ruby scripts. the Sketchucation extensions index (thanks to Jim!) would also be a great resource to add to that list now
                                    extensions url:
                                    404 Not Found
                                    (www.sketchucation.com)
                                    Chris
                                    • thomthomT
                                      http://code.google.com/apis/sketchup/docs/ourdoc/toolsobserver.html
                                      It'd be nice if the ToolsObserver listed the full list of tools IDs.
                                      I've begun a list here which associates constants to the IDs for convenient use in scripts: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18124
                                      • J
                                        Jim
                                        In the back of my mind I have the idea the the tool id's were not reliable and shouldn't be used; but I can't remember why.
                                        • thomthomT
                                          I thought is was the tool names as on Mac the first four characters where truncated? No?
                                          • Chris FullmerC
                                            (code.google.com)
                                            The ComponentInstance.definition example does not include the method in the example anywhere, so by definition it is not really an example.
                                            This is the given example:
                                             point = Geom;;Point3d.new 10,20,30
                                             transform = Geom;;Transformation.new point
                                             model = Sketchup.active_model
                                             entities = model.active_entities
                                             path=Sketchup.find_support_file "Bed.skp",
                                               "Components/Components Sampler/"
                                            • 18
                                            • 19
                                            • 3 / 19
