    New API doc - typos and questions
    370 Posts 35 Posters 293.3k Views 35 Watching
      Error 404 (Not Found)!!1
      (code.google.com)
      For example, if a user has double-clicked into a component to edit its geometry, and then double clicked into a sub-group to edit that, the active_path might contain:
      And there it stops. Doesn't actually display an example.
      • scottliningerS Offline
        scottlininger
        Self note: We should add these codes to the send_action docs:
        http://groups.google.com/group/Ruby-API/msg/e30ee3f2b21cb228
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          http://code.google.com/apis/sketchup/docs/ourdoc/toolsobserver.html
               # This is an example of an observer that watches tool interactions.
               class MyToolsObserver < Sketchup;;ShadowInfoObserver
                 def onActiveToolChanged(tools, tool_name, tool_id)
                   UI.messagebox("onActiveToolChanged; " + tool_name.to_s)
               # Attach the observer.
               Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
          Note that it refers to Sketchup::ShadowInfoObserver instead of Sketchup::ToolsObserver.
            Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
            If there are such codes it makes like a lot easier...
            Some "wrong": Sketchup.send_action 21513 >>> opens the Outliner ???
              (code.google.com)
              The manual says the argument should be either true or false, but the example sets it to 3.
              • Chris FullmerC Offline
                The FAQ page lists some sites that carry/catalog ruby scripts. the Sketchucation extensions index (thanks to Jim!) would also be a great resource to add to that list now
                extensions url:
                410 Gone
                (www.sketchucation.com)
                  It'd be nice if the ToolsObserver listed the full list of tools IDs.
                  I've begun a list here which associates constants to the IDs for convenient use in scripts: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18124
                    Jim
                    In the back of my mind I have the idea the the tool id's were not reliable and shouldn't be used; but I can't remember why.
                      I thought is was the tool names as on Mac the first four characters where truncated? No?
                        http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#definition
                        The ComponentInstance.definition example does not include the method in the example anywhere, so by definition it is not really an example.
                        This is the given example:
                         point = Geom;;Point3d.new 10,20,30
                         transform = Geom;;Transformation.new point
                         model = Sketchup.active_model
                         entities = model.active_entities
                         path=Sketchup.find_support_file "Bed.skp",
                           "Components/Components Sampler/"
                          Jim
                          Any ideas about a way to mark these errors as they are fixed?
                            We could ask Coen to have a strike-through BBC tag. [deleted] or something...
                            Or, put a big fat FIXED in bold green. Might be easier.
                              avariant
                              From Image.explode:
                              entitiesarray     an Array object of entities if successful
                              which I interpret as the face and edges created in the explosion. However, the result from my testing always returns an empty array.
                                I see that behaviour as well: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=17150&hilit=+explode
                                  http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#add_polygon
                                  add polygon detail just repeats the add_point example.
                                    scottlininger
                                    @thomthom said:
                                    Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                                    But onOpen works.
                                    Thomas,
                                    I'm about to push an update with all of the recent changes above. This one puzzled me, though. The ToolsObserver examples work fine for me on the onOpen and onClose. Can you clarify what "dead as well" means? 😄
                                    Tig, these action codes only work on the PC, but I still think I'll add them to the docs. There are some cool things in there that PC-only shops might need.
                                    Thanks, guys! New update should be live in the next day or so.
                                    • Scott Lininger
                                      scottlininger
                                      Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
                                      • Scott Lininger
                                        Dead as in: I never see it trigger.
                                          ToolObservers? How are they related to onClose and onOpen?
                                            remus
                                            I'll ask gai if he can make you a mod for the ruby forum 👍
                                            • 18
                                            • 19
                                            • 3 / 19
