    New API doc - typos and questions
    370 Posts 35 Posters 310.8k Views 35 Watching
      Point3d.project_to_plane
      The example uses project_to_line
       plane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)]
       point = Geom;;Point3d.new 10,10,10
       projected_point = point.project_to_line line
      • Chris FullmerC Offline
        Tool - onMouseMove example has a bad local variable.
        http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMove
         def onMouseMove(flags, x, y, view)
           puts "onMouseMove; flags = " + key.to_s
           puts "                 x = " + x.to_s
           puts "                 y = " + y.to_s
           puts "              view = " + view.to_s
        The variable "key" should be replaced with "flag" I think. That makes the example work.
          http://code.google.com/apis/sketchup/docs/ourdoc/face.html#get_UVHelper
          The code example:
           model = Sketchup.active_model
           entities = model.active_entities
           pts = []
           pts[0] = [0, 0, 0]
           pts[1] = [9, 0, 0]
           pts[2] = [9, 9, 0]
           pts[3] = [0, 9, 0]
           # Add the face to the entities in the model
           face = entities.add_face pts
           tw = Sketchup;;TextureWriter.new
           uvHelp = face.get_UVHelper true, true, tw
          This will return the error:
          Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
          (eval):95
          Instead of tw = Sketchup::TextureWriter.new, the method tw = Sketchup.create_texture_writer will work.
          Which leads to another questions: why can't tw = Sketchup::TextureWriter.new be used as in the example?
            ModelObserver.onPlaceComponent
            http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponent
            The manual claims that a Model is passed on as the argument, but instead it's the ComponentInstance. I have not tested the rest of the ModelObserver events to see if they also match.
            onPlaceComponent FIXED
            • scottliningerS Offline
              scottlininger
              Thomas, you rock.
              I'll double check all of the modelobserver arguments. Thanks!
              • Scott Lininger
                SketchUp Software Engineer
                Have you visited the Ruby API Docs?
                remus
                For Point3d.distance_to_line the docs give the same example as point3d.distance.
                  I can't get the DefinitionObserver to trigger at all. http://code.google.com/apis/sketchup/docs/ourdoc/definitionobserver.html Neither the onComponentInstanceAdded or onComponentInstanceRemoved events. Are these the correct event names?
                    scottlininger
                    I just had a big one reported to me... posting it here so folks are aware until the next fix.
                    The face.material method is entirely missing from the new docs.
                    • Scott Lininger
                      scottlininger
                      There's a new update live that fixes (most of) the problems reported above. There were one or two that will require me to pound on it a bit more. Keep 'em coming!
                      I also posted a new tutorial on reading attributes.
                      • Scott Lininger
                        Nice one Scott.
                        I seem to have come across three observer events that doesn't work. It would probably be useful to mark these in the docs with a warning so that people won't waste a whole lot of time trying to get them work work. ..like I have...
                        DefinitionObserver http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17631 (Completely busted)
                        EntitiesObserver.onContentsModified http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17970 (Add and Remove event works though. Haven't tried the Erase event.)
                          scottlininger
                          I also just got this one from a coworker:
                          Sketchup.get_resource_path example fails. Looks like there's a required parameter that's not properly documented.
                          -Scott
                          • Scott Lininger
                            These failing observers is quite severe. I don't suppose there's a chance the dev team can push out an update outside the servicepack schedule? (I don't know what your schedule is, but seeing that we just got an servicepack I'm a bit pessimistic to when this might be addressed...)
                              remus
                              A semi related typo:
                              in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
                                ::OFF TOPIC::
                                All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?
                                  scottlininger
                                  Just saw another one: the Sketchup.break_edges= example is the Sketchup.break_edges? example.
                                  Thom, step 1 with the observers is to confirm if it's the implementation that is broken or the documentation. Simone has filed A-list bugs against the observer problems you've found, and he and I have been chatting about it. Any fixes will have to wait until the next maintenance release.
                                  Feel free to PM me if you want to brainstorm workarounds for what you're trying to accomplish. I know a few tricks. 😉
                                  • Scott Lininger
                                    remus
                                    Dont pretend your not in on it as well 😄
                                    on a more serious note, it seems a shame to miss out on the ever so powerful ruby based capabilities of sketchup, so i thought i'd try my hand at it and see if i got anywhere.
                                    I reckon i could just about right a box making script at the moment 👍 just as long as you dont want to change your box at all...
                                      Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                                      But onOpen works.
                                        Error 404 (Not Found)!!1
                                        (code.google.com)
                                        For example, if a user has double-clicked into a component to edit its geometry, and then double clicked into a sub-group to edit that, the active_path might contain:
                                        And there it stops. Doesn't actually display an example.
                                          scottlininger
                                          Self note: We should add these codes to the send_action docs:
                                          http://groups.google.com/group/Ruby-API/msg/e30ee3f2b21cb228
                                          • Scott Lininger
                                            http://code.google.com/apis/sketchup/docs/ourdoc/toolsobserver.html
                                                 # This is an example of an observer that watches tool interactions.
                                                 class MyToolsObserver < Sketchup;;ShadowInfoObserver
                                                   def onActiveToolChanged(tools, tool_name, tool_id)
                                                     UI.messagebox("onActiveToolChanged; " + tool_name.to_s)
                                                 # Attach the observer.
                                                 Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                                            Note that it refers to Sketchup::ShadowInfoObserver instead of Sketchup::ToolsObserver.
                                            • 18
                                            • 19
                                            • 3 / 19
