    New API doc - typos and questions
    370 Posts 35 Posters 310.9k Views 35 Watching
      ModelObserver.onPlaceComponent
      http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponent
      The manual claims that a Model is passed on as the argument, but instead it's the ComponentInstance. I have not tested the rest of the ModelObserver events to see if they also match.
      onPlaceComponent FIXED
      • scottliningerS Offline
        scottlininger
        Thomas, you rock.
        I'll double check all of the modelobserver arguments. Thanks!
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          remus
          For Point3d.distance_to_line the docs give the same example as point3d.distance.
            I can't get the DefinitionObserver to trigger at all. http://code.google.com/apis/sketchup/docs/ourdoc/definitionobserver.html Neither the onComponentInstanceAdded or onComponentInstanceRemoved events. Are these the correct event names?
              scottlininger
              I just had a big one reported to me... posting it here so folks are aware until the next fix.
              The face.material method is entirely missing from the new docs.
              • Scott Lininger
                scottlininger
                There's a new update live that fixes (most of) the problems reported above. There were one or two that will require me to pound on it a bit more. Keep 'em coming!
                I also posted a new tutorial on reading attributes.
                • Scott Lininger
                  Nice one Scott.
                  I seem to have come across three observer events that doesn't work. It would probably be useful to mark these in the docs with a warning so that people won't waste a whole lot of time trying to get them work work. ..like I have...
                  DefinitionObserver http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17631 (Completely busted)
                  EntitiesObserver.onContentsModified http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17970 (Add and Remove event works though. Haven't tried the Erase event.)
                    scottlininger
                    I also just got this one from a coworker:
                    Sketchup.get_resource_path example fails. Looks like there's a required parameter that's not properly documented.
                    -Scott
                    • Scott Lininger
                      These failing observers is quite severe. I don't suppose there's a chance the dev team can push out an update outside the servicepack schedule? (I don't know what your schedule is, but seeing that we just got an servicepack I'm a bit pessimistic to when this might be addressed...)
                        remus
                        A semi related typo:
                        in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
                        • Chris FullmerC Offline
                          ::OFF TOPIC::
                          All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?
                            scottlininger
                            Just saw another one: the Sketchup.break_edges= example is the Sketchup.break_edges? example.
                            Thom, step 1 with the observers is to confirm if it's the implementation that is broken or the documentation. Simone has filed A-list bugs against the observer problems you've found, and he and I have been chatting about it. Any fixes will have to wait until the next maintenance release.
                            Feel free to PM me if you want to brainstorm workarounds for what you're trying to accomplish. I know a few tricks. 😉
                            • Scott Lininger
                              remus
                              Dont pretend your not in on it as well 😄
                              on a more serious note, it seems a shame to miss out on the ever so powerful ruby based capabilities of sketchup, so i thought i'd try my hand at it and see if i got anywhere.
                              I reckon i could just about right a box making script at the moment 👍 just as long as you dont want to change your box at all...
                                Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                                But onOpen works.
                                  Error 404 (Not Found)!!1
                                  (code.google.com)
                                  For example, if a user has double-clicked into a component to edit its geometry, and then double clicked into a sub-group to edit that, the active_path might contain:
                                  And there it stops. Doesn't actually display an example.
                                    scottlininger
                                    Self note: We should add these codes to the send_action docs:
                                    http://groups.google.com/group/Ruby-API/msg/e30ee3f2b21cb228
                                    • Scott Lininger
                                      http://code.google.com/apis/sketchup/docs/ourdoc/toolsobserver.html
                                           # This is an example of an observer that watches tool interactions.
                                           class MyToolsObserver < Sketchup;;ShadowInfoObserver
                                             def onActiveToolChanged(tools, tool_name, tool_id)
                                               UI.messagebox("onActiveToolChanged; " + tool_name.to_s)
                                           # Attach the observer.
                                           Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                                      Note that it refers to Sketchup::ShadowInfoObserver instead of Sketchup::ToolsObserver.
                                        Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
                                        If there are such codes it makes like a lot easier...
                                        Some "wrong": Sketchup.send_action 21513 >>> opens the Outliner ???
                                          (code.google.com)
                                          The manual says the argument should be either true or false, but the example sets it to 3.
                                            The FAQ page lists some sites that carry/catalog ruby scripts. the Sketchucation extensions index (thanks to Jim!) would also be a great resource to add to that list now
                                            extensions url:
                                            410 Gone
                                            (www.sketchucation.com)
                                            • 18
                                            • 19
                                            • 3 / 19
