    New API doc - typos and questions
    370 Posts 35 Posters 291.3k Views 35 Watching
      remus
      A semi related typo:
      in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
      • Chris FullmerC Offline
        ::OFF TOPIC::
        All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?
        • scottliningerS Offline
          scottlininger
          Just saw another one: the Sketchup.break_edges= example is the Sketchup.break_edges? example.
          Thom, step 1 with the observers is to confirm if it's the implementation that is broken or the documentation. Simone has filed A-list bugs against the observer problems you've found, and he and I have been chatting about it. Any fixes will have to wait until the next maintenance release.
          Feel free to PM me if you want to brainstorm workarounds for what you're trying to accomplish. I know a few tricks. πŸ˜‰
          • Scott Lininger
            SketchUp Software Engineer
            Have you visited the Ruby API Docs?
            remus
            Dont pretend your not in on it as well πŸ˜„
            on a more serious note, it seems a shame to miss out on the ever so powerful ruby based capabilities of sketchup, so i thought i'd try my hand at it and see if i got anywhere.
            I reckon i could just about right a box making script at the moment πŸ‘ just as long as you dont want to change your box at all...
              Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
              But onOpen works.
                Error 404 (Not Found)!!1
                (code.google.com)
                For example, if a user has double-clicked into a component to edit its geometry, and then double clicked into a sub-group to edit that, the active_path might contain:
                And there it stops. Doesn't actually display an example.
                  scottlininger
                  Self note: We should add these codes to the send_action docs:
                  http://groups.google.com/group/Ruby-API/msg/e30ee3f2b21cb228
                  • Scott Lininger
                    http://code.google.com/apis/sketchup/docs/ourdoc/toolsobserver.html
                         # This is an example of an observer that watches tool interactions.
                         class MyToolsObserver < Sketchup;;ShadowInfoObserver
                           def onActiveToolChanged(tools, tool_name, tool_id)
                             UI.messagebox("onActiveToolChanged; " + tool_name.to_s)
                         # Attach the observer.
                         Sketchup.active_model.tools.add_observer(MyToolsObserver.new)
                    Note that it refers to Sketchup::ShadowInfoObserver instead of Sketchup::ToolsObserver.
                    • TIGT Online
                      Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
                      If there are such codes it makes like a lot easier...
                      Some "wrong": Sketchup.send_action 21513 >>> opens the Outliner ???
                        (code.google.com)
                        The manual says the argument should be either true or false, but the example sets it to 3.
                          The FAQ page lists some sites that carry/catalog ruby scripts. the Sketchucation extensions index (thanks to Jim!) would also be a great resource to add to that list now
                          extensions url:
                          410 Gone
                          (www.sketchucation.com)
                            It'd be nice if the ToolsObserver listed the full list of tools IDs.
                            I've begun a list here which associates constants to the IDs for convenient use in scripts: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18124
                              Jim
                              In the back of my mind I have the idea the the tool id's were not reliable and shouldn't be used; but I can't remember why.
                                I thought is was the tool names as on Mac the first four characters where truncated? No?
                                  http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#definition
                                  The ComponentInstance.definition example does not include the method in the example anywhere, so by definition it is not really an example.
                                  This is the given example:
                                   point = Geom;;Point3d.new 10,20,30
                                   transform = Geom;;Transformation.new point
                                   model = Sketchup.active_model
                                   entities = model.active_entities
                                   path=Sketchup.find_support_file "Bed.skp",
                                     "Components/Components Sampler/"
                                    Jim
                                    Any ideas about a way to mark these errors as they are fixed?
                                      We could ask Coen to have a strike-through BBC tag. [deleted] or something...
                                      Or, put a big fat FIXED in bold green. Might be easier.
                                        avariant
                                        From Image.explode:
                                        entitiesarray     an Array object of entities if successful
                                        which I interpret as the face and edges created in the explosion. However, the result from my testing always returns an empty array.
                                          I see that behaviour as well: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=17150&hilit=+explode
                                            http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#add_polygon
                                            add polygon detail just repeats the add_point example.
                                            • 18
                                            • 19
                                            • 3 / 19
