    New API doc - typos and questions
    370 Posts 35 Posters 290.9k Views 35 Watching
      @tig said:
      But strangely not with add_arc which returns an ArcCurve ?
      Nope, also returns an array.
      @tig said:
      It would be unadvisable to change what the API does with these add_ methods
      Agree.
        Agree.
        Perhaps I meant to say, "... add_arc which says it returns an ArcCurve wrongly!" πŸ˜’
          Sketchup.write_default
          Sketchup.read_default
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#write_default
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#read_default
          [..] the string associated with a value within the specified sub-section section of a .INI file or registry (within the Software > @Last Software > SketchUp section).
          Is it really stored under @Last any more?
            No, / Google / Sketchup 7 / etc... πŸ˜‰
              Group.move!
              http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/group.html#move!
              .move! moves to an absolute point. Worth noting in the manual.
              • Dan RathbunD Offline
                Dan Rathbun
                Geom::Point3d.+
                http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#+
                The '+' operator is a fast way to add to the current x, y and z values of a point, or to set the values of a point by adding to other points together.
                The end of the sentence should read, "...by adding **two** other points together."
                Returns:
                vector a Vector object
                There is no defined object named 'vector'. If we follow the example the class of the result is given as Geom::Point3d.
                pt2 = Geom;;Point3d.new(100,200,300)
                pt3 = pt2 + [1,1,1]
                >> Point3d(101, 201, 301)
                pt3.class
                >> Geom;;Point3d
                Arguments:
                point2 A Point3d object.
                An ArugemtError exception is raised if point2 is a Point3d object.
                Valid argument classes are: Array or Vector3d. This means to use a Point3d as an argument, you must convert to Array. Example:
                pt3 = pt1 + pt2.to_a
                This method needs to be fixed to take a Point3d object and internally convert it to an Array...
                # internal to + method
                if arg[0].is_a? Point3d { arg[0]=arg[0].to_a }
                ...or a Vector3d:
                if arg[0].is_a? Point3d { arg[0]=[0,0,0].vector_to(arg[0]) }
                either way. The current implementation is clumsy.
                I'm not here much anymore.
                  Dan Rathbun
                  **Geom::Point3d.-**
                  http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#-
                  Returns:
                  There is no defined object named 'vector', but there IS one named ' Vector3d'. If we follow the example the class of the result is given as Geom::Vector3d.
                  pt3 = pt2 - [1,1,1]
                  >> Vector3d(99, 199, 299)
                  pt3.class
                  >> Geom;;Vector3d
                  It seems a bit strange that + returns Point3d, but - returns Vector3d.
                    Dan Rathbun
                    Geom::Point3d.offset
                    Code example has errors:
                    [line1]replace"point ="with"point1 ="
                    [line1]use parameter delimiters both lines
                    [line3]replace".offset**!**"with".offset"
                    add comments
                    Corrected code:
                    point1 = Geom;;Point3d.new(10,10,10)
                    vector = Geom;;Vector3d.new(0,0,1)
                    point2 = point1.offset vector
                    # point1 is unchanged
                    # point2 is Point3d(10, 10, 11)
                    Geom::Point3d.offset!
                    add comments
                    point2 = point1.offset! vector
                    # point1 now equals point2
                      Dan Rathbun
                      Geom::Vector3d.x=
                      http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#x=
                      Geom::Vector3d.y=
                      http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#y=
                      Geom::Vector3d.z=
                      http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#z=
                      #Anchors: '=' char should be replaced with 'equals' in links.
                      All 3 methods suffer from the same return class anomoly as the Vector3d.[]= method, in that they return the class of the argument (which may not always be Float.) In contrast, the .x, .y and .z methods always return class Float.
                      Propose that the .x=, .y= and .z= methods should be modified to return Float as the .x, .y and .z methods do.
                      Propose to add note: "See the **.set!** method to set all three coordinates in one statement." ( .. to the description sections, of each of the three methods.)
                        Dan Rathbun
                        Geom::Vector3d.set!
                        http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#set!
                        This is a shortcut for writing:
                        Clarify: "This is a shortcut for setting all coordinates of the vector, instead of setting them individually in three statements."
                        You may also call this method with an array or another vector:
                        Confusing. (I first took this mean that the SU extended Array class had an Array.set! method; which is NOT the case.)
                        Clarify: "You may also call this method with an Array or a Vector3d object as the first argument,(and any other arguments will then be ignored.)"
                        Add: "If only one Numeric argument is supplied, or if a one element Array is supplied, then only the x value will be changed. IF only 2 values are supplied, in the same way, then the z value will remain unchanged.
                        All coordinate values must be implicitly convertable to Float class.
                        (If you pass a nil value, a TypeError exception is raised.)"
                        Arguments:
                        x ____ The x value for the vector.
                        y ____ The y value for the vector.
                        z ____ The z value for the vector.
                        vector2 ____ A Vector3d object.
                        Remove 4th argument. (There is no valid fourth argument for this method. All args beyond 3 are ignored.)
                        Clarify: (suggested Argument list)
                        Arguments:
                        x ____ The x value for the vector, a Vector3d object, or an Array.
                        y ____ The y value for the vector. (optional)
                        z ____ The z value for the vector. (optional)
                        Better Code Example:
                        vector = Geom;;Vector3d.new 0,0,1
                        vector.set! 1,0,0  # three Numeric arguments
                        vector2 = Geom;;Vector3d.new 1,2,3
                        vector.set! vector2  # one Vector3d argument
                        # vector now is (1,2,3)
                        array1 = Array.new(4,5,6)
                        vector.set! array1[2]  # one Numeric argument
                        # vector now is (6,2,3)
                        vector2.set! array1  # one Array argument
                        # vector2 now is (4,5,6)
                        vector.set! [5,4]  # one Array with 2 values
                        # vector now is (5,4,3)
                        # change x and z in one statement, this way;
                        vector.set! 9, vector.y, 8
                        # vector now is (9,4,8)
                          Dan Rathbun
                          Geom::Vector3d.[=]
                          [="]http://code.google.com/apis/sketchup/docs/ourdoc/vector3d.html#[]=[/url]
                          Again the HTML anchor may cause problems in some browsers, suggest '#subscriptEquals'
                          Obviously the #[]= anchor tag in the url cannot even be displayed properly in this forum.All of the #anchor links to methods using special chars need to be changed to comply with the HTML spec, as ThomThom noted:
                          ID and NAME tokens must begin with a letter ([A-Za-z]) and may be followed by any number of letters, digits ([0-9]), hyphens ("-"), underscores ("_"), colons (":"), and periods ("."). [url:nfjuel6m]http://www.w3.org/TR/html4/types.html#type-name]("http)
                          Returns:
                          value _______ the newly set coordinate value
                          the Geom::Vector3d.[] method returns class Float
                          BUT, the Geom::Vector3d.[]= method returns the class of the argument.
                          The code example may be misleading to the unwary,
                          value = vector[i] = coordinate
                          ..if the class of the coordinate variable is Integer then the class of the value variable will also be Integer.
                          This causes a coder to do a two-step expression if they want a Float, ie:
                          coordinate = 2
                          vector[i] = coordinate # returns Integer 2
                          value = vector[i]  # value.class >> Float
                          %(#FF4000)[Two Issues:
                          1. Is 'coordinate' the correct term, or would 'component' be a better term when refering to vectors?1. If all the rest of the methods that return subscript values from a Vector3d object are Float, then perhaps this method should as well, regardless of the class of the argument.]
                            Dan Rathbun
                            Geom::Point3d.<
                            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#%3C
                            Returns:
                            true if the point2 is closer to the origin.
                            Following the example, I get the opposite result.
                            TheReturns:should probably read,
                            " *true* if the point2 is **farther** from the origin; *false* if the point2 is closer to the origin (than the receiver.)
                              @thomthom said:
                              Group.move!
                              It doesn't seem to though - we've been testing it in another thread this afternoon and it seem that it moves relative to the transformation-origin NOT the model's ORIGIN - you first have to do a transformation by vector from where it is to the ORIGIN and then off again to the absolute point ?
                                @dan rathbun said:
                                Ruby code can no longer use the nil return value in a conditional boolean statement.
                                There is also no way now to determine how many Dictionary objects, there are within an AttributeDictionaries collection (No Methods: .size, .length, .count, or .empty?)
                                There are no methods but several easy combos to do it...
                                You make an array of it and than get its length ?
                                len = AttributeDictionaries.to_a.length
                                or use 'each' ?
                                len = 0;AttributeDictionaries.each{|d|len += 1}
                                Where len is the AttributeDictionaries length ?
                                  AttributeDictionaries.to_a.length works.
                                    ComponentInstance.explode
                                    http://code.google.com/apis/sketchup/docs/ourdoc/componentinstance.html#explode
                                    Code example is irrelevant - doesn't show the use of .explode.
                                      RenderingOptions
                                      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/renderingoptions.html
                                      FogColor
                                      # FogDensity
                                      FogEnd
                                      FogStart
                                      # FogType
                                      FogUseBkColor
                                      Bold entries returns nil.
                                      The RenderingOptions I get when I iterate the collection is:
                                      BackgroundColor
                                      BandColor
                                      ConstructionColor
                                      DepthQueWidth
                                      DisplayColorByLayer
                                      DisplayDims
                                      DisplayFog
                                      DisplayInstanceAxes
                                      DisplaySketchAxes
                                      DisplayText
                                      DisplayWatermarks
                                      DrawDepthQue
                                      DrawGround
                                      DrawHidden
                                      DrawHorizon
                                      DrawLineEnds
                                      DrawProfilesOnly
                                      DrawSilhouettes
                                      DrawUnderground
                                      EdgeColorMode
                                      EdgeDisplayMode
                                      EdgeType
                                      ExtendLines
                                      FaceBackColor
                                      FaceColorMode
                                      FaceFrontColor
                                      FogColor
                                      FogEndDist
                                      FogStartDist
                                      FogUseBkColor
                                      ForegroundColor
                                      GroundColor
                                      GroundTransparency
                                      HideConstructionGeometry
                                      HighlightColor
                                      HorizonColor
                                      InactiveHidden
                                      InstanceHidden
                                      JitterEdges
                                      LineEndWidth
                                      LineExtension
                                      LockedColor
                                      MaterialTransparency
                                      ModelTransparency
                                      RenderMode
                                      SectionActiveColor
                                      SectionCutWidth
                                      SectionDefaultCutColor
                                      SectionInactiveColor
                                      ShowViewName
                                      SilhouetteWidth
                                      SkyColor
                                      Texture
                                      TransparencySort
                                      If the differences is due to changes between SU version I hope the docs will say when they where removed instead of removing them from the manual. Good to know the history.
                                      • chrisglasierC Offline
                                        chrisglasier
                                        Probably picked up before but I just noticed it. So just in case ...
                                        Drawingelement.visible=SketchUp 6.0+
                                        The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                                        Arguments:
                                        visibility true if you want to hide the element, false if not
                                        Returns:
                                        status true if the element has been hidden, false if the element has not been hidden.
                                        With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                                          Dan Rathbun
                                          My previous post onSketchup::AttributeDictionarieshas been REVISED See the original post:
                                          http://forums.sketchucation.com/posting.php?mode=reply&f=180&t=17047#pr218516
                                            Dan Rathbun
                                            AttributeDictionaries (Introduction )
                                            http://code.google.com/apis/sketchup/docs/ourdoc/attributedictionaries.html
                                            You access this class not by performing an AttributeDictionaries.new but by grabbing a handle from an existing entity.
                                            ... which is refering to Sketchup::Entity.attribute_dictionaries
                                            http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#attribute_dictionaries
                                            @dan rathbun said:
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=17047&p=208352#p208352
                                            This only works for model objects (seems the model has an empty dictionary list by default.) Other entities will return nil (as they do not have an AttributeDictionaries object created until after an AttributeDictionary has been attached.); the API should note that first a script needs to create an AttributeDictionary object, before the AttributeDictionaries object can be 'grabbed' (because it does not yet exist.)
                                            UPDATE (2010JAN23-DanRathbun) PC ver 7.1.6860:
                                            REVISED (2010JAN28-DanRathbun):In, SU ver 7.1, IF the Dynamic Components extension is turned OFF, the entity.attribute_dictionariesmethod will appear to always return aSketchup::AttributeDictionariesobject for the entity, regardless of whether there are any memberSketchup::AttributeDictionary%(#4040BF)[objects.
                                            In addition, (if DCs are OFF,) all of the methods of the]Sketchup::AttributeDictionaryclass (except.name,) will no longer work!
                                            Theentity.attribute_dictionariesmethod was NOT changed in the previous release, as I thought. The method works as the API says it does, returning "nil if there are none." BUT the Dynamic Components extension must be enabled."
                                            There is also no way to determine how many Dictionary objects, there are within an AttributeDictionaries collection (NoMethods: .size, .length, .count, or .empty?)
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 14 / 19
