    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 81.0k Views 24 Watching
      I miss something or we are obliged to recall the box dialog between each generation?
      • Chris FullmerC Offline
        Yeah, I think the inputbox has to be recalled each time you want to use it Frenchy.
        And Pibuz, I will make a grid and divide into 10cm boxes and try the script. Are you trying to offset it more than 5cm?
        If it helps, I use a grid that is roughly made up of boxes that are 9m x 9m. So the deafult values will work best on a much larger grid than 10cm. Maybe just try it on a larger grid for starters. I think you will run into issues if you are trying to offset the face more than is tolerable.
        Chris
        All my Plugins I've written
        • P Offline
          pibuz
          Hi Chris!
          I made a rar file containing all that you requested.
          -skp file
          -greeble.rb
          -progressbar.rb
          -offset.rb
          -screenshots of the problem
          Thank you so much. You're so kind...
          greeble test.rar
          WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          • P Offline
            pibuz
            ...Oh, BTW: I tried to use protrude.rb by Jim Foltz, and it appears to have the same problem.
            I'm starting to feel like I've sort of a plugin conflict... πŸ˜’
              ok, we're getting somewhere. It is possible that you are experiencing a problem that component spray tool is causing. Get the newest release here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16446&p=129280
              That might very well fix the problem. Let me know if it does,
              Chris
              • P Offline
                pibuz
                Yey! everything works allright now!!! Thank you so much!
                Sorry to have been such a pain in the ***, chris...
                Thank you again!
                  Nope, absolutely not a pain at all. Thanks for staying around until we could find the fix. I really want my script to work for everyone.
                  Chris
                  • P Offline
                    pibuz
                    ...I owed it to you πŸ˜„
                    Thank you Chris!
                    PS. Rendered in Indigo. I'm trying a blend map between pure gold shader (metal nk) and stone (diffuse bumpy shader). One night of calculations. I was looking for an high-contrasted image, to give the all scene a dark overall feeling. What do you think? Volume light in postpro.
                      Hey, that looks great! I don't know much about shaders, but the image sure looks good. Glad I could help,
                      Chris
                        bugmcw
                        hey guys! i've tried searching and can't find it..... was there ever a plugin that randomly divides a face?
                        There is one on the web that says it is in production (but that was updated August '08)
                        Thanks in advance!
                          Hihi
                          I believe that is Protrude πŸ˜‰
                          The competitor of this one πŸ’š
                            Sheesh!, get me in trouble with Jim!
                            Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his πŸ˜„ ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
                            Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
                              But Zorro2 by Whaat is cool too and give you more control πŸ’š
                              And works also for a 3D object! 😎
                              @Chris
                              (yes Protrude has just the Button to press between each generation πŸ˜‰ πŸ˜„
                                bugmcw
                                well i had protrude already (go figure)
                                but when i press 'divide' on a rectangular face it does nothing.... any ideas?
                                  You must select face or object not grouped first!
                                  Except that no idea πŸ˜’
                                    bugmcw
                                    hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
                                    [edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
                                      Jim
                                      It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
                                      • X Offline
                                        xrok1
                                        i'll model you one if that helps. 🀣
                                        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                          bugmcw
                                          haha i wont buy you one Jim, but youre more than welcome to test on mine! let me know if i can help!
                                            So goto the Protrude thread and ask your problem ! πŸ˜‰
                                            Maybe it's because you have a Mac πŸ˜’
                                            Damned crossing post πŸ˜’
                                            • 2 / 5
