    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 81.0k Views 24 Watching
      pibuz
      Oh, I use Windows Xp service pack2 or 3, don't remember..
      Sketchy6pro.
      ..I'm gonna pm you the ".rb"s later, cos now I'm at home and I tried the plugin at work. But I can tell you I'm quite sure that all of them are the latest plugins available. 😑
      Moreover, my not-so-well-working-scene is really simple: a square 1m x 1m subdivided into smaller squares 10cm x 10cm. No groups no components nothing at all: just the square. If I select all and start the plugin I get the message i pasted previously..
      I'm so embarassed to bother this much, Chris. But now it's become sort of a personal matter. πŸ˜„
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        pibuz
        ..I had NO generation at all, Pilou... 😳 😳 😳
          I miss something or we are obliged to recall the box dialog between each generation?
          • Chris FullmerC Offline
            Yeah, I think the inputbox has to be recalled each time you want to use it Frenchy.
            And Pibuz, I will make a grid and divide into 10cm boxes and try the script. Are you trying to offset it more than 5cm?
            If it helps, I use a grid that is roughly made up of boxes that are 9m x 9m. So the deafult values will work best on a much larger grid than 10cm. Maybe just try it on a larger grid for starters. I think you will run into issues if you are trying to offset the face more than is tolerable.
              pibuz
              Hi Chris!
              I made a rar file containing all that you requested.
              -skp file
              -greeble.rb
              -progressbar.rb
              -offset.rb
              -screenshots of the problem
              Thank you so much. You're so kind...
              greeble test.rar
                pibuz
                ...Oh, BTW: I tried to use protrude.rb by Jim Foltz, and it appears to have the same problem.
                I'm starting to feel like I've sort of a plugin conflict... πŸ˜’
                  ok, we're getting somewhere. It is possible that you are experiencing a problem that component spray tool is causing. Get the newest release here:
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16446&p=129280
                  That might very well fix the problem. Let me know if it does,
                    pibuz
                    Yey! everything works allright now!!! Thank you so much!
                    Sorry to have been such a pain in the ***, chris...
                    Thank you again!
                      Nope, absolutely not a pain at all. Thanks for staying around until we could find the fix. I really want my script to work for everyone.
                        pibuz
                        ...I owed it to you πŸ˜„
                        Thank you Chris!
                        PS. Rendered in Indigo. I'm trying a blend map between pure gold shader (metal nk) and stone (diffuse bumpy shader). One night of calculations. I was looking for an high-contrasted image, to give the all scene a dark overall feeling. What do you think? Volume light in postpro.
                          Hey, that looks great! I don't know much about shaders, but the image sure looks good. Glad I could help,
                            bugmcw
                            hey guys! i've tried searching and can't find it..... was there ever a plugin that randomly divides a face?
                            There is one on the web that says it is in production (but that was updated August '08)
                            Thanks in advance!
                              Hihi
                              I believe that is Protrude πŸ˜‰
                              The competitor of this one πŸ’š
                                Sheesh!, get me in trouble with Jim!
                                Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his πŸ˜„ ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
                                Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
                                  But Zorro2 by Whaat is cool too and give you more control πŸ’š
                                  And works also for a 3D object! 😎
                                  @Chris
                                  (yes Protrude has just the Button to press between each generation πŸ˜‰ πŸ˜„
                                    bugmcw
                                    well i had protrude already (go figure)
                                    but when i press 'divide' on a rectangular face it does nothing.... any ideas?
                                      You must select face or object not grouped first!
                                      Except that no idea πŸ˜’
                                        bugmcw
                                        hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
                                        [edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
                                          Jim
                                          It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
                                          • X Offline
                                            xrok1
                                            i'll model you one if that helps. 🀣
                                            • 2 / 5
