    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 85.5k Views 24 Watching
    • Chris FullmerC
      Yeah, I think the inputbox has to be recalled each time you want to use it Frenchy.
      And Pibuz, I will make a grid and divide into 10cm boxes and try the script. Are you trying to offset it more than 5cm?
      If it helps, I use a grid that is roughly made up of boxes that are 9m x 9m. So the deafult values will work best on a much larger grid than 10cm. Maybe just try it on a larger grid for starters. I think you will run into issues if you are trying to offset the face more than is tolerable.
      • P
        pibuz
        Hi Chris!
        I made a rar file containing all that you requested.
        -skp file
        -greeble.rb
        -progressbar.rb
        -offset.rb
        -screenshots of the problem
        Thank you so much. You're so kind...
        greeble test.rar
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • P
          pibuz
          ...Oh, BTW: I tried to use protrude.rb by Jim Foltz, and it appears to have the same problem.
          I'm starting to feel like I've sort of a plugin conflict... πŸ˜’
          • Chris FullmerC
            ok, we're getting somewhere. It is possible that you are experiencing a problem that component spray tool is causing. Get the newest release here:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16446&p=129280
            That might very well fix the problem. Let me know if it does,
            • P
              pibuz
              Yey! everything works allright now!!! Thank you so much!
              Sorry to have been such a pain in the ***, chris...
              Thank you again!
              • Chris FullmerC
                Nope, absolutely not a pain at all. Thanks for staying around until we could find the fix. I really want my script to work for everyone.
                • P
                  pibuz
                  ...I owed it to you πŸ˜„
                  Thank you Chris!
                  PS. Rendered in Indigo. I'm trying a blend map between pure gold shader (metal nk) and stone (diffuse bumpy shader). One night of calculations. I was looking for an high-contrasted image, to give the all scene a dark overall feeling. What do you think? Volume light in postpro.
                  • Chris FullmerC
                    Hey, that looks great! I don't know much about shaders, but the image sure looks good. Glad I could help,
                    • B
                      bugmcw
                      hey guys! i've tried searching and can't find it..... was there ever a plugin that randomly divides a face?
                      There is one on the web that says it is in production (but that was updated August '08)
                      Thanks in advance!
                        Hihi
                        I believe that is Protrude πŸ˜‰
                        The competitor of this one πŸ’š
                        • Chris FullmerC
                          Sheesh!, get me in trouble with Jim!
                          Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his πŸ˜„ ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
                          Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
                            But Zorro2 by Whaat is cool too and give you more control πŸ’š
                            And works also for a 3D object! 😎
                            @Chris
                            (yes Protrude has just the Button to press between each generation πŸ˜‰ πŸ˜„
                            • B
                              bugmcw
                              well i had protrude already (go figure)
                              but when i press 'divide' on a rectangular face it does nothing.... any ideas?
                                You must select face or object not grouped first!
                                Except that no idea πŸ˜’
                                • B
                                  bugmcw
                                  hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
                                  [edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
                                    Jim
                                    It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
                                    • X
                                      xrok1
                                      i'll model you one if that helps. 🀣
                                      • B
                                        bugmcw
                                        haha i wont buy you one Jim, but youre more than welcome to test on mine! let me know if i can help!
                                          So goto the Protrude thread and ask your problem ! πŸ˜‰
                                          Maybe it's because you have a Mac πŸ˜’
                                          Damned crossing post πŸ˜’
                                          • Chris FullmerC
                                            Ressurecting the dead - or at leas the long forgotten!
                                            But I've updated this script, and its a big enough update that I thought I'd post and let people know. Two main things are that it now works inside of groups and components and does not cause bug splats! (that was a big bug I never noticed until about 3 weeks ago, oops!). Also, the script remembers your settings between uses (but not between SketchUp sessions).
                                            So if you have an old copy (include clf_greeble.rb or an old clf_greeble2.rb) please delete them and install this one.
                                            UPDATE August 31, 2009
                                            2.20:: 2009-08-31
                                            • Fixed a MAJOR bug that would cuase SketchUp to crash when greeble was used inside a group or component. So yes, you can now safely use Greeble inside a group or component!
                                            • Changed some code that should theoretically speed things up ever so slightly....frankly I don't think it helped.
                                            • Changed some code to make it run smarter, skip certain methods if they were not being executed.
                                            • Fixed some code that could cause problems when faces would overlap.
                                              2.21:: 2009-08-31
                                            • Now user input settings are rembered between script uses.
                                            Download
                                            This script is hosted at http://www.smustard.com/script/Greeble2
                                            • 2 / 5
