    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 85.5k Views 24 Watching
    • Chris FullmerC
      Hmm, did you download the version that is posted on Smustard? That error corresponds to a line of code that is not part of the code. And the provided error does not correspond to what is written on that line also. BUt I have another thought, it does not work on groups or components. You have to have regular ungrouped faces. Or go into a group and then run the script. Is that by chance the problem?
      • P
        pibuz
        Hey!
        ..I'm sorry to report that I downloaded and installed the Smustard version of the plugin.
        And that I tried to greeble a manually-subdivided plane which was not a group..
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        • Chris FullmerC
          Are you on a Mac, or XP, or Vista? Are you using SU 6 or 7? And lastly, maybe could you pm me a copy of the plugin you have installed? And maybe also a model that you tried to use it on. There seems to be something fishy. But we'll figure it out,
          • P
            pibuz
            Oh, I use Windows Xp service pack2 or 3, don't remember..
            Sketchy6pro.
            ..I'm gonna pm you the ".rb"s later, cos now I'm at home and I tried the plugin at work. But I can tell you I'm quite sure that all of them are the latest plugins available. 😑
            Moreover, my not-so-well-working-scene is really simple: a square 1m x 1m subdivided into smaller squares 10cm x 10cm. No groups no components nothing at all: just the square. If I select all and start the plugin I get the message i pasted previously..
            I'm so embarassed to bother this much, Chris. But now it's become sort of a personal matter. πŸ˜„
            • P
              pibuz
              ..I had NO generation at all, Pilou... 😳 😳 😳
                I miss something or we are obliged to recall the box dialog between each generation?
                • Chris FullmerC
                  Yeah, I think the inputbox has to be recalled each time you want to use it Frenchy.
                  And Pibuz, I will make a grid and divide into 10cm boxes and try the script. Are you trying to offset it more than 5cm?
                  If it helps, I use a grid that is roughly made up of boxes that are 9m x 9m. So the deafult values will work best on a much larger grid than 10cm. Maybe just try it on a larger grid for starters. I think you will run into issues if you are trying to offset the face more than is tolerable.
                  • P
                    pibuz
                    Hi Chris!
                    I made a rar file containing all that you requested.
                    -skp file
                    -greeble.rb
                    -progressbar.rb
                    -offset.rb
                    -screenshots of the problem
                    Thank you so much. You're so kind...
                    greeble test.rar
                    • P
                      pibuz
                      ...Oh, BTW: I tried to use protrude.rb by Jim Foltz, and it appears to have the same problem.
                      I'm starting to feel like I've sort of a plugin conflict... πŸ˜’
                      • Chris FullmerC
                        ok, we're getting somewhere. It is possible that you are experiencing a problem that component spray tool is causing. Get the newest release here:
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16446&p=129280
                        That might very well fix the problem. Let me know if it does,
                        • P
                          pibuz
                          Yey! everything works allright now!!! Thank you so much!
                          Sorry to have been such a pain in the ***, chris...
                          Thank you again!
                          • Chris FullmerC
                            Nope, absolutely not a pain at all. Thanks for staying around until we could find the fix. I really want my script to work for everyone.
                            • P
                              pibuz
                              ...I owed it to you πŸ˜„
                              Thank you Chris!
                              PS. Rendered in Indigo. I'm trying a blend map between pure gold shader (metal nk) and stone (diffuse bumpy shader). One night of calculations. I was looking for an high-contrasted image, to give the all scene a dark overall feeling. What do you think? Volume light in postpro.
                              • Chris FullmerC
                                Hey, that looks great! I don't know much about shaders, but the image sure looks good. Glad I could help,
                                • B
                                  bugmcw
                                  hey guys! i've tried searching and can't find it..... was there ever a plugin that randomly divides a face?
                                  There is one on the web that says it is in production (but that was updated August '08)
                                  Thanks in advance!
                                    Hihi
                                    I believe that is Protrude πŸ˜‰
                                    The competitor of this one πŸ’š
                                    • Chris FullmerC
                                      Sheesh!, get me in trouble with Jim!
                                      Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his πŸ˜„ ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
                                      Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
                                        But Zorro2 by Whaat is cool too and give you more control πŸ’š
                                        And works also for a 3D object! 😎
                                        @Chris
                                        (yes Protrude has just the Button to press between each generation πŸ˜‰ πŸ˜„
                                        • B
                                          bugmcw
                                          well i had protrude already (go figure)
                                          but when i press 'divide' on a rectangular face it does nothing.... any ideas?
                                            You must select face or object not grouped first!
                                            Except that no idea πŸ˜’
                                            • 2 / 5
