    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 80.5k Views 24 Watching
      pibuz
      Yey! everything works allright now!!! Thank you so much!
      Sorry to have been such a pain in the ***, chris...
      Thank you again!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • Chris FullmerC Offline
        Nope, absolutely not a pain at all. Thanks for staying around until we could find the fix. I really want my script to work for everyone.
          pibuz
          ...I owed it to you πŸ˜„
          Thank you Chris!
          PS. Rendered in Indigo. I'm trying a blend map between pure gold shader (metal nk) and stone (diffuse bumpy shader). One night of calculations. I was looking for an high-contrasted image, to give the all scene a dark overall feeling. What do you think? Volume light in postpro.
            Hey, that looks great! I don't know much about shaders, but the image sure looks good. Glad I could help,
              bugmcw
              hey guys! i've tried searching and can't find it..... was there ever a plugin that randomly divides a face?
              There is one on the web that says it is in production (but that was updated August '08)
              Thanks in advance!
                Hihi
                I believe that is Protrude πŸ˜‰
                The competitor of this one πŸ’š
                  Sheesh!, get me in trouble with Jim!
                  Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his πŸ˜„ ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
                  Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
                    But Zorro2 by Whaat is cool too and give you more control πŸ’š
                    And works also for a 3D object! 😎
                    @Chris
                    (yes Protrude has just the Button to press between each generation πŸ˜‰ πŸ˜„
                      bugmcw
                      well i had protrude already (go figure)
                      but when i press 'divide' on a rectangular face it does nothing.... any ideas?
                        You must select face or object not grouped first!
                        Except that no idea πŸ˜’
                          bugmcw
                          hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
                          [edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
                            Jim
                            It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
                            • X Offline
                              xrok1
                              i'll model you one if that helps. 🀣
                                bugmcw
                                haha i wont buy you one Jim, but youre more than welcome to test on mine! let me know if i can help!
                                  So goto the Protrude thread and ask your problem ! πŸ˜‰
                                  Maybe it's because you have a Mac πŸ˜’
                                  Damned crossing post πŸ˜’
                                    Ressurecting the dead - or at leas the long forgotten!
                                    But I've updated this script, and its a big enough update that I thought I'd post and let people know. Two main things are that it now works inside of groups and components and does not cause bug splats! (that was a big bug I never noticed until about 3 weeks ago, oops!). Also, the script remembers your settings between uses (but not between SketchUp sessions).
                                    So if you have an old copy (include clf_greeble.rb or an old clf_greeble2.rb) please delete them and install this one.
                                    UPDATE August 31, 2009
                                    2.20:: 2009-08-31
                                    • Fixed a MAJOR bug that would cuase SketchUp to crash when greeble was used inside a group or component. So yes, you can now safely use Greeble inside a group or component!
                                    • Changed some code that should theoretically speed things up ever so slightly....frankly I don't think it helped.
                                    • Changed some code to make it run smarter, skip certain methods if they were not being executed.
                                    • Fixed some code that could cause problems when faces would overlap.
                                      2.21:: 2009-08-31
                                    • Now user input settings are rembered between script uses.
                                    Download
                                    This script is hosted at http://www.smustard.com/script/Greeble2
                                      skkor9y
                                      hi,CHRIS your tools are doin magic.
                                      though my heart was shrunk when two of yr tools didnt worked ...
                                      but yr solution(to PIBUZ),of updating component spray worked...
                                      once again thanx..to u and also pibuz
                                        roytchaikowsky
                                        This thread cannot be in page 11 man
                                          Ummm, what?
                                            It was probably sunken to page 11 of the Ruby Forum. He must have been surprised how that comes although this is such a great plugin
                                            πŸ˜‰
                                            Roy, there IS a reason; this forum is quite active and not only due to the published plugins but also to the technical discussions between the scripters.
                                            Here is a better (cleaner) list of the plugins published on this forum so far (not totally proof though)
                                            http://forums.sketchucation.com/search.php?keywords=Plugin&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=s&sd=a&st=0&ch=300&t=0&submit=Search
                                            Note that this list spans over 21 pages itself so something inevitably must be below page 10.
                                            • 2 / 5
