    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    (TRICK) To re-enable skp file preview
    146 Posts 59 Posters 162.2k Views 59 Watching
      @borgman said:
      I have tried the Seperate command with Windows 7, but alas, it doesn't work. Has anyone come up with a solution for this rather annoying problem already?
      Nope. They changed something between the Beta and the RC so explorer.exe always spawn the 64bit version.
      • EarthMoverE Offline
        EarthMover
        Great trick Thomas! Thanks!! I'll just use the shortcut to search through components. At least I'll have a back button that way.
        Content Creator at Skapeup
        • brodieB Offline
          brodie
          Great find! Thom's shortcut method is working great for me on Vista 64.
          -Brodie
            BorgMan
            I'm going to bump this topic because I'm really curious as to whether this problem has been solved in the released versions of Windows 7. Hey Google, are you watching this? We want our preview back 😑
            More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
            You've gotta love Slivers.
            • E Offline
              Ecuadorian
              Another bump from me. I'm in Windows 7 Pro 64-bit.
              I know the GSU team is working hard in V8, so I hope they add the much needed 64-bit shell extension for Windows Explorer.
              -Miguel Lescano
                No - You can't run the 32bit explorer.exe in the final W7 either.
                • EddyNLE Offline
                  EddyNL
                  Hi guys,
                  I'm using Win 7 64 bit and my previews are also lost.
                  Is there a workaround / solution?
                  Kind regards,
                  Ward
                  viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                  • Y Offline
                    ye136577267
                    • K Offline
                      Khai
                      I have a work around..just noticed it.
                      I have Skp previews in FreeCommander....running on Win7 64...
                      • K Offline
                        kevsterman
                        Thanks for bumping this guys. I saw Thom's suggestion of creating a shortcut to explorer on the desktop and it works a treat. Finally I have preview thumbnails of all my SU models and components. Hurrah!
                        "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                        • K Offline
                          kevsterman
                          Hmm.. I shouldn't have got so happy so soon. Whilst using Thom's desktop shortcut does enable me to view SU thumbnails, I'm finding Explorer constantly crashes. I was trying to sort out all my components into new folders but had to give up because it would crash every time I tried to do anything. Is there a fix for this?
                            bing
                            what i'm doing is that when i want to view some of the su file i open a new sketchup window and i click open, when the whindow pop up i click the view menu to a large icon that's it you will see your su file with preview ...
                            very handy thanx, my pc at work just started doing that the other day
                              FYO, I came across an app that does .skp thumbnails and .skm thumbnails on both 32 and 64bit systems.
                              http://forums.sketchucation.com/viewtopic.php?f=15&t=27784&p=241632
                              http://forums.sketchucation.com/viewtopic.php?f=10&t=27753&p=243280
                                j40
                                Finally! and it works!
                                Thank you Thom so much for pushing it.
                                Top3D Studio
                                • olisheaO Offline
                                  olishea
                                  is this possible with mac? dont get previews 😞
                                  oli
                                    setesur1
                                    Hello to all
                                    Do you have this triedly?
                                    MysticThumbs - Image thumbnails for Windows Explorer.
                                    MysticThumbs 32 and 64 bit Windows Explorer thumbnail generator for PSD, TGA, DDS, RAW camera and other images, color management, XMP extraction, Fully configurable options via control panel, Unicode support, multicore optimized, x86 and x64 support.
                                    (mysticcoder.net)
                                    Discharge
                                    (Direct download links removed. Out of date.)
                                    A greeting. πŸ˜‰
                                      @setesur1 said:
                                      Hello to all
                                      (mysticcoder.net)
                                      Discharge
                                      A greeting. πŸ˜‰
                                      Yes - It's great, .skp and skm - I personally requested it.
                                      Well worth the money.
                                      I removed the direct links to the downloads. They where out of date. He's got regular updates, so it's best to just link to his site. Also, it's good manners not to hotlink other sites resources + it's Donationware so I'm sure he'd like people who download to actually read about the product and see the donation button.
                                        πŸ‘
                                        • brodieB Offline
                                          brodie
                                          mystic thumbs is well worth the $15 or whatever it's going for. I did the trial awhile back and loved it. Finally got around to buying it recently and it's wonderful. The only thing that surprised me was that it doesn't work with .hdr's, but I emailed the owner and he said that it'll be coming very soon πŸ˜„
                                          -Brodie
                                            Yea - he is very responsive to requests.
                                            • 6
                                            • 7
                                            • 8
                                            • 3 / 8
