    (TRICK) To re-enable skp file preview
    147 Posts 60 Posters 204.4k Views 60 Watching
      • Right-click your desktop
      • New->Shortcut
      • Enter C:\Windows\SysWOW64\explorer.exe /separate as the program path
        j40
        A shortcut would be great πŸ˜„ . Can you please explain how can i make one specifically for this command ?
        Top3D Studio
          j40
          Thanks Thom Works great!
          Top3D Studio
          • B
            BorgMan
            I have tried the Seperate command with Windows 7, but alas, it doesn't work. Has anyone come up with a solution for this rather annoying problem already?
            More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
            You've gotta love Slivers.
              Nope. They changed something between the Beta and the RC so explorer.exe always spawn the 64bit version.
              • EarthMoverE
                EarthMover
                Great trick Thomas! Thanks!! I'll just use the shortcut to search through components. At least I'll have a back button that way.
                Content Creator at Skapeup
                • brodieB
                  brodie
                  Great find! Thom's shortcut method is working great for me on Vista 64.
                  -Brodie
                  • B
                    BorgMan
                    I'm going to bump this topic because I'm really curious as to whether this problem has been solved in the released versions of Windows 7. Hey Google, are you watching this? We want our preview back 😑
                    • E
                      Ecuadorian
                      Another bump from me. I'm in Windows 7 Pro 64-bit.
                      I know the GSU team is working hard in V8, so I hope they add the much needed 64-bit shell extension for Windows Explorer.
                      -Miguel Lescano
                        No - You can't run the 32bit explorer.exe in the final W7 either.
                        • EddyNLE
                          EddyNL
                          Hi guys,
                          I'm using Win 7 64 bit and my previews are also lost.
                          Is there a workaround / solution?
                          Kind regards,
                          Ward
                          viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                          • Y
                            ye136577267
                            • K
                              Khai
                              I have a work around..just noticed it.
                              I have Skp previews in FreeCommander....running on Win7 64...
                              • K
                                kevsterman
                                Thanks for bumping this guys. I saw Thom's suggestion of creating a shortcut to explorer on the desktop and it works a treat. Finally I have preview thumbnails of all my SU models and components. Hurrah!
                                "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                • K
                                  kevsterman
                                  Hmm.. I shouldn't have got so happy so soon. Whilst using Thom's desktop shortcut does enable me to view SU thumbnails, I'm finding Explorer constantly crashes. I was trying to sort out all my components into new folders but had to give up because it would crash every time I tried to do anything. Is there a fix for this?
                                  • B
                                    bing
                                    what i'm doing is that when i want to view some of the su file i open a new sketchup window and i click open, when the whindow pop up i click the view menu to a large icon that's it you will see your su file with preview ...
                                    very handy thanx, my pc at work just started doing that the other day
                                      FYO, I came across an app that does .skp thumbnails and .skm thumbnails on both 32 and 64bit systems.
                                      http://forums.sketchucation.com/viewtopic.php?f=15&t=27784&p=241632
                                      http://forums.sketchucation.com/viewtopic.php?f=10&t=27753&p=243280
                                        j40
                                        Finally! and it works!
                                        Thank you Thom so much for pushing it.
                                        Top3D Studio
                                        • olisheaO
                                          olishea
                                          is this possible with mac? dont get previews 😞
                                          oli
                                            setesur1
                                            Hello to all
                                            Do you have this triedly?
                                            404 - File or directory not found.
                                            (mysticcoder.net)
                                            Discharge
                                            (Direct download links removed. Out of date.)
                                            A greeting. πŸ˜‰
                                            • 3 / 8
