    How to make screw threads?
    30 Posts 20 Posters 57.7k Views 20 Watching
    • brookefoxB Offline
      brookefox
      Thread title should perhaps refer to bolt thread, which I am happy to learn about, but I am looking for screw thread.
      ~ Brooke
        Roger
        Pilgrim Screw Company
        @roger said:
        Reminds me of the building I passed on the way home this morning. It was the "Pilgrim Screw Company". It seems like a straight line looking for a joke.
        http://www.azcreative.com
        • K Offline
          KE6CVH
          Hi Gilles, I just downloaded both attachments from your post April 17 2010 and laast edited Mar8 2010. I have them showing up in my plugins when opening sketchup 8 but can't see them in the file folder, kind of strange. One shows up as "screw" and the other as "screw 21". What I need is a tutorial as I don't have the slightest clue how to use them. When I click on the tutorial link on this discussion it brings me to the ruby depot library homepage and if I look under A-Z I can only see the download that doesn't work and no tutorial. Best regards, Mike
          • gillesG Offline
            gilles
            Screw1_5.rb is the one you need (screw in plugins window)
            Have a look at Rich's tutorial:
            http://sketchucation.com/forums/viewtopic.php?p=245701#p245701
            • wimveW Offline
              wimve
              @rich o brien said:
              Here's how to use this plugin....
              Hello,
              Was looking for this today. Works like a charm ! Thanks.
              Best regards,
              Wim
              Holland
              http://www.petromax.nl/DeBeer.html
              • O Offline
                Oliveros
                I'm the last guy to the party. I'm trying to figure this out for 3d printing. Is the plugin used in the example the "Screw_21.RB" and "Screw 1_5.rb" links that were posted?
                  The v1.5 RB file is the newest one [unfortunately it was misnamed by its author ! as explained in an earlier post...]
                  Download it, and manually put that .RB file into your [hidden] Plugins folder, alternatively you can ZIP it and then add .RBZ to the end of the ZIP file, to change its file-type.
                  Then you can install that RBZ, using the native Install Extension processes...
                  The tutorial referenced in this thread covers how to use it...
                  This post might also be of interest...
                  http://sketchucation.com/forums/viewtopic.php?p=654151#p654151
                  • HumpmetwiceH Offline
                    Humpmetwice
                    Draw Whorl??
                    SketchUp Extension Warehouse
                    Your library of custom third-party extensions created to optimize your SketchUp workflow.
                    (extensions.sketchup.com)
                      @humpmetwice said:
                      Draw Whorl??
                      Good suggestion as long as you aren't interested in standard thread profiles.
                      • O Offline
                        Oliveros
                        So far it's working really well for me with the whole Dave Method and then using the upright extruder with a thread profile.
                        I'm printing at 0.06MM layer height to get accurate threads but it seems to be working, I managed to match an existing thread for a part I'm trying to replicate out of PETG as the existing is crap.
                        • 2 / 2
