    [Plugin] SliceModeler v1.3 released!
    93 Posts 37 Posters 121.1k Views 37 Watching
      Thanks TIG.
      You are indeed correct as you always are. Very good.
      Dave
        cpeep
        Thanks for posting on my blog about this. I had toyed with the idea of using Sketchup for sliceforms, but didn't realize you could write a plugin to slice up ANY shape. Fabulous!! I'm going to play around with it a bit. Stay tuned.
        Carol
        Extreme Cards and Papercrafting
        http://extremecards.blogspot.com
          asteronimo
          Dave R,
          Go back to my first post in this thread and get the script there.
          The latest version gives thickness to the slices.
            cpeep
            I've had the opportunity to play around with this plugin a little. It works quite well, but I found that very often I want my center slice to cut through the center point of the model, thus creating two slices that intersect along the center line of each other. (The plugin creates four intersecting slices at the center of the model, equidistant from the center).
            Maybe I missed a way to shift the slices along the model?
            Carol
            • P Offline
              paolo99
              asteronimo - Is there any support for the new version. I've got a bit of a problem...
              Just in case anyone can help -
              I'm trying to slice an object made up of two different pieces - they are grouped so they do look like one. The object is a available to form the the Sketchup 3d Warehouse. It's a mushroom - "Mushroom Pilz' by moom.
              The problem is that the slicer always seems to see the model as two separate entities - which, technically speaking it is. Is there a way to join faces in Sketchup?
              If someone with more of an understanding of what's going on can get this to work properly, can you let me know.
              Cheers
              Paolo
              p.s. It doesn't always ask if I want to output the flat images. This plugin clearly needs work if it's not a freebie!! WASTE OF TIME ❗
              • X Offline
                xrok1
                very nice. i've had this for a while but never tried it out till now. its very cool.
                i do however have a file that it won't complete on, instead of discribing the problem i'll just post the file. could you please take a look at it to verify?
                horse.skp
                “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                • E Offline
                  Ecuadorian
                  Before using the slicemodeler, try getting rid of the internal faces. Make the whole model a single solid.
                  -Miguel Lescano
                  • X Offline
                    xrok1
                    thanks for the script. 😄
                    and thanks for the tip. 😉
                      dcoop58
                      Anybody using SliceModeler v1.4?
                      It's Technical...............
                      • X Offline
                        xrok1
                        • X Offline
                          xrok1
                          oh i see. from the web site. no not i.
                          i wonder if TIG is getting a cut of the sales since its based on his script. TIG how bout it?
                            I am strictly 'non-profit-making'... Though if you want to send me a sack full of cash please PM me for the address... 😄
                            • X Offline
                              xrok1
                              well i would send it to you like i did with Fredo6, but i certainly won't sent to the guy that ripped it off without sharing!
                                dcoop58
                                @xrok1 said:
                                Check out:
                                http://www.public-art-international.com/catalog/product_info.php/products_id/200/language/en
                                SliceModeler 1.4 with downloads and tutorial......
                                  dcoop58
                                  Hi everyone!
                                  Has anyone had issues with random sections not being completed on complex models? I have tried with some success to cut a complex shape with slicemodeler, and I get sections that have the perimeter defined, but the thickness and assembly slots are left out.
                                  Here is a screen cap of what I am talking about:
                                  • P Offline
                                    princedragoncok
                                    @dcoop58 said:
                                    Hi everyone!
                                    I have been using slicer modeller almost on a daily basis for the last two months and yes it simply happens all the time - especially with complex models. The calculations just seem to be buggy. I am very tempted to hear what 1.4 is like - i really should have just paid for it by now..
                                    A quick tip for your case however is that the intersections are crossing over at specifically difficult areas. (like at the junction of the side of the window you have made) - If you alter your spacing so that the intersections fall at simpler junctions then you should be ok.
                                      rru96
                                      Hello there. I have a question about SliceModeler. I am fairly new to SU and SliceModeler and have yet to find a way to do this. What I am looking to do is export a slice to an image so I can print and make small scale models.
                                      I have an object designed. It is sliced into 10 slices on the X and the Y. These slices are 1.5' x 3' on average. I am looking to print each slice up on cardstock or a similar medium to actually get to hold a scaled model of the final to save on costs. Each slice needing to be selected, then sent to the printer so I can then cutout using a cheaper material before going into 'full production' so to speak.
                                      If anyone could help me out I would be greatly appreciated.
                                      I have done a search on the forums and the net but just cant seem to find anything.
                                        dcoop58
                                        After you have created the slices, they are grouped by axis. You can select the group and then right-click and "explode" the group to get individual sections. By using standard camera views, and placing the camera in "parallel projection" you can get a straight on view of your slices. You can then export a 2D graphic of each slice into a .jpg or other format that can then be printed. My concern for you is that your slices are big "1.5' x 3' on average", as you state. I hope you have a big plotter or you will be taping smaller pieces together. If you have Adobe Illustrator, this process is much easier. You can import the group and use AI to scale the slice forms down to fit on standard printer paper.
                                        I hope this helps.
                                          dcoop58
                                          @princedragoncok said:
                                          @dcoop58 said:
                                          Hi everyone!
                                          Thanks for the tip. BTW, I am using SM V1.4 with the results you see above. I thing the main thing is that it is faster than V1.3 and fixes some bugs.
                                            rru96
                                            Thanks for the response. That is what I was doing. Top down view zoomed in. It worked okay. It just took time to scoot to each piece to print. I just was looking for a simplar way. I was able to get it doing the same method you stated, just time consuming.
                                            Now if only I could find a CNC shop!
                                            • 2 / 5
