    [Plugin] Selection Toys
    594 Posts 121 Posters 495.7k Views 121 Watching
      @tig said:
      SO they need 'TT_Lib2 - 2.0.0.zip'
      Yes, they do, but not Selection Toys. Selection Toys still require TT_Lib 1.2.0.
        @thomthom said:
        That is both Image Opacity and Plan Tools that require TT_Lib2. Nothing to do with Selection Toys.
        That's the only way I can recreate the error is to move the Lib2 folder... Other tools load OK... We need a screen-shot of the error-message - our psychic powers are not that powerful... πŸ˜‰
        • EscapeArtistE Offline
          EscapeArtist
          My error message:
            That is the same as what TIG showed - it's not Selection Toys, it's Guide Tools and Image Opacity that both require TT_Lib2. Note the 2 digit here.
            Selection Toys require TT_Lib 1.2.0
            The two other plugins require TT_Lib 2.0.0
              stonebreaker
              SU 8 issue:
              i put the required files in the plugin folder but it doesn't appear in the app.
                @stonebreaker said:
                SU 8 issue:
                Please post a screenshot of the Plugins folder with the files where you placed them.
                  stonebreaker
                  Hi thomthom.
                  here is the content of my plugin folger:
                  #extrusionToolbar.rb
                  2D#.rb
                  2DTools
                  bezierspline.rb
                  BoolTools
                  booltools.rbs
                  BZ_Dir_14
                  ChrisP_RadialMove_EN.rb
                  clf_scale_rotate_multiple
                  clf_select_outer_edges.rb
                  clf_shape_bender
                  clf_shape_bender_loader.r
                  crvsmth.rb
                  ctrlpnts.rb
                  CURVILOFT_Dir_10
                  CurviShear.rb
                  deBabelizer.rb
                  DEFPARAM_Dir
                  Eclate_Deplace.3.0.2_EN.r
                  Examples
                  examples.rb
                  extrudeEdgesByEdges.rb
                  extrudeEdgesByFace.rb
                  extrudeEdgesByFaces.rb
                  extrudeEdgesByLathe.rb
                  extrudeEdgesByLoft.rb
                  extrudeEdgesByRails.rb
                  extrudeEdgesByRailsByFace
                  extrudeEdgesByRailsToLatt
                  extrudeEdgesByVector.rb
                  FREDOSCALE_Dir_20
                  FredoScale_ZH.lang
                  FreeRotate.rb
                  fur_en
                  fur_en.rb
                  jointpushpull.rb
                  JPP_Dir
                  LibFredo6.rb
                  LIBFREDO6_Dir_35
                  LibTraductor.rb
                  lss_tb_icons
                  lss_toolbar.rb
                  maxwell
                  maxwell.rb
                  mshstick.rb
                  Ocean
                  ocean_extension.rb
                  offset.rb
                  pathface.rb
                  pb_loader.rb
                  pnts2mesh.rb
                  ProfileBuilder
                  progressbar.rb
                  proper_animation_1.07.rbs
                  protrude
                  protrude.rb
                  ROUNDCORNER_Dir_21
                  RubyWinFunc.so
                  sample
                  SketchyBevel.rb
                  SketchyPhysics
                  sketchyphysics.rb
                  SketchyPhysics3
                  sketchysolids.rb
                  skin
                  skin.rb
                  SliceModeler.rb
                  SoapSkinBubble
                  SoapSkinBubbleTools.rb
                  sublend.rb
                  Subsmooth
                  subsmooth_loader.rb
                  surface_plotter.rb
                  TheaExporter.rbs
                  TheaExporter_files
                  TIGtools
                  TOS_Dir_16
                  tt_edgetools.rb
                  tt_image_opacity.rb
                  TT_Lib
                  TT_Lib2
                  tt_plan_tools.rb
                  tt_selection_toys.rb
                  TT_Select_Toys
                  tt_solid_inspector.rb
                  Twilight
                  twilight.rb
                  unins000.dat
                  unins000.exe
                  Utilities
                  utilities.rb
                  win32api.so
                  wudworx
                  wudworx.rb
                  WxSU
                  ZLoader__Curviloft.rb
                  ZLoader__FredoScale.rb
                  ZLoader__OnSurface.rb
                  ZLoader__RoundCorner.rb
                    hmm... I see no reason why it would not load.
                    Are you looking for the menus in the Tools menu and the context menu?
                    There was another user that had problems with not seeing the menus of a plugin he'd installed - turned out that the plugins was correctly installed in SU8, but the user was launching SU7. (when you doubleclick .skp files Windows will launch the last SU version you used.)
                      stonebreaker
                      yeah...i look in both menues.
                      su8 is the only sketchup app on my pc^^
                        And there are no errors at all when you start SU?
                        If you open Ruby Console, what output do you get when you type:
                        Select_Toys
                        load 'tt_selection_toys.rb'
                        TT_Lib::VERSION
                          stonebreaker
                          Select_Toys
                          --Select_Toys
                          --true
                          TT_Lib::VERSION
                          --1.2.0
                          i use the german su8 version.^^
                            I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
                            I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
                            Can you post a screenshot of your Tools menu?
                              stonebreaker
                              hi
                              now it runs...i reinstall su8 and copy the plugin seperatly in before i add my "backup-plugin" folder.^^
                              ...for whatever reason...^^
                                hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
                                Whatever it was, I'm glad it work for you now. πŸ˜„
                                  stonebreaker
                                  btw. thx for the help. πŸ˜„
                                  i don't want to miss your really great plugin which makes work so much easier.^^
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
                                    These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
                                    I'm not here much anymore.
                                      Jim
                                      Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
                                      Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
                                        Dan Rathbun
                                        It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
                                        • K Offline
                                          Khai
                                          can someone give me a step by step idiots guide on how to actually use this?
                                          I can get it to light an edge up orange. that's all. how do you select things with it?
                                            Dan Rathbun
                                            See the first post for basic use.
                                            Thomas has a link to a Command Cheatsheet also in the first post.
                                            (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 29
                                            • 30
                                            • 14 / 30
