    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 233.5k Views 123 Watching
      awkonradi
      TIG, thank you very much for that information.
        joergber
        is this plugin still maintained by anybody?
        I would like to know if it is possible to substract an capsulated group from the surrounding one ...
        For example by selecting the groups through the outliner (this doesn't work).
        Or does anybody know of a manual way to do that?
        Many thanks in advance!
        Moin,
        Jörg
        • gillesG Offline
          gilles
          Make your groups components copy them outside with paste in place, substract and delete
            joergber
            Hi Gilles,
            thanks for the quick reply ...
            But I don't get it ...
            'copy them outside with paste in place' seems quite paradox to me ...
            Could you pls. explain again?
            (slowly) 😕
            Many thanks!!!!
            Jörg
            • gillesG Offline
              gilles
              What I understood it that you have a group inside another and you want them to substract.
              So making them components allow you to make copies and place those copies(instances) in a context they can interfere with each other.
              Paste in place make you sure their respective positions are good.
              Procede the boolean operation, then delete them the instances have been modified.
              • gillesG Offline
                gilles
                Forget what I said before about components, this plugin only works with groups
                  joergber
                  thank you anyway!
                  I tried adding an 'object' to the inner group that is not encapsulated ...
                  So I have some kind of selector.
                  But this doesn't work either 😞
                  Any other suggestions?
                  Thanks!
                  Jörg
                  • gillesG Offline
                    gilles
                    But if your two groups are nested at the same level doesnt' it work?
                    • gillesG Offline
                      gilles
                      I made some tries and it seems that subtract fail and sometimes crash with two copies of the same group.
                      could your share the model at least the two groups in their context?
                        joergber
                        attached is my testenvironment ...
                        Have fun!
                        Jörg
                        testenvironment for boolean substraction of encapsulated group
                        • gillesG Offline
                          gilles
                          I think I got you!
                          There is no possible intersection between those two groups: the little one is floating inside the big one, no face intersecting.
                          Just select them, explode and group you get a solid group.
                          Untitled.skp
                          • gillesG Offline
                            gilles
                            Also, I don't know if it's important for 3D print (if want to print) but i should reverse the faces of the "hole".
                              joergber
                              Hi Gilles,
                              thank you!
                              That was too easy (as so often 😉 )
                              Best regards,
                              Jörg
                              • gillesG Offline
                                gilles
                                You're welcome.
                                • dukejazzD Offline
                                  dukejazz
                                  Hey joergber
                                  I have some insight
                                  with the help of section plain
                                  the [Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free ver will works
                                  box- inside.skp
                                  by joergber » Yesterday, 6:26 am
                                  Yes
                                  The smart author gives you both outcome combine and minus as shown above
                                  most of the time you need a inersection to minus a object with another object
                                  but in your special case use section plain so you can make a groups of box- inside object
                                  and a manual way to do that?
                                  is just delete the the inside group object
                                  wait a min you say it the the inter combine you want
                                  well manual way uses outliner to put inter object inside outer object group (then explode inter)
                                  by gilles » Today, 2:22 pm
                                  oh yes reverse
                                  "Many thanks in advance!"
                                  your welcome
                                  Dukejazzz
                                  • JBJDesignsJ Offline
                                    JBJDesigns
                                    Hi!
                                    I know this has been out for awhile, but I used it the other day and it's awesome!!! Thank you Oscar!!!
                                    Jo 😄
                                    ...you send them to school, you give them books, and they eat the pages...
                                      Brettb2953
                                      Will this plugin work for Sketchup Make (v13)
                                      When I run it I see this error in the ruby console with a simple two cube grouped system.
                                      Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                                      (eval):127:in add' (eval):127:in set_current_point'
                                      (eval):73:in `onLButtonUp'
                                      (eval):127
                                        Should work just the same as Pro pr SU8 - there is no change in the API between the versions. Got sample model?
                                          ArtPen
                                          same error 😳
                                            dkolok
                                            I have the same problem. It worked great in 8 but gives that error message in Sketchup Make. A made a cube turned it into a group, made a second cube turned it into a group. the cubes overlap by about 50% then I select the two groups. A window pops up and says "OSCOOLEAN needs UPDATE: OSCoolean is a beta version(Sep 2010) for Google Sketchup Version 8!
                                            then you click on OK and get nothing.
                                            The ruby Console gives these two errors:
                                            Error: #<NoMethodError: undefined method best_picked' for nil:NilClass> (eval):98:in set_current_point'
                                            (eval):73:in onLButtonUp' (eval):98 Error: #<NoMethodError: undefined method best_picked' for nil:NilClass>
                                            (eval):98:in `set_current_point'
                                            BTW I've tried this on both my MAC and Windows 7 machine. doesn't work on either.
                                            I've included the file
                                            Test.skp
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
