    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 246.8k Views 123 Watching
    • gillesG Offline
      gilles
      What I understood it that you have a group inside another and you want them to substract.
      So making them components allow you to make copies and place those copies(instances) in a context they can interfere with each other.
      Paste in place make you sure their respective positions are good.
      Procede the boolean operation, then delete them the instances have been modified.
      • gillesG Offline
        gilles
        Forget what I said before about components, this plugin only works with groups
          joergber
          thank you anyway!
          I tried adding an 'object' to the inner group that is not encapsulated ...
          So I have some kind of selector.
          But this doesn't work either 😞
          Any other suggestions?
          Jörg
          • gillesG Offline
            gilles
            But if your two groups are nested at the same level doesnt' it work?
            • gillesG Offline
              gilles
              I made some tries and it seems that subtract fail and sometimes crash with two copies of the same group.
              could your share the model at least the two groups in their context?
                joergber
                attached is my testenvironment ...
                Have fun!
                Jörg
                testenvironment for boolean substraction of encapsulated group
                • gillesG Offline
                  gilles
                  I think I got you!
                  There is no possible intersection between those two groups: the little one is floating inside the big one, no face intersecting.
                  Just select them, explode and group you get a solid group.
                  Untitled.skp
                  • gillesG Offline
                    gilles
                    Also, I don't know if it's important for 3D print (if want to print) but i should reverse the faces of the "hole".
                      joergber
                      Hi Gilles,
                      thank you!
                      That was too easy (as so often 😉 )
                      Best regards,
                      Jörg
                      • gillesG Offline
                        gilles
                        You're welcome.
                        • dukejazzD Offline
                          dukejazz
                          Hey joergber
                          I have some insight
                          with the help of section plain
                          the [Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free ver will works
                          box- inside.skp
                          by joergber » Yesterday, 6:26 am
                          I would like to know if it is possible to substract an capsulated group from the surrounding one ...
                          Yes
                          The smart author gives you both outcome combine and minus as shown above
                          most of the time you need a inersection to minus a object with another object
                          but in your special case use section plain so you can make a groups of box- inside object
                          and a manual way to do that?
                          is just delete the the inside group object
                          wait a min you say it the the inter combine you want
                          well manual way uses outliner to put inter object inside outer object group (then explode inter)
                          by gilles » Today, 2:22 pm
                          oh yes reverse
                          "Many thanks in advance!"
                          your welcome
                          Dukejazzz
                          • JBJDesignsJ Offline
                            JBJDesigns
                            Hi!
                            I know this has been out for awhile, but I used it the other day and it's awesome!!! Thank you Oscar!!!
                            Jo 😄
                            ...you send them to school, you give them books, and they eat the pages...
                              Brettb2953
                              Will this plugin work for Sketchup Make (v13)
                              When I run it I see this error in the ruby console with a simple two cube grouped system.
                              Error: #<TypeError: wrong argument type (expected Sketchup::Entity or Array of Sketchup::Entity)>
                              (eval):127:in add' (eval):127:in set_current_point'
                              (eval):73:in `onLButtonUp'
                              (eval):127
                                Should work just the same as Pro pr SU8 - there is no change in the API between the versions. Got sample model?
                                  ArtPen
                                  same error 😳
                                    dkolok
                                    I have the same problem. It worked great in 8 but gives that error message in Sketchup Make. A made a cube turned it into a group, made a second cube turned it into a group. the cubes overlap by about 50% then I select the two groups. A window pops up and says "OSCOOLEAN needs UPDATE: OSCoolean is a beta version(Sep 2010) for Google Sketchup Version 8!
                                    then you click on OK and get nothing.
                                    The ruby Console gives these two errors:
                                    Error: #<NoMethodError: undefined method best_picked' for nil:NilClass> (eval):98:in set_current_point'
                                    (eval):73:in onLButtonUp' (eval):98 Error: #<NoMethodError: undefined method best_picked' for nil:NilClass>
                                    (eval):98:in `set_current_point'
                                    BTW I've tried this on both my MAC and Windows 7 machine. doesn't work on either.
                                    I've included the file
                                    Test.skp
                                      troypiggo
                                      I'm having the same error also. I'm trying to trim a group with a group full of components, but get the same error with just simple cube groups.
                                      This is not my signature. I type it at the end of every message for quality control.
                                        dkolok
                                        Any thoughts? Has anyone gotten this to work in Sketchup make?
                                          smartroad
                                          Same error here 😞
                                            The toolset's author has not been active in the forums for some time... you could try to PM or email him. 😕
                                            Unfortunately he has compiled his toolset's script as a .rbs file, making it impossible to read or change.
                                            I suspect that his tool has a 'SketchUp version checker' to ensure that it's at least being run in v8 - because it probably uses some functions only available in the >=v8 API...
                                            If he is doing a version comparison using a string then something like '9'>'8' would be true, BUT '13'>'8' is false - because of the starting '1' - using integer comparisons is different - 9>8 AND 13>8 are both true...
                                            So it's easy resolved using Sketchup.version.to_i>=8 which returns true for 8, 13, 14 etc. If it is a bald Sketchup.version.to_i!=8 then the code is also easily adjusted as above...
                                            There is no simple way to side step the compiled script's version checker... 😒
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
