    Is it possible...
    7 Posts 4 Posters 1.0k Views 4 Watching
    • W
      Whaat
      1. Is it possible to enter 'component edit mode' with Ruby?
      2. Is it possible to prompt the user to browse for a file folder (not a file)?
      If not, consider these requests for the next service release of SU.
      Thanks.
      • R
        RickW
        No on both counts. I requested #1 back in June and again in October, so it's on the radar in Boulder. I like #2 as well. I suppose it could be handled in a webDialog, but it would be so much better as a native tool. I have officially requested #2 now...
        RickW
        www.smustard.com
        • W
          Whaat
          Thanks Rick! (although not the response I was hoping for...)
          • W
            Whaat
            Good info, TIG. Thanks!
            Here's another one:
            Is it possible to use the arrow keys to lock axis inference in a user-defined tool?
            • fredo6F
              fredo6
              I am afraid you have to code it as part of your tool, which is not too complex in general.
              Sorry for bad news, but maybe someone else has a trick.
              Fredo
              • W
                Whaat
                [I am afraid you have to code it as part of your tool, which is not too complex in general.
                I'm not quite sure how to do this...I guess I'll start experimenting.
                • TIGT
                    Thanks.
                  1. I used a trick to edit groups [PC only] - components could be done similarly...
                  require 'sketchup'
                  require 'win32ole.so'
                  def edit_group
                    ### an example of access SUp tools not otherwise available...
                    ### make shortcut here if NOT set already = ctrl+alt+shift+G
                    ### check that you have one group selected and if so do this...
                    WIN32OLE.new("WScript.Shell").SendKeys("+^%{g}")
                  end#def
                  ### run it from within other tools
                  ### the menu here for test only...
                  if(not file_loaded?("edit_group.rb"))
                    UI.menu("Plugins").add_item("Edit Group"){edit_group}
                  end#if
                  file_loaded("edit_group.rb")
                  1. This is how I find a directory - you do need to pick a file in it though...
                  require 'sketchup.rb'
                  def materialimporter
                     model= Sketchup.active_model
                     materials= model.materials
                     model.start_operation ("Import Materials") ###undo - see commit at end
                     pwd= Dir.getwd.split("/").join("\\")+"\\" ### fix for SU
                     drctry= UI.openpanel "To Pick this Directory; Pick Any Image File + OK...", pwd , "*.???"
                     return nil if not drctry
                     drctry= File.dirname(drctry)
                     cwd= Dir.chdir(drctry)
                     images= Dir["*.{jpg,png,tif,bmp,gif,tga,epx}"]### for all supported image file types
                     for image in images
                        imgname= image.split(".")[0..-2].join(".") ### removes .jpg etc from end
                        mat= materials.add(imgname)
                        mat.texture= image
                     end#for image###
                     model.commit_operation ###undo all if needed
                  end#def###
