    Is it possible...
    7 Posts 4 Posters 964 Views 4 Watching
    • W Offline
      Whaat
      1. Is it possible to enter 'component edit mode' with Ruby?
      2. Is it possible to prompt the user to browse for a file folder (not a file)?
      If not, consider these requests for the next service release of SU.
      Thanks.
        RickW
        No on both counts. I requested #1 back in June and again in October, so it's on the radar in Boulder. I like #2 as well. I suppose it could be handled in a webDialog, but it would be so much better as a native tool. I have officially requested #2 now...
        RickW
        www.smustard.com
        • W Offline
          Whaat
          Thanks Rick! (although not the response I was hoping for...)
          • W Offline
            Whaat
            Good info, TIG. Thanks!
            Here's another one:
            Is it possible to use the arrow keys to lock axis inference in a user-defined tool?
            • fredo6F Offline
              I am afraid you have to code it as part of your tool, which is not too complex in general.
              Sorry for bad news, but maybe someone else has a trick.
              • W Offline
                Whaat
                [I am afraid you have to code it as part of your tool, which is not too complex in general.
                I'm not quite sure how to do this...I guess I'll start experimenting.
                    Thanks.
                  1. I used a trick to edit groups [PC only] - components could be done similarly...
                  require 'sketchup'
                  require 'win32ole.so'
                  def edit_group
                    ### an example of access SUp tools not otherwise available...
                    ### make shortcut here if NOT set already = ctrl+alt+shift+G
                    ### check that you have one group selected and if so do this...
                    WIN32OLE.new("WScript.Shell").SendKeys("+^%{g}")
                  end#def
                  ### run it from within other tools
                  ### the menu here for test only...
                  if(not file_loaded?("edit_group.rb"))
                    UI.menu("Plugins").add_item("Edit Group"){edit_group}
                  end#if
                  file_loaded("edit_group.rb")
                  1. This is how I find a directory - you do need to pick a file in it though...
                  require 'sketchup.rb'
                  def materialimporter
                     model= Sketchup.active_model
                     materials= model.materials
                     model.start_operation ("Import Materials") ###undo - see commit at end
                     pwd= Dir.getwd.split("/").join("\\")+"\\" ### fix for SU
                     drctry= UI.openpanel "To Pick this Directory; Pick Any Image File + OK...", pwd , "*.???"
                     return nil if not drctry
                     drctry= File.dirname(drctry)
                     cwd= Dir.chdir(drctry)
                     images= Dir["*.{jpg,png,tif,bmp,gif,tga,epx}"]### for all supported image file types
                     for image in images
                        imgname= image.split(".")[0..-2].join(".") ### removes .jpg etc from end
                        mat= materials.add(imgname)
                        mat.texture= image
                     end#for image###
                     model.commit_operation ###undo all if needed
                  end#def###
