    [Plugin] Archiland Toolbar
    58 Posts 40 Posters 73.7k Views 40 Watching
    • CadFatherC Offline
      CadFather
      have you unzipped all the contents in plugins?
        cyan.archnet
        I did unzip the file, but i still get the same error, don't know what is the problem.
          CadFather
          try replacing this
          Sketchup.rb
            cyan.archnet
            Dear CadFather, It's working perfectly well now, THANKS A WHOLE LOT!
            • arqpadaoA Offline
              arqpadao
              Hi CadFather
              Many thanks, good ideia,
              But
              I have a problem. Installed and appeared all the items on the menu but Plugins to open the window of the icons they do not appear. The folder - Archiland Toolbar are in the plugins folder and the 4 files. RB were copied to the plugins folder of Sketchup. It could help me.
              fernando padão
              arquiteto
              porto alegre - brasil
              http://arqpadao.blogspot.com
                CadFather
                make sure the folder cd_icons is in the plugins folder
                • david_hD Offline
                  david_h
                  Very cool. Thanks.
                  • arqpadaoA Offline
                    arqpadao
                    small detail.
                    There are tutorials on how to use the plugins...
                    I do not understand the use of Spiral Stairs, Simplify Contours, Make Contourns, Triangulate points, Pontify and Terrain Reshaper...
                    fernando padão
                    arquiteto
                      CadFather
                      i'm working on a new set of toolbars and also planning some tutorials - it's just a matter of squeezing it all in 24 hour cycles
                      but in short they are easy to start with - try and see
                      draw a jagged curve with the freehand tool - simplify contours will reduce the jagginess (and segmentation)
                      draw a cone or any 3d shape (not cube), group it - make contours will create new contour lines around the 3d shape
                      on the same shape (explode the group) run pointify - the result is c-points on every vertex (corner)
                      trangulate points does the reverse - delete the 3d shape, select all c-points - run the script
                      you will also find many tutorials in pdf on Didier Bur's site
                      404 Not Found
                      (www.crai.archi.fr)
                        AthidhiTM
                        thanks
                        • arqpadaoA Offline
                          arqpadao
                          thanks
                          this will be very good
                          fernando padão
                          arquiteto
                          • F Offline
                            Frank0503
                            Thanks CADfather, I've already download your ruby in another 4r & it's really really useful. But I wonder why you don't more develop it more, like could I change the style of stair tread like Sketchup?
                              CadFather
                              ..now that we have dynamic components, the stairs might be less important - in any case i'm working on an update..
                              also remember the rubies have been created by the ruby masters - all i did was integrate them into the toolbar with command and icons
                                lorenzo
                                thanks a lot Cadfather!!!
                                that's great!!!
                                  CadFather
                                  your welcome Lorenzo 😄
                                    Ross Macintosh
                                    Max - you truly are the CadFather! Your tool bar is a great addition to the neighborhood.
                                    I have one little problem relating to the roof tools. On my toolbar the mansard & gable roof buttons are transposed. Clicking the gable produces the mansard etc. -- The tooltips are correct so it seems its just the images are referenced wrong.
                                    Regards, Ross
                                      bellwells
                                      Max, as Ross just pointed out, the icons representing the gable, mansard and hipped roof designs are mixed up. The pyramid roof icon is correct. I have renamed the icon (.png) files appropriately and am attaching a new CD_ICON folder here so others can replace the old folder with this one. I hope this is a permissable act on my part.
                                      CD_ICONS.zip
                                      EDIT: Ohhh...and thank you very much for a wonderful tool!!
                                      Ron
                                      • jcdbJ Offline
                                        jcdb
                                        Thanks CF. What does Pointify do?
                                        http://www.acustombuilder.com
                                          bellwells
                                          I think pointify converts vertexes into construction points. Do a search and you'll find plenty of posts on the subject.
                                          Ron
                                            CadFather
                                            Hi, just back from italy where i had little or no connection - can't believe i did live just the same 😲 - i knew there were a couple of icons out of place but they eventually slipped by.. thanks all for your feedback.. and Ron, i will change the package with the updated icons.. (done)
                                            Cheers! 👍
                                            • 2 / 3
