    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • O Offline
      oli_sketch
      Dear Fredo,
      I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
      My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
      Can you help me.
      Thank you and kind regards.
        BillyRX
        @oli_sketch said:
        Dear Fredo,
        Can you help me.
        What he said. Please. This used to be my most commonly used extension. 😞
        • BoxB Offline
          There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
            Beejeez
            I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
            I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
            Thanks in advance
            • fredo6F Offline
              fredo6
              NEW RELEASE 1.6a - 11 Nov 2013
              This release is for future Sketchup compatibility
              Download new release at main post
              Fredo
              • fredo6F Offline
                fredo6
                NEW RELEASE 1.6b - 12 Nov 2013
                It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.
                Fredo
                  Makolee
                  THX FOR THIS PLUGIN
                  • gonashviliG Offline
                    gonashvili
                    Hi there
                    So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
                    Cheers
                    • mitcorbM Offline
                      mitcorb
                      Hi.
                      After reading gonashvili's post above, I opened Sketchup8 to test the spline. I placed an initial spline in an empty scene with 0 default setting. Then began to place another, but changed the parameter to 10 and OK. I got a bugsplat window. I captured the window and the response. Interestingly, I immediately repeated the process and got no error.
                      Sorry, if the two images appear out of order. The splat window is first and the response window is supposed to be second.
                      Also, apology to gonashvili for jumping in here. I was simply investigating.
                        suHappyPills
                        cool tools,Thx a lot.
                        • robertWanR Offline
                          robertWan
                          I type radius 10 mm, but have 14,1. (sqrt200 😒 )
                          Robert
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE 1.6c - 03 Mar 14
                            This release is fixes a bug in the TBone curves, found by Robert Wan.
                            Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13.
                            Download latest release if BezierSpline at main post
                            Fredo
                              robertWan
                              Thank you for the correction.
                              If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
                              Robert
                              • fredo6F Offline
                                fredo6
                                Robert
                                This is not possible with the current GUI. The only thing you can do is to place intermediate points to control the respective lengths of segments at corner.
                                Also, I publish a small upgrade (1.6d) to make sure T-bones appears when one of the segment has the required minimum length.
                                Fredo
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE 1.6d - 04 Mar 14
                                  This release fixes a few bugs and problem in the TBone curves, as highlighted by Robert Wan.
                                  Remember also that v1.6 is necessary for SU14 and also fixes some crashes encountered on some Mac OSX configuration and SU13.
                                  Download latest release of BezierSpline from main post
                                  Or the PluginStore http://sketchucation.com/pluginstore?pln=BezierSpline
                                  Fredo
                                    ly871108
                                    I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
                                    Here is the CHINESE version of 1.6D:
                                    CHINESE Version!Enjoy it! 1.6D
                                    • P Offline
                                      pizixie
                                        dedmin
                                        See the video.
                                        Video_2014-03-28_200608.wmv
                                          matthew.robert
                                          Is there any way to convert multiple welded lines (contours for example) to segmented lines with set segment lengths? I have used Bezier Spline in the past to get better "From Contour" results by converting contour lines one at a time to lines made with consistent segment lengths. This works considerably better than the "simplify contours" plugin that still creates snow drifts all over the place.
                                          EDIT, kinda related... here is a video I created showing how to use the Polyfit LISP (from polyface.de) in Autocad to ultimately get a more efficient model to do a From Contour in SketchUp.
                                          http://youtu.be/6bQtJhDn_lc?t=3m40s
                                          (Easier to see in HD directly on Youtube, also jump to the 3:40 mark to see the polyfit part.)
                                          I've done a similar thing using BezierSpline with the Polyline Divider option, but I need to weld and apply the tool to each contour line rather than all at once with the Polyfit LISP.
                                          -- matt
                                            MarinerSketch
                                            Awesome plugin.
                                            Is there any option or method to make a spline's ends to be tangent to a straight line?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
