    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • nigel_edwardN Offline
      nigel_edward
      Bloody well brilliant tool! Thank you so much! 👍 😍
      • U Offline
        ukchoiceshops
        I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated 😄
        • mitcorbM Offline
          mitcorb
          Hi, Ross:
          Did you read the advice for Mac users on the first page of this topic?
          Alternatively, have you considered using the Sketchucation Plugin Store tool?
          http://sketchucation.com/resources/plugin-store-download
          At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
          There may be some other issue, so post back for someone to assist.
            aydee
            Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
            • O Offline
              oli_sketch
              Dear Fredo,
              I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
              My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
              Can you help me.
              Thank you and kind regards.
                BillyRX
                @oli_sketch said:
                Dear Fredo,
                Can you help me.
                What he said. Please. This used to be my most commonly used extension. 😞
                • BoxB Offline
                  There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
                    Beejeez
                    I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
                    I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
                    Thanks in advance
                    • fredo6F Offline
                      NEW RELEASE 1.6a - 11 Nov 2013
                      This release is for future Sketchup compatibility
                      Download new release at main post
                      • fredo6F Offline
                        NEW RELEASE 1.6b - 12 Nov 2013
                        It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.
                          Makolee
                          THX FOR THIS PLUGIN
                          • gonashviliG Offline
                            gonashvili
                            Hi there
                            So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
                            Cheers
                            • mitcorbM Offline
                              mitcorb
                              Hi.
                              After reading gonashvili's post above, I opened Sketchup8 to test the spline. I placed an initial spline in an empty scene with 0 default setting. Then began to place another, but changed the parameter to 10 and OK. I got a bugsplat window. I captured the window and the response. Interestingly, I immediately repeated the process and got no error.
                              Sorry, if the two images appear out of order. The splat window is first and the response window is supposed to be second.
                              Also, apology to gonashvili for jumping in here. I was simply investigating.
                                suHappyPills
                                cool tools,Thx a lot.
                                • robertWanR Offline
                                  robertWan
                                  I type radius 10 mm, but have 14,1. (sqrt200 😒 )
                                  Robert
                                  • fredo6F Offline
                                    NEW RELEASE 1.6c - 03 Mar 14
                                    This release is fixes a bug in the TBone curves, found by Robert Wan.
                                    Remember also that v1.6 is necessary for SU14 and fixes some crashes encountered on some Mac OSX configuration and SU13.
                                    Download latest release if BezierSpline at main post
                                      robertWan
                                      Thank you for the correction.
                                      If it could also be chosen on which line T-bones is formed. Right now it's only on a longer one.
                                      Robert
                                      • fredo6F Offline
                                        Robert
                                        This is not possible with the current GUI. The only thing you can do is to place intermediate points to control the respective lengths of segments at corner.
                                        Also, I publish a small upgrade (1.6d) to make sure T-bones appears when one of the segment has the required minimum length.
                                        • fredo6F Offline
                                          NEW RELEASE 1.6d - 04 Mar 14
                                          This release fixes a few bugs and problem in the TBone curves, as highlighted by Robert Wan.
                                          Remember also that v1.6 is necessary for SU14 and also fixes some crashes encountered on some Mac OSX configuration and SU13.
                                          Download latest release of BezierSpline from main post
                                          Or the PluginStore http://sketchucation.com/pluginstore?pln=BezierSpline
                                            ly871108
                                            I have translated it into CHINESE,perfectly.I tried my best to be with it.THANK YOU!
                                            Here is the CHINESE version of 1.6D:
                                            CHINESE Version!Enjoy it! 1.6D
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
