    [Plugin] follow me rotate
    211 Posts 79 Posters 242.2k Views 79 Watching
      @alnahrini said:
      Hi guys,,
      i just installed it, but i have this error message
      Note: am using sketchup 2016
      please can any one help me..
      thanks in advance
      Read TIG's post just a few up from yours.
      • P Offline
        pipinek
        After installing the plugin on SU 2015 I have the following message on SU start:
        Error: c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
        c:/users/artur/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
        c:/users/ddd/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/followandrotate_en.rbs:49: syntax error, unexpected end-of-input, expecting keyword_end
        inp=Inputbox.new "±äÐθúËæ"
        SketchUp:1:in `eval'
        I will be thankful for any solution to this issue.
        Thank you in advance.
          You might do the same thing I suggested in the post just above yours in response to the post before that in which the poster reported the exact same problem.
          • I Offline
            irminv
            I installed the plugin, but I get an error message whenever I start SU.
            also the plugin is not visible as a toolbar.
            I have SU15 pro...
            • TIGT Online
              Reread this, about using the correct [but oddly named] version http://sketchucation.com/forums/viewtopic.php?p=537020#p537020
                I have SU15 pro...
                What makes you think there is a toolbar button that is missing? If you watch the tutorial video in the first post, you see it tells you the tool is accessed through the Plugins menu which is now called the Extensions menu.
                  Albert95
                  Hello wikii Is it possible to update "follow me and rotate" for sketchup 2017 ?
                  console ruby
                  Error: #<NoMethodError: undefined method curve' for nil:NilClass> c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:28:in wikii_push_pull'
                  c:/users/.../appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/followandrotate_cn.rbs:109:in block in <main>' SketchUp:1:in call'
                  thank you
                  Albert
                    Albert95
                    Hello,
                    I followed the advice of Tig : "Find the 'en' version and remove it from the v2014 Plugins folder [find that folder using the appropriate utility in the SketchUcation submenu]."
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=13014%26amp;start=120#p530627
                    But "FAR" does not work properly to model a rope.
                    Can I get help
                    thank in advance
                    Albert
                    follow-me and rotate in sketchup 2017
                    • chriC Offline
                      chri
                      hi
                      Same problem as Albert .
                      I had trying after removing the "en" file but the plugin still does not work !
                      The error message has disappeared but i don't see the plugin menu.
                      • TIGT Online
                        @chri
                        You do not seem to have actually removed the ..._en,rbs file as the error-message relates to that !
                        To recap...
                        There are two version of the plugin installed by the RBZ.
                        The ..._en one loads in preference to the .._cn one,
                        Perversely the .._en one has issues because of Chinese characters etc - so that needs removing [..._en.rbs] and the other one [with ..._cn.rbs ending] will be used loaded successfully...
                        http://sketchucation.com/forums/viewtopic.php?p=531322#p531322
                        Note how the author has misnamed the two files before encrypting them !
                        • BoxB Online
                          I'm not sure the plugin works properly on 2017 anyway.
                          I installed it earlier and it was very flaky, (highly technical term).
                            Works in the 2016! 😄
                            Seems not yet in 2017 (even remove en .... )
                            • TIGT Online
                              I've not tested it in v2017 - but if it is "flaky" it will now be unfix-able because its code is encrypted !
                              • chriC Offline
                                chri
                                Hi TIG
                                your are righ, i made a mistake during installation
                                it works fine with 2015 2016 but not 2017 version.
                                • CoreMaster110C Offline
                                  CoreMaster110
                                  Doesn't work with 2017 version. I removed the en version of the file.
                                  I made polyline and a face, selected both, clicked "Extensions/FollowAndRotate" but nothing happens, no dialog box.
                                    Yes, if you read the posts above yours, this has already been reported. Unless the author fixes it, the extension won't work, It doesn't seem likely that the author will fix it so it's probably a good idea to find other ways to manage what you did with this one.
                                      ...or use an old version of Su! 😉
                                        targetx
                                        Hi guys!
                                        Carefully had read everything, made every step as adviced. Installed, removed EN version. No errors, plugin appeared in the menu and everything seemed to be successful, but ... while clicking on the plugin there is NO input box ... Tried on SU 2016 ans 2013 - same result. Please help me to run the plugin 😄 Thanks!
                                        • duanekempD Offline
                                          duanekemp
                                          @wikii said:
                                          It is still in developing, here is the current version.
                                          Get the latest version as an RBZ from the PluginStore:
                                          wikii, This is such a cool, useful and needed plugin. Alternatives to get similar results are tedious, time consuming and not always effective. If possible, I'd like to encourage the continued development of this plugin for SU2017 and SU2018.... resurrect this puppy so it can be used without reverting to SU 2015/16.
                                          I hope you release a new version since this does what needs to be done. And again, thank you for making this!!!
                                          Duane Kemp
                                          Kemp Productions
                                          Puidoux, Switzerland
                                          Gallery:
                                          https://duanekemp.artstation.com/
                                            Ahmed0007
                                            Thanks For Plugin
                                            Please Update for 2017/18
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
