    [Plugin] Double line
    91 Posts 38 Posters 62.8k Views 38 Watching
      rv1974
      Didier many thanks for your efforts!
      Double click for close is neat idea though I couldn't manage to get good result- it's a bit messy.
        it's a bit messy
        ? Very clear! ☀
        A little trick if you find this difficult 😉
        Draw your lines without the plug, group it, then redraw with the plug over them! 😒
        Erase the group
          rv1974
          Now I understood: it closes wall in a newpoint not at the first one. I'm spoiled with CAD background )
          @Pilou: With pre-drowed lines extrude lines.rb is better choise imho
            You have not the drawing of the dashed axis line 😉
            And you have a thickness with extrude simple lines ❓ And a wall ❓
            it closes wall in a new point not at the first one
            Yes Didier is some original ! 💚
            It's some pertubating but after some try we are in the move! ☀
              rv1974
              Pardon, I meant extrude along path .rb (of TIG i beleive).
              I'm afraid the wink about dashed line I didn't understand. What do you mean?
                Just this 😉
                • G Offline
                  gogo2suf
                  Thank You vary much D. Bur ,
                  Thank you!!!!!!!!!!!!
                  GOGO
                    agrazdi
                    Is it possible to add a png icon into the tool bars for the double line function ?
                    agrazdi
                    • FletchF Offline
                      Fletch
                      Didier! You are wonderful... but you already knew this. Thank you for sharing this wonderful update.
                      Since you love bug-hunting... here's what I get now... it does draw the wall but in the opposite direction from expected... I drew vertically on the 'inside' of this wall... I think it's picking the 'positive' direction of the green axis... perhaps - just a guess.
                      my axis lines show up now. 😄
                      So, this guy goes to the doctor...
                      man: "Doc, my arm hurts when I move it like this."
                      doctor: "Well, don't move it like that."
                      Fletch
                      3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
                      • G Offline
                        gamore
                        some errors
                        what should i do?
                          RickW
                          That's caused from "sketchup.rb" not being loaded. Didier should be able to fix that in no time.
                          RickW
                          www.smustard.com
                          • G Offline
                            gamore
                              lengai
                              HI - perhaps a little out of date, but this post appears active (despite last input Oct '08!)
                              Didier did you have an fix for RickW's error as I have got the same message?
                              'Error Loading File dline.rb
                              (eval):514: undefined method `file_loaded?' for main:Object'
                              Any pointers appreciated - i've got a pile of single lines from an OS map, representing adjacent site walls which I would like to double up and extrude (SU speak 'pull') - I figure Dbl Line will do it?
                              Thanks.
                              • Didier BurD Offline
                                Didier Bur
                                Hi, I've released a patch today (10.04.10)
                                See page 1 of the thread.
                                regards,
                                DB
                                  lengai
                                  Didier thanks for snappy comeback! Still getting error message though..
                                  I'm running SU7.1 pro on Vista in case that makes a difference?
                                  Thanks, L
                                    Didier Bur
                                    I don't understand what's happening on your side but it works here.
                                    So the second patch uploaded page 1 of this thread is a version without a call to the offending method "file_loaded?". It SHOULD work.
                                    Regards,
                                    DB
                                    • simon le bonS Offline
                                      simon le bon
                                      Cher Didier,
                                      Happy to see you coming time to time into SCF. Hope you feel good. For me, several of your tools are definitively adopted!!
                                      (Projections tools is an absolute must 👍 👍 👍 )
                                      As you probably know, we have intermittent problems to reach your Ruby Library Depot
                                      About DOUBLE LINE I would like indicate to you a problem with French version. As far, we can't draw the walls because hitting ENTER key calls nothing. So I'm using English version which works fine. 😉
                                      *simon
                                        Didier Bur
                                        Hi Simon,
                                        Yes I know, we had serious problems with our server and it has moved to another computer, but it seems that this is not really the solution.
                                        The RLD site is in complete rework, I hope that in June you'll have a brand new site where (among others) you can submit your plugin yourself, or provide a link to your blog/site, etc.
                                        P.S.: pour la version française je ne comprend pas leproblème puisque c'est le même code avec juste les messages et menus traduits. Je regarde ça dès que possible.
                                        DB
                                          taralee324
                                          Dider, you made my day!!! This makes my life much easier.
                                          A couple of suggestions...
                                          1. Can you add a "Set Defaults" button so that I can be lazy and save my preferred settings between opening/closing SketchUp?
                                          2. Can you add functionality so to support switching to the pan/orbit tool and back w/o loosing the current path being drawn?
                                          Even without... love it!
                                            JuanV.Soler
                                            Thanks Didier great help 👍
                                            just downloaded your plugin, did not noticed before.
                                            • 3 / 5
