    20 ruby's you can't live without
    22 Posts 19 Posters 5.3k Views 19 Watching
    • G Offline
      galbavy1
      Being faster is better in the profession, we should start a list of the top ruby's that made your life easier. Start off by explaining how they made your life better.... ie a real world modeling experience (I took 20 hours to do this vs. 4 hrs with a script). If anybody knows how to make a survey that adds everyones votes that would be great! If I am repeating a previous discussion feel free to drop, drape, and kick my asss! 👍
      • PixeroP Offline
        Pixero
        There are so many good new scripts now but one I use very frequently is "Put on layer."
        Without it my models would be a mess. With it I can hide large portions of geometry while modelling and turn their layers on when i need too.
        Another incredible one is of cause "Joint push pull." This is one of those "how did we survive without it" scripts.
        And "Left click reverse faces." Simple and quick it does what it says.
        And...and...and...
        I'd better stop now and leave some to you. 😉
        • plot-parisP Offline
          plot-paris
          it may sound trivial - but the select instancesscript (not sure, if this is the proper name).
          if you have one component selected, right click on it and "select all instances" to have every copy of the component in your selection.
          if you have a lot of copies of one component (trees in a forrest for example) it is so easy to select all of them... 😄
          • MarianM Offline
            Marian
            Draw on surfaces it's a huge time saver and makes possible editing surfaces easier in conjuncture with joint push pull ....in fact those plugins i use most often
              remus
              Id probably have to go with:
              Joint push/pull
              Tools on surface
              Whaats subsmooth plugin
              Centrepoint script
              The first 2 greatly speed up tihngs that were already possible in SU, and are as easy to use as any native SU tool, just how it should be. SUbsmoth adds an entirely new level of funcion to SU, so you cant go to wrong with that. And finally the centrepoint script does what SU should do, but doesnt, for whatever reason.
              • soloS Offline
                solo
                There are so many great ruby's available, however there are a few I use daily and others that I use specifically. I will say that 'Purge all' is my most used ruby for my day to day works and 'subsmooth', 'JPP', 'Surface tools' and 'FFD' used for all my freeform work (organics)
                http://www.solos-art.com
                • O Offline
                  otb designworks
                  I probably use mirror selection more than anything.
                  Set center point
                  beziersplines
                  Cheers, Chuck
                  OTB Designworks is on Youtube
                  • Mike LuceyM Offline
                    Mike Lucey
                    Guys, I wonder if the info / comments being offered here
                    could be turned into a future poll to establish a User
                    Rating 1 - 20?
                    Mike
                    • jcdbJ Offline
                      jcdb
                      FFD ❓
                      which one is that?
                      http://www.acustombuilder.com
                        JuanV.Soler
                        OK lets do it
                        • jujuJ Offline
                          juju
                          @jcdb said:
                          FFD ❓
                          which one is that?
                          Free Form Deform.
                            JuanV.Soler
                            bit tricky
                            • ibonI Offline
                              ibon
                              I use very much 45ºShadows plugin for elevations, it's very fast and you don't have to move shadows and sun for each view 😉
                              • EdsonE Offline
                                Edson
                                @jcdb said:
                                FFD ❓
                                which one is that?
                                SketchyFFD
                                http://www.mahfuz.arq.br
                                • boofredlayB Offline
                                  boofredlay
                                  In no particular order, here are the ones I am grateful for.
                                  1. Mirror
                                  2. Purge
                                  3. Remove Materials
                                  4. Pipe along path
                                  5. Podium
                                  6. Subdivide & Smooth
                                  7. Sketchy Free Form Deformation
                                  8. STP Copy
                                  9. Weld
                                  10. Tools On Surface
                                  11. Joint Push Pull
                                  12. Round Edge
                                  13. Bevel
                                  14. Windowizer
                                  15. Make Faces
                                  16. Section Cut Face
                                  • EdsonE Offline
                                    Edson
                                    1. Round Edge
                                    eric,
                                    i could not find any script called round edge. can you post it, please?
                                      boofredlay
                                      It's right here on the first page of the Ruby forum.
                                      301 Moved Permanently
                                      (www.sketchucation.com)
                                      • V Offline
                                        viga1978
                                        my indispensable Ruby scripts are:
                                        1)Bezier Spline
                                        2)Tube along path
                                        3)Windowizer
                                        4)Remove material
                                        5)Section Cut Faces
                                        6)3d Grid
                                          dolphus
                                          My most used scripts are
                                          1 FFD
                                          2 Extrude along path
                                          3 Dome
                                          4 Calculator
                                          5 (CASF) Fun Shapes
                                          6 Blezier Curves
                                          7 TOOLS ON SURFACE
                                            Matt666
                                            Hi ! Good idea !
                                            1. Purge
                                            2. Mirror
                                            3. Quick selection
                                            4. Tools On Surface
                                            5. Joint Push Pull
                                            6. Round Edge
                                            7. Beziersplines
                                            8. FFD
                                            9. Ruby panel
                                            10. Global material change
                                            11. Section Cut Face
                                            12. Cut List And Materials
                                            13. Vray
                                            14. Make faces
                                            15. Extrude lines
                                            Frenglish at its best !
                                            My scripts
                                            • 1 / 2
