    20 ruby's you can't live without
    22 Posts 19 Posters 5.9k Views 19 Watching
    • soloS
      There are so many great ruby's available, however there are a few I use daily and others that I use specifically. I will say that 'Purge all' is my most used ruby for my day to day works and 'subsmooth', 'JPP', 'Surface tools' and 'FFD' used for all my freeform work (organics)
      • O
        otb designworks
        I probably use mirror selection more than anything.
        Set center point
        beziersplines
        Cheers, Chuck
        OTB Designworks is on Youtube
        • Mike LuceyM
          Mike Lucey
          Guys, I wonder if the info / comments being offered here
          could be turned into a future poll to establish a User
          Rating 1 - 20?
          Mike
          • jcdbJ
            jcdb
            FFD ❓
            which one is that?
            http://www.acustombuilder.com
              JuanV.Soler
              OK lets do it
              • jujuJ
                juju
                @jcdb said:
                FFD ❓
                which one is that?
                Free Form Deform.
                  JuanV.Soler
                  bit tricky
                  • ibonI
                    ibon
                    I use very much 45ºShadows plugin for elevations, it's very fast and you don't have to move shadows and sun for each view 😉
                    • EdsonE
                      Edson
                      @jcdb said:
                      FFD ❓
                      which one is that?
                      SketchyFFD
                      http://www.mahfuz.arq.br
                      • boofredlayB
                        boofredlay
                        In no particular order, here are the ones I am grateful for.
                        1. Mirror
                        2. Purge
                        3. Remove Materials
                        4. Pipe along path
                        5. Podium
                        6. Subdivide & Smooth
                        7. Sketchy Free Form Deformation
                        8. STP Copy
                        9. Weld
                        10. Tools On Surface
                        11. Joint Push Pull
                        12. Round Edge
                        13. Bevel
                        14. Windowizer
                        15. Make Faces
                        16. Section Cut Face
                        • EdsonE
                          Edson
                          1. Round Edge
                          eric,
                          i could not find any script called round edge. can you post it, please?
                          • boofredlayB
                            boofredlay
                            It's right here on the first page of the Ruby forum.
                            404 Not Found
                            (www.sketchucation.com)
                            • V
                              viga1978
                              my indispensable Ruby scripts are:
                              1)Bezier Spline
                              2)Tube along path
                              3)Windowizer
                              4)Remove material
                              5)Section Cut Faces
                              6)3d Grid
                                dolphus
                                My most used scripts are
                                1 FFD
                                2 Extrude along path
                                3 Dome
                                4 Calculator
                                5 (CASF) Fun Shapes
                                6 Blezier Curves
                                7 TOOLS ON SURFACE
                                  Matt666
                                  Hi ! Good idea !
                                  1. Purge
                                  2. Mirror
                                  3. Quick selection
                                  4. Tools On Surface
                                  5. Joint Push Pull
                                  6. Round Edge
                                  7. Beziersplines
                                  8. FFD
                                  9. Ruby panel
                                  10. Global material change
                                  11. Section Cut Face
                                  12. Cut List And Materials
                                  13. Vray
                                  14. Make faces
                                  15. Extrude lines
                                  Frenglish at its best !
                                  My scripts
                                  • N
                                    nerz
                                    Well i think we could add to this list the script soapskin i use nearly for each of my projects...
                                    • FletchF
                                      Fletch
                                      1 - make faces
                                      2 - extrude lines up, extrude lines using 2 points, etc... all them extrude lines commands.
                                      3 - Windowizer (creates a curtainwall)
                                      4 - select all instances - is that a ruby, or built-in... I forget now...
                                      5 - Joint Push Pull (for push-pulling curves)
                                      6 - pushpull face in any direction (using 2 points), and other pushpull face commands... along normal, along Z, etc.
                                      7 - stair generator
                                      8 - SU2KT (SketchUp 2 Kerkythea)
                                      9 - Proper Animation - (great for showing diff. options for furniture, or doors swinging open)
                                      10 - Scene Exporter pro - once get used to having it... can't live without.
                                      11 - Automated 2D Output
                                      12 - Mirror Selection
                                      13 - Deselect Edges (Deselect Faces) - I think these are rubies...
                                      14 - Offset on surface (and tools on surface)
                                      15 - Purge (this should be number 2)
                                      16 - Layers and Materials plugin by Didier Bur
                                      17 - Intersect overlapping lines
                                      18 - Selection Memory
                                      19 - Soap Skin Bubble
                                      20 - Protrude (closest thing we have to greeble plugin for SU)
                                      Fletch
