    20 ruby's you can't live without
    22 Posts 19 Posters 5.7k Views 19 Watching
    • MarianM
      Marian
      Draw on surfaces it's a huge time saver and makes possible editing surfaces easier in conjuncture with joint push pull ....in fact those plugins i use most often
        remus
        Id probably have to go with:
        Joint push/pull
        Tools on surface
        Whaats subsmooth plugin
        Centrepoint script
        The first 2 greatly speed up tihngs that were already possible in SU, and are as easy to use as any native SU tool, just how it should be. SUbsmoth adds an entirely new level of funcion to SU, so you cant go to wrong with that. And finally the centrepoint script does what SU should do, but doesnt, for whatever reason.
        • soloS
          There are so many great ruby's available, however there are a few I use daily and others that I use specifically. I will say that 'Purge all' is my most used ruby for my day to day works and 'subsmooth', 'JPP', 'Surface tools' and 'FFD' used for all my freeform work (organics)
          • O
            otb designworks
            I probably use mirror selection more than anything.
            Set center point
            beziersplines
            Cheers, Chuck
            OTB Designworks is on Youtube
            • Mike LuceyM
              Mike Lucey
              Guys, I wonder if the info / comments being offered here
              could be turned into a future poll to establish a User
              Rating 1 - 20?
              Mike
              • jcdbJ
                jcdb
                FFD ❓
                which one is that?
                http://www.acustombuilder.com
                  JuanV.Soler
                  OK lets do it
                  • jujuJ
                    juju
                    @jcdb said:
                    FFD ❓
                    which one is that?
                    Free Form Deform.
                      JuanV.Soler
                      bit tricky
                      • ibonI
                        ibon
                        I use very much 45ºShadows plugin for elevations, it's very fast and you don't have to move shadows and sun for each view 😉
                        • EdsonE
                          Edson
                          @jcdb said:
                          FFD ❓
                          which one is that?
                          SketchyFFD
                          http://www.mahfuz.arq.br
                          • boofredlayB
                            boofredlay
                            In no particular order, here are the ones I am grateful for.
                            1. Mirror
                            2. Purge
                            3. Remove Materials
                            4. Pipe along path
                            5. Podium
                            6. Subdivide & Smooth
                            7. Sketchy Free Form Deformation
                            8. STP Copy
                            9. Weld
                            10. Tools On Surface
                            11. Joint Push Pull
                            12. Round Edge
                            13. Bevel
                            14. Windowizer
                            15. Make Faces
                            16. Section Cut Face
                            • EdsonE
                              Edson
                              1. Round Edge
                              eric,
                              i could not find any script called round edge. can you post it, please?
                              • boofredlayB
                                boofredlay
                                It's right here on the first page of the Ruby forum.
                                404 Not Found
                                (www.sketchucation.com)
                                • V
                                  viga1978
                                  my indispensable Ruby scripts are:
                                  1)Bezier Spline
                                  2)Tube along path
                                  3)Windowizer
                                  4)Remove material
                                  5)Section Cut Faces
                                  6)3d Grid
                                    dolphus
                                    My most used scripts are
                                    1 FFD
                                    2 Extrude along path
                                    3 Dome
                                    4 Calculator
                                    5 (CASF) Fun Shapes
                                    6 Blezier Curves
                                    7 TOOLS ON SURFACE
                                      Matt666
                                      Hi ! Good idea !
                                      1. Purge
                                      2. Mirror
                                      3. Quick selection
                                      4. Tools On Surface
                                      5. Joint Push Pull
                                      6. Round Edge
                                      7. Beziersplines
                                      8. FFD
                                      9. Ruby panel
                                      10. Global material change
                                      11. Section Cut Face
                                      12. Cut List And Materials
                                      13. Vray
                                      14. Make faces
                                      15. Extrude lines
                                      Frenglish at its best !
                                      My scripts
                                      • N
                                        nerz
                                        Well i think we could add to this list the script soapskin i use nearly for each of my projects...
                                        • FletchF
                                          Fletch
                                          1 - make faces
                                          2 - extrude lines up, extrude lines using 2 points, etc... all them extrude lines commands.
                                          3 - Windowizer (creates a curtainwall)
                                          4 - select all instances - is that a ruby, or built-in... I forget now...
                                          5 - Joint Push Pull (for push-pulling curves)
                                          6 - pushpull face in any direction (using 2 points), and other pushpull face commands... along normal, along Z, etc.
                                          7 - stair generator
                                          8 - SU2KT (SketchUp 2 Kerkythea)
                                          9 - Proper Animation - (great for showing diff. options for furniture, or doors swinging open)
                                          10 - Scene Exporter pro - once get used to having it... can't live without.
                                          11 - Automated 2D Output
                                          12 - Mirror Selection
                                          13 - Deselect Edges (Deselect Faces) - I think these are rubies...
                                          14 - Offset on surface (and tools on surface)
                                          15 - Purge (this should be number 2)
                                          16 - Layers and Materials plugin by Didier Bur
                                          17 - Intersect overlapping lines
                                          18 - Selection Memory
                                          19 - Soap Skin Bubble
                                          20 - Protrude (closest thing we have to greeble plugin for SU)
                                          Fletch
